Question about Lenovo Computers & Internet
Safe mode key - Lenovo Computers & Internet
  • 55 Answers
The Windows Safe Mode key is always F8.
The key to restore your computer to factory defaults may vary from model to model. You should be able to find that information with a google search like this. http://lmgtfy.com/?q=Lenovo+Desktop+System+Restore
Good Luck
J
Posted on Feb 26, 2015
How do I turn safe mode on on a galaxy avant?
The information is here
Turn on and use safe mode Safe mode allows you to turn on the device with third-party apps disabled. Then you can easily remove all apps that may be causing a conflict or software problem. To turn on safe mode and use it to fix app problems, follow these steps:
Turn on safe mode
  1. Turn the device off.
  2. Press and hold the Power key.
  3. When Samsung Galaxy Avant appears on the screen:
    1. Release the Power key.
    2. Immediately press and hold the Volume down key.
  4. Continue to hold the Volume down key until the device finishes restarting.
  5. Release the Volume down key when you see Safe Mode in the bottom left corner.
Uninstall third party applications
  1. Continue in Safe mode.
  2. From the home screen, tap Apps.
  3. Tap Settings.
  4. Scroll to 'APPLICATIONS,' then tap Application manager.
  5. If necessary, swipe right to the Downloaded screen.
  6. Tap the desired application.
  7. Tap Uninstall.
  8. Tap OK.
Turn off safe mode To turn off safe mode, follow these steps:
  1. Press and hold the Power key.
  2. Tap Restart.
  3. The device reboots in standard mode.
    Safe mode Samsung Galaxy Avant
Jan 16, 2016 | Samsung Galaxy Cell Phones
Will not boot to safe mode imac g4
Starting up in Safe Mode Follow these steps to start up into Safe Mode.
  1. Be sure your Mac is shut down.
  2. Press the power button.
  3. Immediately after you hear the startup sound, press and hold the Shift key. The Shift key should be pressed as soon as possible after startup, but not before the startup sound.
  4. Release the Shift key when you see the Apple logo appear on the screen.
After the Apple logo appears, it may take longer than usual to reach the login screen. This is because your computer is performing a directory check as part of Safe Mode.
To leave Safe Mode, restart your computer without pressing any keys during startup.
Sep 25, 2014 | Apple Computers & Internet
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
Arrow keys will not work in safe mode screen to made selection
On a GUI, use the TAB key to move from an option to the next.
Jan 22, 2014 | IBM ThinkPad Computers & Internet
Start my panasonic CF-f9 in safe mode. what key do I press??
For ALL Panasonic Toughbook Models
and for all Operating Systems
(Win XP, Vista and Win'7):
To start in safe mode, press the "F8" function key
(located ABOVE the number 7) immediately and
repeatedly as soon as you power-ON your
Panasonic Toughbook model.
You will see three choices in a text-only Windows:
Safe Mode (without networking)
Safe Mode with networking (my regular choice)
Use the UP or Down Arrow Keys to HighLight
the selction and then press Enter to choose.
That is it!
Good Luck,
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Jan 24, 2013 | Panasonic Computers & Internet
How do i turn off safe mode on a samsung galaxy ace
Safe mode in Galaxy Ace s5830
To START "Safe Mode" use both hands to Press the Home Key (bottom centre) and then simultaneously Press BOTH the Power (right hand side) key, and the Volume-Up (left-hand side) key. When the Samsung Galaxy logo appears, release the sides' Power and Volume-Up keys but keep the Home key pressed. Safe Mode should come on shortly. SIMPLY DOING THIS SAME KEYING SEQUENCE, WHILE THE PHONE SHOWS "SAFE MODE" IN THE BOTTOM LEFT CORNER OF THE SCREEN, SEEMS TO TURN THAT "SAFE MODE" OFF. Safe Mode prevents Third Party Apps running, apparently.
Apr 18, 2012 | Samsung Lands Phones
How to get to safe modem?
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use yourarrow keys to move to "Safe Mode" and press your Enter key.
Trouble Getting into Windows 2000 or Windows XP Safe mode- If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen
Jan 14, 2012 | Compaq Armada M700 Notebook
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Microsoft Windows Vista and Windows 7 users
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
Won't boot in safe mode
Starting an IBM Thinkpad T43 in safe mode allows you to troubleshoot technical issues that you otherwise couldn't. Often when a system has a virus or other type of malicious program, safe mode is the only way to locate and delete the problem. In safe mode, only the computer's essential programs are enabled, and only the files necessary to running the system are in use. Learn how to start an IBM Thinkpad T43 in safe mode using a few fairly easy steps.
1.Close all programs and restart the IBM Thinkpad T43.
2.Press "F8" repeatedly after the IBM logo appears, but before the operating system logo appears. If the "F8" key doesn't work, restart the computer and try pressing the "F11" key repeatedly.
3.Press the "down arrow" key to select "Safe Mode."
4.Press the "Enter" key. The computer will boot up in safe mode.
Sep 16, 2011 | IBM ThinkPad T43 Notebook
How do you put windows into safe mode?
Power on or Restart your computer, keep tapping F8 on the keyboard while it boots up. After few seconds, you'll be taken to the "Advanced Boot Options" with "Safe Mode" in the lists. Use the Up-Down arrow keys to highlight the "Safe Mode" and press enter on the keyboard to confirm the selected boot options. Black Screen with white texts will be displayed on the display, wait for few seconds until you see the windows logon Screen. You'll also see a confirmation message box asking you to confirm to boot into Safe Mode, click "yes" or "Ok" and proceed forward. There now you are in the Safe Mode.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 26, 2010 | Computers & Internet
Computers & Internet Logo
83 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
