Question about Sub-Zero Refrigerators
Black spots My fruit and veggies do not stay, lettuce turns brown in 48 hours, now I have black spots. I also get the spots on my jars. I have had this problem before and have had parts replaced including gaskets twice. Model no 2811 and is 25 years old. Also replaced the metal shelves. The new ones are just plastic covered metal and they are rusting Do you think I should jut get a new fridge? I will not spend the money again for a s zero, but I need one 36 " wide. Thank you for your help
  • 518 Answers
SOURCE: fridge parts broken
Try checking HERE.
Hope that gets ya fixed up...
Geno
Posted on Mar 24, 2008
  • 1462 Answers
SOURCE: Rust spots appearing on front of doors of kitchen (indoor) Kenmore refrigerator.
paint ain't perfect!
rust on a 15yr old appliance is normal
Posted on Dec 01, 2008
  • 56 Answers
SOURCE: condensation and water in refrigerator
It sounds like you need someone who knows what they are doing out to your house. A tech should find and repair or replace the component that leaks. A second trip should be not be needed. The fact you have mold tells me they have never properly did your repair. Mold will grow only when the cavity gets above 40 degrees for a sustained period of time. use http://www.subzero.com/locator/locator.aspx?type=0&zip=02030 or call 800-222-7820 and explain the situation and get another company to fix it right.
Posted on Dec 06, 2008
  • 56 Answers
SOURCE: Need two door shelves, Sub Zero, 251 RFD, the last two shelves
http://www.subzero.com/locator/locator.aspx?type=0&zip=Zip%20Code will get you to the nearest SZ?wolf parts distributor.
Posted on Apr 23, 2009
  • 2976 Answers
SOURCE: Refrigerator crisper drawers are freezing veggies
Shut the air flow into the crispers if you can. If not, turn the refrigerator temperature warmer by just a few degrees. The air into the fridge from the freezer is channeled into the crispers.
Posted on Jul 01, 2009
I HAVE CONCORD GRAPES THE FRUIT DIEING ON VINE AND LEAVES ARE DRYING UP
Have a read. Disease, pests or virus.
Grape Diseases and Drying on the Vine ' Home Guides ' SF Gate
homeguides.sfgate.com > Garden > Pest Control
  1. Cached
  2. Similar
The leaves become mottled with tiny black spots and the fruit also bears dark spots. ... Most of the diseases that cause drying grapes on the vine are fungal ...
Why Are the Grapes Dying on the Vine? ' Home Guides ' SF Gate
  1. Cached
  2. Similar
Luckily, the fungi, insects and bacteria that cause fruit to rot or wither are easily ... Summer bunch rot-infected grapes have black, brown or green powdery fungal ... Removing leaves at the base of stems once grapes have set helps control both ... Best Time to Pick Concord Grapes for the Best Flavor ยท Grapevines & Leaf Curl ...
What Are the Causes of Grapes Turning Black Before They Ripen ...
  1. Cached
  2. Similar
If your grapes turn black on the vine before they ripen, the cause is usually black rot. ... which helps prevent infection by speeding the drying of leaves and fruit.
Why are my grapes turning dark and drying up before they ripen ...
https://ask.extension.org/questions/199835
  1. Cached
  2. Similar
Jul 16, 2014 - Minimize black rot problems by removing infected fruit, cleaning up mummies, and pruning out leaves that surround fruit clusters. See fruit links ...
Grape Diseases ' Integrated Pest Management Program - MSU IPM
www.ipm.msu.edu/grape_diseases
  1. Cached
Oct 16, 2014 - Leaves develop numerous dark brown spots, 1/25 to 1/5 inch (1 to 5 mm) in diameter. ... resulting in distinctive clusters of dead vines within the vineyard. ... Berries that do not fall off shrivel up, similar to black rot-infected berries. .... This disease occurs only in Concord and Catawba grapes in Michigan.
CONCORD GRAPES THE FRUIT DIEING ON VINE AND LEAVES ARE DRYING UP Google...
Aug 14, 2017 | Cooking
Tip
How To Properly Store Vegetables and Food
The first step in proper storage is making sure your refrigerator is at the proper temperature. You will want to make sure your fridge is somewhere between 34 degrees and 40 degrees Fahrenheit. If your fridge goes above 40 degrees, your food will spoil more quickly, but if the temperature is too low, the vegetables in your drawer will freeze.
Often, crisper drawers will have a mechanism to regulate how much moisture flows into and out of the drawer. Depending upon which vegetables you are storing, set the drawer to either let moisture out for drier veggies or keep moisture in for vegetables that need the humidity. Having a fridge with multiple crisper drawers is helpful in storing vegetables based upon their humidity needs.
Vegetables tend to be very sensitive to ethylene, a substance that comes from most fruits and a select number of vegetables. Because of this, storing fruits and vegetables separately is advised. Ethylene exposure is responsible for carrots turning bitter, the yellowing of certain green vegetables and lettuce turning brown. In addition to absorbing ethylene, some vegetables also absorb odors from other veggies. For example, the odor of apples is absorbed by carrots, cabbages and onions. If odor absorption occurs, it can affect the taste of the vegetable. Add a box of baking soda to the crisper drawer to help with odor absorption. After about two weeks, you'll want to shake out the top layer of the baking soda to maximize freshness.
