Question about Olympia InfoGlobe Caller ID
Itwill not show incoming call number,even when i plug directly to phone jack
Incoming caller name and number is not showing
Hi, My Nokia 130 phone does not display number for incoming calls. It shows "private number" for all the incoming numbers. I tried moving contacts from SIM to phone, removed duplicate entries. Even restored the factory settings twice. But still it does not help. I will be grateful for any help in this regard.
Mar 15, 2013 | Nokia 100 Rh-130 CV Uk Festival Mobile...
My phone seems dead although the computer connection and the fax are working. Help!
First try a new phone cord and a different phone. Are all items attached to one jack with one phone number? If you have multiple jacks, check if the phone works on another jack. If you have separate phone lines, check if the phone works on the computer/fax line. Check if the phone works without the other devices (particularly if daisy chained). Swap out all of the cables in the chain if it works directly.
In the multiple line case, if your phone works on one line and not the other, check if a phone works on that line at the incoming service. (If you are lucky, the incoming service has RJ-11 connections and you can test this yourself. Otherwise, you'll need a service person.) I've had several cases where mice or something broke one of two incoming phone lines outside so I just lost that one phone number. If the outside service doesn't work, call your phone company. They will fix it for free. If the outside service works, check your jack for loose wires. Check any exposed wiring in the house for damage. If the wiring isn't damaged in the exposed areas or at the jack, you'll probably need a service call (for a fee).
Checking the jack and wiring also applies if the phone works at one jack and not another.
If another phone works and the AT&T phone doesn't, check if the power adapter is plugged in and warm or cold. If the power brick is cold, then replace the power supply. The information on the type of power supply is usually listed on the bottom of the phone. Since this is a corded phone, it should work even without power, but sometimes, it won't. If the power is good to the phone, then replace the AT&T phone. Unless it's under warranty, it isn't worth getting them serviced. They aren't meant to be user serviced.
I hope this helps.
Jan 18, 2011 | AT&T 1855 Phone
Change incoming fax number
Unless I'm misunderstanding your question, your fax machine has nothing to do with the incoming fax number. That's assigned by your phone service provider to the telephone line the fax machine is connected to. The only way to change that number would be connect the machine to a different phone line. This might be as simple as just plugging the phone cord into another jack if that line already appears at a convenient location, or it might mean a visit from a technician to place a jack where it's needed. Or you can contact your phone service provider about assigning a new number.
I hope this has helped. If not, please post a comment with more information about your question and I'll try to help further.
Oct 11, 2010 | Canon FAX-L800 Plain Paper Laser
Incoming calls show up unknow number/ even ones in address book
Hi Bro. I have d same Problem since yestday.. It shows unknown number for all d incoming calls even from d ones in Phone book. Did u find a solution to this problem.. Please help me out on this. THANKS.
Yogesh Kumar
Sep 16, 2010 | Samsung Gravity SGH-T459 Cell Phone
On incoming calls the caller id use to show number and name time ect. but now it just shows no id,but if i get a text it shows from who and when.
Did u find a solution to this problem.. If Yes, Please help me out on this. THANKS.
Yogesh Kumar
Sep 11, 2010 | Cell Phones
All Incoming Calls Show As Private Number
First thing : the person who's calling you have CLIR . Don't put the same number to phone & SIM. Use the phone memory and also save numbers in international format.
Jul 12, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Plugged my cordless GE phone into phone jack "A"
You dont owe me anything dear.
If your phone is working properly. Charging, incoming call and outbound are ok then you are safe.
Blinking light is called heart beat. It tells you that system is working. Let us know if you need something else
Have a great evening.
Vit
Jun 21, 2009 | GE 27998GE6 Cordless Phone
Nortel M7310 Phone moved to another jack, now no incoming calls
you need to go to your previous location and get the jack number, than go to the new location and get the jack number. now go to the phone system closet and look for these cable numbers on the 66 blocks. Swap the cross connect of the jacks and wallah your phone will be your s again! ldtnsj.com
Jan 20, 2009 | NorStar M7310 Corded Phone
Can't receive incoming faxes!
It sounds like maybe the printer is not picking up the incoming call. Check to see that the printer is the first thing connected to the phone jack. If you have DSL you will need to plug the printer into the "phone" side of the DSL filters that you have on all your phone jacks.
If you have an answering machine it should be plugged into the printer's phone jack - not the other way around. The printer is smart enough to pick up fax calls and pass voice calls on to the answering machine if you get it hooked up right. Check the user's guide for more specifics.
Oct 15, 2007 | Lexmark X5470 All-In-One InkJet Printer
Olympia InfoGlobe Caller ID Logo
59 people viewed this question
Top Olympia Lands Phones Experts
Computer Repairing
Computer Repairing
ray gallant
Jose Ma DM.
Jose Ma DM.
Are you an Olympia Lands Phone Expert? Answer questions, earn points and help others
