Question about Zenith XBV713
Menu no remote - Zenith XBV713
Navigate DVD menu without remote
You can't navigate the DVD menu, without a remote control.
Apr 23, 2013 | Sylvania NB111 Remote Control NB111UD
Tip
Service menu codes phillips magnavox
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes
# Press {0} {6} {2} {5} {9} {7} {INFO+} on the remote.
or
# Press {0} {6} {2} {5} {9} {7} {STATUS} on the remote.
or
# Press {0} {6} {2} {5} {9} {7} {MENU} on the remote.
# Turn the TV off to exit the Service Menu
* Press {0} {6} {2} {5} {9} {6} {INFO+} on the remote.
or
* Press {0} {6} {2} {5} {9} {6} {STATUS} on the remote.
or
* Press {0} {6} {2} {5} {9} {6} {MENU} on the remote.
* Turn the TV off to exit the Service Menu.
* Press {0} {6} {1} {5} {9} {6} {MENU} on the remote.
or
* Press {0} {6} {1} {5} {9} {7} {MENU} on the remote.
* Turn the TV Off to exit the Service Menu.
* Press {1} {6} {2} {5} {9} {6} {MENU} on the remote.
or
* Press {1} {6} {2} {5} {9} {6} {STATUS} on the remote.
* With the TV off:
Models 15MF605T/17, 20MF605T/17, 15MF500T/37:
To Factory Mode:
Step 1 : Select the source "PC" and then turn off LCD-TV.
Step 2 : [Push "power " button and then push the "VOL- " and "VOL+" buttons at the same time immediately and hold it] about five seconds then release all buttons.
Press "menu"button and bring up factory mode indication
on Apr 29, 2015 | Magnavox Televison & Video
Tip
DirecTV Remote Control Onscreen Setup
DirecTV Universal Remote Control Onscreen Setup
You can set your DirecTV Remote Control up for your other equipment onscreen by following these steps:
  1. Press MENU
  2. then SELECT on Settings, Setup in the Quick Menu
  3. then selecting Remote from the left menu.
I hope that helps.
________________________________________________
DirecTV Remote Control Code List Download
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Search
DirecTV Remote Control Code Entry
on Jun 10, 2010 | Televison & Video
Cant get in to the menu cause the remote controll is bad
Most models need the remote to access the menu and settings. You should be able to get a remote from www.tvrepairworld.com
Mar 31, 2010 | Televison & Video
Tip
  1. Press MENU
I hope that helps.
on Jun 10, 2010 | Universal Remote Control DIRECTV Universal...
Tip
Acessing Menu with universal remote
We used a One4All model URC3021BOO remote. We programmed BOTH the TV function and the DVD/vcr button with code 0807.  To access the menu PRESS TV then MENU button then DVD/VCR button will allow you to change menu functions using left and right and select buttons. *TV button will access Menu screen BUT NO menu functions. * DVD/VCR button will NOT access menu screen but WILL control menu functions if menu is already displayed. May work with other sharp products, or other universal remotes? These original (RRMCG1330PESA) remotes run 38.00+ to buy new so try this FIRST!
on Oct 29, 2008 | Sharp 13VT-J100 13 in. Combo
No Remote - Need to access Menu
on some sets you can push both the channel up and down buttons to access the menu, then use them and the volume buttons to navigate the menu. otherwise you may have to get a programmable remote control.
May 30, 2008 | Televison & Video
Menu, select buttons not working
Try getting a universal remote that would let you get into the menu and change the settings you are thrying to change.
Jan 02, 2006 | Zenith Z46Z83D 46" Rear Projection...
Menu
Why do you need them? use the remote....
Jan 01, 2006 | Zenith Z46Z83D 46" Rear Projection...
Zenith XBV713 Logo
13 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