Some vegetables benefit from being stored in a bag in the refrigerator rather than being out of a bag. These vegetables, such as artichokes, broccoli, cauliflower, cabbage and eggplant, should be placed in the crisper bin in perforated plastic or paper bags so that they can maintain moisture. However, some vegetables like lettuce don't do well with lots of moisture; for this reason, you should not wash your vegetables before storing, but before eating instead. With carrots, beets, radishes and parsnips, removing their tops prior to storage will help them keep longer. Similarly, the head of celery stalks should be covered before storing.
on Oct 19, 2011 | Frigidaire Refrigerators
Model #ess25lgpaww ref section too cold turbo light will not go off ,fan goes off and on normal but lite stays on it dont freeze everything but it freeze in fresh food items fruit juice and lettuce
That sounds like a thermostat problem, but I wonder why the Turbo light won't go off.
Here is the Service Manual for your appliance
https://www.manualslib.com/manual/575785/Ge-Gss20.html#manual
This is your Instruction manual and it says if you press the Turbo Mode button, it will run in Turbo Mode for 8 Hours and then you have to press it again after 8 hours to get out of Turbo. Have you tried pulling the plug to get out of Turbo Mode. It chills the compartment to 1'C, so that would certainly ruin a lettuce!
Details are on Page 5.
http://kitchen.manualsonline.com/manuals/mfg/ge_appliances/25_and_27.html?p=5
Dec 18, 2016 | Refrigerators
Does some bagged lettuce have bacteria in them?
Undoubtedly. There have been warnings about rewashing bagged vegetables. Vegetable soap is sold around the country.
Apr 21, 2016 | Cooking
Soft fruits, lettuce, cucumber in fridge turn to mush but jars and bottles stay cold
Crisper drawers were made to be a 4 degree lower temp
try turning up 1 number
Jul 01, 2015 | Smeg FAB10RR Retro style Red 114 l...
GE psc23ng...the veggie bin is freezing vegetables and temp. on fridge and freezer does stay put!!
GE Appliances Customer Phone Number Shortest Wait Best Support
GE Appliances Calls You Instead
Good Luck
THE FIX
Avoiding Frozen Lettuce
By TIM McKEOUGHPublished: March 18, 2009
Q. How can I keep produce from freezing in my refrigerator?
More Articles in This Series
Jason West, the marketing manager for refrigeration at General Electric. "Nobody really knows what the temperature of B is, or what the temperature of No. 5 is."One solution is a refrigerator thermometer. Oxo makes a handsome one with a round dial attached to a suction cup that can be installed easily on either interior side wall ($12.99 atoxo.com). Taylor makes a rectangular digital one that is installed the same way ($12.47 atamazon.com).
Once you have the thermometer, "put it in overnight and check it immediately in the morning, the first time you open the fridge," Ms. Reek said, because the temperature varies during the day as the door opens and closes.
The problem might be where you're storing fruits and vegetables, which are sensitive to cold air. Leafy vegetables are especially prone to freezing, Ms. Reek said, because of their high water content.
Although some newer refrigerators have separate cooling mechanisms for the main body and the freezer, most refrigerators cool by funneling air from the freezer into an opening near the top rear of the main compartment.
Fruits and vegetables should be kept away from this outlet, Ms. Reek said, or else "you're going to be blowing that very cold air right on the produce."
Both she and Mr. West recommended keeping produce in the crisper drawer, away from the circulating air.
"You don't want the moisture to transpire out of the product and make it limp," which can happen with produce on a shelf, Ms. Reek said.
If the crisper is full and some produce has to sit on a shelf, it's better to keep it at the front of the refrigerator, because cold air falls down along the back wall. Along with the area directly beneath the outlet, Mr. West said, "the back and bottom of the refrigerator tend to be the coldest spots."
Shirley O. Corriher, a biochemist and cookbook writer, suggests shaking off all the surface moisture from produce and sealing it in heavy zip-top freezer bags before putting it in the crisper drawer or on a shelf.
"Oxygen is a major villain, so to speak, in the deterioration of fruits and vegetables," said Mrs. Corriher, the author of "BakeWise: The Hows and Whys of Successful Baking" (Scribner, 2008) and "CookWise: The Secrets of Cooking Revealed" (William Morrow Cookbooks, 1997).
Lettuce leaves, in particular, benefit from being sealed in plastic, she said, and you should roll the bag "until you squeeze all the air out. That lettuce will keep for three weeks. It's just amazing."
Still, Ms. Reek said, "the objective of food is to eat it."
"If it's fresher, it's going to have higher vitamin content and be healthier for you," she said. "So it's really better not to plan to store food for ever and ever."
Feb 16, 2015 | GE Refrigerators
Can fruits and vegetables be stored for emergencies?
No, unless they are canned fruits and vegetables. Regular vegetables and fruits will not last for a long period of time.
Feb 04, 2013 | Home
Kenmore 253. I'm renting a house with this refrigerator. Freezer seems ok but fresh food spoils really fast - lettuce brown, berries moldy, etc. How should I adjust the refrigerator? Thanks.
maybe a door seal issue. Worn seals allowing fresh moisture laden air into the box. May not be getting enough cold air, try turning it down. Lettuce browns from oxygen contact, fresh air may be making it brown faster. May also be just how the unit operates.
Oct 07, 2010 | Kenmore Refrigerators
Jul 01, 2009 | GE PFS22SISSS Stainless Steel French Door...
Humidity controls for my refrigerator
High humidity for veggies!
Low humidity for fruits!
Jan 01, 2009 | Home
Refrigerators Logo
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
