Question about Whirlpool Refrigerators
Klixon 8ea Tengo un regfrigerador Kenmore el relex de arranque es KLIXON 8EA 303 2183454, pero ese modelo no lo consigo, por cual lo sustutuyo
5 Suggested Answers
tzweeb
  • 318 Answers
SOURCE: 18 cubic foot roper is clicking, but not freezing.
yes the "relay" on your unit has burnt out. if you shake it and pepper looking pieces come out of it that will verify that you need to replace the relay.
nice work finding the exact problem by yourself and now all you have to do is buy a relay and plug it in to get things back to normal.
also be sure to clean the coils under the unit as when the compressor gets too hot it will cause the relay to fail. it is very common and you can fix this yourself.
Posted on Jan 07, 2009
SOURCE: mi nevera no esta enfriando en el lado del refrigerador
cambiale tambien el bimetalico y la resistencia tambien podria ser le desconectas los 2 cables de lado a lado de la resistencia que esta en el freezer y le pones un cable 110 y lo conectas si ve que se pone caliente la misma esta buena pero si no puede ser parte del problema , cuando estos problemas pasan hay que buscar en el timer,bimetal y resistencia
Posted on Mar 11, 2010
heatman101
  • 43501 Answers
SOURCE: Tengo un frigorifico Magic chef
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 11, 2010
Testimonial: "Gracias, el problema está solucionado"
  • 304 Answers
SOURCE: tengo un problema con la
49.XXXXX ERROR To continue turn off then on
A critical firmware error has occurred.
This type of error can be caused by invalid
print commands, corrupt data, or invalid
operations.
In some instances, electrical noise in the
cable can corrupt data during transmission
to the MFP. Other causes include poorquality
parallel cables, poor connections, or
specific software programs.
Sometimes, the formatter itself is at fault,
which is usually indicated by a 79 ERROR
message.
Follow this:
1 Turn the MFP off, and then turn the MFP on.
2 Upgrade the firmware.
3 Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
4 If the message persists when using different software programs and attempting specific print jobs,disconnect all of the cables that connect the MFP to the network or a computer.
5 Turn the MFP off.
6 Remove all DIMMs and flash-memory cards. Do not remove the firmware memory card that is in slot 1.
7 Remove all of the EIO devices.
8 Turn the MFP on.
9 If the error message disappears, reinstall each DIMM, flash-memory card, and EIO device individually, making sure to turn the MFP power off and then on again as you install each device.
10 Replace the component that caused the error message.
11 If the error persists, replace the formatter.
Posted on Jul 14, 2011
Necesito programar mi television sanyo pero no tengo control remoto
Hola Rodolfo, para que su control funcione con su TV, el control tiene que ser programado a la TV. Tendra que hacer lo siguiente: Siga este vinculo, http://www.mydish.com/support/apps/remotecodes.aspx seleccione el modelo de control (este se encuentra en la parte de atras del control) Una vez usted haga esto, seleccione el tipo de aparato al cual necesita programarlo (en su caso es TV) Y despues la marca de la TV. Una vez usted haga esto le aparecesaran los codigos que posiblemente funcionan con su TV. El procedimiento a programar su control es el siguiente Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 585#. El boton de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor, deberia funcionar. Si tiene preguntas adicionales por favor contacteme a kimberly.escobar@dish.com.
Dec 26, 2012 | DISH Network IR Remote Control
Mi malibu maxx 2004 necesita un cambio de aceite cuando lo compre me dijeron qe el aceite que lleva es color azul pero me dicen que no existe ese color!
hola , tengo un carro malibu 2004 , y creo ke esta kemando aceite , hoy ke trate de prenderlo me encendio la luz del motor , le cheke el aceite y le asia falta , le puse , pero la luz no se le apaga y cuando le aselero tiembla cual podria ser el problema , me podrian guiar por favor
May 29, 2012 | 2004 Chevrolet Malibu Maxx
Tengo un p9000t pero al iniciaqr DVD, TV o simplemente encenderlo aparesce una imagen que dice warning pleasa stop wacht video player en momentos trasmite el canal y el video pero posterior presenta...
Hola buen dia, mira tengo un stereo con pantalla marca planet audio, modelo P9762T. El probleme es que no funciona el touch y el control igual se descompuso, y no encuentro ni el control ni kien me lo arregle del toach, ayuda x favor saben kien lo puede arreglar y en cuanto saldria o ya de minimo el control. Gracias de antemano y saludos
Jul 02, 2011 | Planet Audio P9745B / P9740 Car Video...
Programar el contro
Hola mi nombre es Mayra Diaz con DISH Network. Tengo entendido que quiere programar un control. Si por favor me puede dar informaci?n adicional con mucho gusto le puedo ayudar con este problema. La informaci?n que necesito es ala televisor que lo quiere programar o al recibidor de DISH Network, otra cosa seria cual es el modelo del control esta localizado en la parte de atr?s de su control.
