Question about Samsung HT-X70 Theater System
POWER SHUTTING OFF NO SPOND
WHEN THE UNIT HAS BEEN RUNNING FOR ABOUT FIVE MINUTES THE SOUND SHUTS OFF
I have a Frigidaire dehumidifer model FDL70S1 that wont stay running for more than 3 minutes and then it shuts the fan off, but still has power to the unit.
Hi lynn crisp, thanks for your post!
From my understanding you are having a challenging time with your Frigidaire dehumidifier shutting too quickly. It sounds like a possible problem with your sensor or control panel. Are you currently under warranty? I would contact your manufacturer for assistance to a proper resolution. -Matt
Oct 20, 2014 | Frigidaire Dehumidifiers
Sanyo flat screen lcd 46 inch
Probably the power supply is failing intermittently, just shutting down without affecting picture or sound.
Mar 10, 2014 | Televison & Video
Compressor shuts off after a few minutes and only fan stays on. now only fan comes on and even that shuts off. I tried power surging. My plumber, installer (2 year old unit) is stumped.
From the sound of it your refrigerant charge sounds like its off. (shutting down on either high pressure; dirty condenser or low pressure; refrigerant leak.)
Jul 27, 2011 | Mitsubishi MSY-A24NA Air Conditioner
Washer keeps shutting down after running for a few minutes
Check the program controller unit, check if there is any loose connection to the wiring to the controller, the relay or the motor and the power plug.
When the machine shuts down then check on the power to the unit , check the door switches, the sensors , in case there is a false alarm..
Jun 14, 2011 | Kenmore Elite 45986 Front Load Washer
My LG flat screen has been just shutting it self o...
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 21, 2010 | Televison & Video
My power light comes on, but it makes a clicking sound then shuts back off
Your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. The sound is it starting up, shutting down, over and over. You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Feb 03, 2010 | Mitsubishi WS-65807 65" Rear Projection...
F9 reset, no heat and door wont lock for cleaning. no heat for regular oven either
Hi. The unit is programmed to not operate,or heat, when there is a serious fault within the door latch assembly. This F-9 code, represents a failed door latch assembly. This device must be replaced. Once replaced, the unit will operate correctly.
NOTE_ Try to reset the mechanism. This can be done by shutting down the power, or unplugging for five minutes. Once the five minutes have passed, simply, re-introduce power to the unit, and observe. if the error code returns, replace the door latch assembly.
Dec 09, 2009 | Amana AOCS3040SS Electric Single Oven
Shuts down after about five minutes and wonr
If it runs really rough before shutting down it is most likely a spark plug.
Jun 29, 2009 | Watts Onan Portable Generator - 4000 ,...
Shuts off completely
They are sending it to NJ to get fixed as the entire power system shuts off on it's own every 20 minutes
Dec 30, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Unit is always shutting down / turning off
Try first unplugging power cable for five minutes and using a different power outlet, if you still get the problem, the unit has a faulty power supply on the board inside.
Nov 12, 2008 | Pioneer Televison & Video
Samsung HT-X70 Theater System Logo
21 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
