Question about Bosch SHE65T55UC 500 Series 24" Stainless Steel Built-In Dishwasher 15 Place Settings, Energy Star
New never used e24 code does not drain water
Does not finish cycle , water does not drain out
2 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: Bosch dishwasher model SHV6803UC/12 - washing
Welcome to FixYa.
I`ll start by letting you know there are many things which can manifest in the manner you`re describing...or even how one interprets what you`re describing.
Having said that are you referring to water in the tub or in fact the "pan" also known as overfill basin ?
**before performing any repairs please turn off the power to the dishwasher...safety first**
In either case I would instruct you to start by checking the drain hose where it is connecting to your home plumbing...i.e. under sink or into food disposer/garberator. for kinks or obstructions.
Also remove the filter assembly and check for food or soap deposits clogging the sump assembly.
**ultimately it may in fact be a faulty drain pump not pumping the adequate volume of water for the time allowed...but I certainly would check the drain first**
That is by far and away the most common cause behind the problem you are describing...based on my understanding as I mentioned.
Let me know if indeed this was helpful or not and we can move forward from here.
Either way thank you for choosing FixYa today. I`ll watch for your reply.
Regards,
Macmarkus :)
Posted on Sep 22, 2010
Bosch dishwasher stopped working after few minutes. And LED displayed E:24. What is the problem?
Fault Code E24
Symptom: Dishwasher not draining properly.
Cause: Drain filters blocked.
Action: Clean the filters.
Go to:Why is My Bosch Dishwasher Not Draining?
For more detailed codes see ...
http://www.drdishwasher.com/troubleshooting/manufacturer/bosch/error-codes
Sep 05, 2016 | Bosch Dishwashers
It pauses with error code E20 and doesn't seem to drain or spin, could it be the filter is cloged?
The E20 error code is a class code that indicates a drain problem in the washer. This is consistent with the drain and spin problem that you are observing. To determine the exact error code, follow these steps:
Wake the machine by pressing any button
Wait 5 seconds
Press and hold the START and PAUSE/CANCEL buttons simultaneously
The exact error code (E21, E23 or E24) will be displayed.
If E23 or E24 are displayed, you will normally need to replace the control board due to a failed drain pump relay.
If the E21 code is displayed, I recommend that you follow these troubleshooting tips:
Check the washer drain to see if it is clogged.
Check the washer drain hose for a clog or restriction.
Make sure that the washer drain system complies with the installation instructions for the washer.
Try to gravity drain the washer by placing the drain hose in a bucket on the floor. If the washer will gravity drain, you may be able to
unplug the washer
and remove the bottom front service panel using the procedure in the image below. Arrange towels to catch residual water that may be in the washer and check the pump filter and drain trap for a clog or debris. If you find no clog or debris, then you may need to replace the drain pump. NOTE: You should not attempt this procedure unless you are completely confident in your technical ability to safely access and check the pump. Do not disassemble the drain pump hose if the washer is full of water.
May 15, 2015 | Washing Machines
My Miele dishwasher says E24 and will not complete a full cycle. I have cleaned the drain which had some food and fat in it. I've ensured all parts are enabled. What is next to overcome thi
E24 is the heating relay contact that´s probably defect, this would mean that the water is not getting hot.
I can´t remember just where it is locatet.
Dec 18, 2014 | Miele Dishwashers
ERROR CODE E24
E24 is linked to a drain error. You need to get the water out of the bottom and remove the filter by unscrewing it and it will raise up. Get all the water out of the bottom and you will see 3 grooves in the bottom sump area. Make sure nothing is blocking these. On the left side in the bottom you will see a cover and 1 screw.Remove this screw and lift the cover up and make sure nothing is blocking the pump and see if you can turn it by hand . If all of this looks ok the next thing to check is where the unit drains out under the sink. Take the drain line loose and see if anything is clogged where it drains into to the plumbing. Hope this helps and please remember to click accept
Mar 12, 2014 | Thermador DWHD64 Dishwasher
E24 code on Siemens dishwasher, water still in machine
E24 indicates a draining failure.
If the appliance has stopped full of water then you have to check the drain hose for blockages, especially where it connects to the drain. Check the pump for a blockage, bail out the water manually and remove the filters. You should find a cover held by a screw covering the pump impellor. Take out the screw, take off the cover and remove anything jamming the pump. Refit the cover and try the appliance again.
Dec 09, 2013 | Siemens Dishwashers
My washing machine will not drain. It finished all the cycles but didn't drain after the rinse cycle. It still spun afterwards with water still in it.
Aug 10, 2009 | Whirlpool Washing Machines
Dirty water is standing in the bottom of washer when finished what to do?
Check the drain for clogs and also the drain screen. Flush washer with new water. You can use a bucket of water and the drain cycle
Jul 29, 2009 | Dishwashers
if its new call your dealer its a warranty call
Dec 22, 2007 | Dishwashers
Bosch SHE65T55UC 500 Series 24" Stainless Steel Built-In Dishwasher 15 Place Settings, Energy Star Logo
67 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
