Question about Samsung LN40A550 LCD TV
My samsung pn50b550 vertical line screen - Samsung LN40A550 LCD TV
5 Suggested Answers
  • 98 Answers
SOURCE: 42 samsung plasma tv
Need to get service from A/S center for replace PDP module.
Posted on Feb 06, 2009
  • 113 Answers
SOURCE: 50. In LCD samsung has pink vertical lines
hi,
your lcd micron tube in the panel had already worn out.
got to replace the panel
Posted on May 10, 2010
  • 15 Answers
SOURCE: vertical lines on samsung ua46b7000wf
Your screen is probably cracked did someone hit the screen with something? Push on the screen lightly next to one of the cracks does it get bigger near your finger? If so you will just have to deal with the lines or replace the TV as it is permanent damage with screen.
Posted on Apr 23, 2012
gopakumarg43
  • 74496 Answers
SOURCE: horizontal and vertical lines on samsung ue46b7000
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or make a search by type in the brand name of the device in the "Search Box", at the top right of the display window
Posted on Dec 05, 2012
Samsung UN40D6000SFXZA TV has blue screen with vertical lines of various shades of blue.
You may try a new T-CON, but most of the problem could be a display panel.
Nov 01, 2017 | Samsung Televison & Video
Tip
Samsung PN50B550 Manual Download
Download Samsung PN50B550 HDTV Manual
Have you misplaced your Samsung PN50B550 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Samsung PN50B550 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
on Apr 25, 2010 | Samsung PN50B550 50 in. Plasma HDTV
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
Two horizontal lines going across the screen
hi i have the same tv mine just started doing this last week were you able to fix the problem if so wht was it
Dec 02, 2012 | Samsung PN50B550T2FXZA PN50B550 50 Plasma...
Vertical lines on samsung ua46b7000wf
Apr 21, 2012 | Samsung 460UX-2 LCD TV
I have a Samsung PN50B550-T2F (almost 2 years old) and for more than 2 months a thin (possibly one pixel thick) vertical line runs down the center of the screen whenever the television is on. This line has...
No,this problems 100% a circuit board it is the cause and the problems.It is dying and shorting out not axact sure which buffer boards are causing this the upper or lower buffer boards are causing this axactly,but have narow it down it is those 2 buffers boards are shorting out,shops around for local repair shops,cost are different from shop to shops,should cost u around 300-350 for parts and labors.
Jul 26, 2011 | Samsung PN50B550 50 in. Plasma HDTV
Anyone know why the Samsung PN50B550 50in Plasma would have a vertical strip about 2 inches long on the far left side that keeps going to static/out of tune. The rest of the picture is fine. I've checked...
I had this issue..Go to Menu and go to the burn in troubleshooting and run the scrolling feature..Scrolls whites and darks..Run for an hour..I had it on both sides..From watching 4 X 3 pic, image retention..Should clean up fine
Mar 02, 2011 | Samsung PN50B550 50 in. Plasma HDTV
Hi I have a samsung pn50b550 and have saved a movie onto the internal memory am i able to copy it back onto my flashdrive?
Your Samsung PN50B550 does have a USB port for USB devices formatted to FAT16 or FAT32. It supports playback of MP3 and JPG, but not movie formats through the USB drive, at this time.
I hope that helps.
________________________________________
Samsung ck-5339zb TV
only horizontal line it is a vertical section failure. caution keep brightnenn as low as possible till it is rectified & you put on tv before it this just to avoid screen burn. solution 1 check for loose contact or crack print or loose deflection coil connector. 2 check supply to vertical section. 3 check vertical ic. 4 vertical (50)Hz signalto vertical section. good luck
Sep 27, 2007 | Samsung TXN3271HF 32" TV
Samsung LN40A550 LCD TV Logo
13 people viewed this question
Henry  Thomas
Henry Thomas