Jan 13, 2011 | DISH Network IR Remote Control
Tengo problemas con una batidora hobart. hl 600. lellega voltaje a la tarjeta de controles ( velocidad y tiempo) pero no enciende nada y no tengo control de el arranque y paro.
Hola amigo, mi nombre es ramon, a mi me sucedio algo parecido, primeramente debes revisar los 24V Ca en la tarjeta, este es rectificado a 24v cd y 12 Cd quienes son los que alimentan el control, no te desgaste buscando en los interruptores de proteccion, el display debe encender autamaticamente cuando la maquina esta energizada, esto es un defecto al parecer comun en estas maquinas, esta tarjeta tiene un Circuito integrado que alimenta a relay C3 y este a C2, hay varios relay de control los cuales pueden o no activarce pero es fundamnetal que arranque el microprocesador de esta tarjeta, quizas con un poco de tiempo puedas reparar esta tarjeta revisando el relox de control y todos los circuitos de control para el funcionamiento de la misma, hubiera que buscar los datos de estos y hacer una ingenieria inversa para detallar el funcionamiento de la misma, pero para que sea mas facil revisa el cable del puerto de comunicacion entre la tarjeta de mando y el variador de frecuencia, si este esta bueno teniendo continuidad, Ah en este cable hay una linea de color ***** que no se utliza esta solo conectado en uno de los estremos, si todo esto esta bien sustituye esta tarjeta por una nueva la misma esta averiada y si no tienes mucho conocimiento en electronica no la podras reparar o poco tiempo que es lo que sucede a mi, que tenga suerte.
Ramon
Aug 19, 2010 | Hobart HL600 Legacy Stand Mixer
El problema es que preseenta una falla que priba el motor y no tiene buen arranque por que
buenas, no se mucho de mecanica, pero lo que si se es que ese problema pro lo general es causado por que el filtro de aire puede estar tapado. espero el ayude.
Jan 18, 2010 | 2002 Daewoo Lanos
Monitor XVM-R70, NO SE ENCIENDE NI SE PONE EN MARCHA.
Tengo el mismo problema, lo pudiste solucionar.?, gracias
Mar 15, 2009 | Sony XVM-R70 7 in. Car Monitor
Ayuda
Sabes que pasa esta anulada porque quedo pegada la funcion de los ajuste en la pantalla.
Pero esa es la clave de la solucion.
Cuando estes viendo los valores esos que no conoces hay un comando en el control remoto que sirve para ajustar, o cambiar esos valores generalmente es (ADJ) pero en tu remoto no se cual es, fijate que debe haber una tecla que te haga salir de ese menu que es el que estas viendo.
Puede ser o la misma tecla MENU, o la tecla ENTER o la tecla de los canales < > o la del volumen, la que ajusta esos valores, y asi como hay una que los ajusta hay una que te saca de ahi.
Lo unico que tenes que hacer es tratar de salir de ese menu fijandote cual boton te saca.
Ese es todo el problema
Proba de nuevo
Cuando apretas la tecla de volumen
Oct 19, 2008 | Air Tools & Compressors
Cuales son tus fuentes?
Primero que nada, muchas gracias por tu pregunta y por darme la oportunidad de despejar (o ampliar) una duda tuya.
Cuando en un modelo de hardware dice que es la Serie 5100, significa que hay mas "subseries" de modelos en esa misma base de hardware, digamos que la 5100 es la básica y la 5160 la tienes tu y tiene un puerto de USB cuando la 5120 no la tiene. Es un ejemplo.
Otro, en cuanto a laptops HP. La serie Pavilion dv8000 tiene varios modelos, la dv8360 tiene 512 MB de RAM mientras que la dv8600 tiene 2GB y cuenta con bluetooth.
Las placas de hardware son una base para crear mas modelos, le quitan o le aumentan algo, pero fisicamente son similares.
Esto contesta tu pregunta?
Recibe un cordial saludo desde Mexico.
- CoolDragon.
Sep 10, 2008 | HP Photosmart D5160 InkJet Printer
Stereo
esta inabilitado porque cambie la beteria yen momento no tenia el codigo y aparedia en pantalla la palabea safe ,despues lo lleve al conseccionario para que me dieran el codigo el cual me dieron pero como todo aqui en este pais es un caos no pedieron por los momentos desabilitarlo ya que supuetamente tenian mucho trabajo en otras areas mas importantes que ocuparce del estereo en ese momento asi que tengo que pedir cita otra vez para cuando les venga en gana ,asi estamos en este pais sorri lo sieeto de veras tener que plantearlo de esta manera pero tengo que ver si lo puedo hacer yo mismo gracias de antemano.
Jul 21, 2008 | 2005 Volkswagen Jetta
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
