Question about Fahrenheat (FFH1614) Wall Mounted Panel Heater
Wiring my 240 V wall mount heater
Do I use 2 wire (with ground) or 3 wire (with ground)?  If 3 wire, what do I do with the white wire?
  • 1 more comment
  • Trav07 Aug 10, 2008
    I want to know how to connect a 240 volt wall heater to service panel with a GFI breaker?
  • david mcknelly
    david mcknelly Dec 27, 2008
    there is a red and black wire to connect to inside heater coming into heater is 4 wires 1 copper ground 1 red 1 blck 1 white what goes where/ thank you
  • jemjr Feb 26, 2009
    I have a 240 volt wall mount heater drawing 16.7 amps. I'm assuming a double 20 amp breaker is okay to use for this. i have a red and black wire on the heater to hook to my incoming wire of 10/2. I think I use my incoming black and white wires as two common wires off of the double breaker and the ground as a ground with no neutral wire am I right.
    Sergeant:
  • 288 Answers
Your question is kind of vague, but the 240v goes to the heating element, if the heater has a fan, it may be a 110v, so the white is common and should be wired as such. The heater should have a wiring diagram on it.
Posted on Nov 05, 2007
Hello Fixya Guru ! I am in the process of installing several Marley PLF series 2000 watt/ 240 volt electric "Hydronic" baseboard heaters. I am using 10/3 bx with a 30amp breaker. To my...
You are correct that these heaters use a two-wire 240 volt supply, and the neutral is not needed.
2000 watts = 240 volt x Amps ==> Amps = 8.3 amps
30 amps x .8 safety factor = 24 amps
24 amps / 8.3 amps = 2.9 heaters per 30 amp breaker (3 heaters should be okay)
More info, pls let me know.
Charlie
P.S. Where does the 2880-watt number come from ?
P.P.S. There has to be a ground bus-bar in the panel -- if it's a main panel (not a sub-panel) the ground buss and the neutral buss are connected in the panel. Could you clarify what you have in the panel.
Jan 11, 2011 | Fahrenheat Electric Convector Baseboard...
I am trying to replace a electric baseboard heater that is 220 volts and I am unsure about the wiring. the heater has a red and black wire and there is a white and black wire coming out of the wall.How do...
if ur are replacing the heater and it was originally 220/240 ur wiring should b ok but to b sure trace the line wire back to breaker panel and look at breaker the white and the black should b hooked up to separate breakers if the white is hooked up to a ground bar usually on the inside side of the panel and the black hooked up to breaker ur line is 110/120 and will cause problems when hooked up. if the lines r 220/240 than red can hook up to white and black to black
Sep 25, 2009 | QMark FBE15002 electric baseboard heater...
How to hard wire 240 volt wall heater
Black is 120v hot
Red is 120v hot
Black and Red go to opposite legs to get 240v between them.
White is 0v neutral
copper is Ground
Dec 27, 2008 | Fahrenheat (FFH1614) Wall Mounted Panel...
How do I wire a federal pioneer wall heater 240v with 2 wires there appears to be only 2 load wires to attach to and a bare ground where does a neutral conect to? Thanks Ross
If you are certain that the heater has only two wires and that it is a 240 volt unit, here's what you do:
Bring in a 240 volt line.  There are three wires.  The red and black are the opposite phases and are each 120 volts above ground/neutral.  Connect them to the load wires.  If there is a neutral, connect that to the white wire, even if it is bare wire.  Bare wire and white are the same for all practical purposes.  If the unit has a fan, it will run on the neutral/white and one of the phases. Wire sizing is important.  Make sure you have a properly sized wire for the job Up to 20 Amps, use #12 wire.  If over 20 Amps rated, use #10.  Fuse appropriately.
Make sure the power is off when doing this work!  240 will KILL YOU.
Nov 22, 2008 | Heating & Cooling
Instalation
First this diy stuff with electricity is scary. You describe the wiring as 3 wire 110, I understand the heater to be 240, the heat side of what? The heat side you say you only had the ground and a red.
You have to be more clear about the heater connections, what voltage, what amperage, what number of conductors you have, what distance to the breaker, what the breaker size is, and much more to do this correctly. As to it being wired with 12/2 that is possible if it were 110 volt and required that much amperage capability, along with a chassis ground, making the wire 12/2 with ground, but that is not 240 that is 120 volt.
Write me at wbwill@sbcglobal.net or look me up at allexperts.com and we will go from there.
But wiring up heaters when there are this many questions is leaving a huge chance for something to go wrong.
Write me back or hire an electrician, one way or the other, it needs to be safe, tested, and checked when completed.
Will or wbwill
Oct 06, 2008 | Fahrenheat Electric Convector Baseboard...
How to wire 1 plf 1504d heater
I have the solution, finally after looking for 2 days.
First off, I couldn't quite put it all together based on what I was reading. I finally tracked down the Fahrenheat web site (www.fahrenheatpro.com). And called tech support (800) 452-4179.
To wire 2 BB units to 1 tstat.
1. Use #14 wire for 0-12 amps, #12 wire for 12.1 to 16 amps and #10 wire for 16.1 to 24 amps.
2. I have a 12/2 wire going from the tstat to BB#1 and another 12/2 wire going from BB1 to BB2.
3. Onthe left side of the heater, you will have 2 sets of black wires tied together with a nut (on right side it's 2 sets of Black/Red wires). You can use either side of the heater. For the purpose of explaining this, lets use the left side, 2 sets of black wires.
4. Undo one of the sets of black wires (it doesn't matter witch), the other set will be left alone.
5. Take the black wire coming from the tstat and tie it into one of the black wires from the heater and the black wire going to the second BB unit. So you will have those 3 wires tied together with a nut at the 1st BB unit.
6. Take the white wire coming from the tstat and tie it into the other black wire from the heater and the white wire going to the other BB heater. Again, you will have 3 wire tied together here.
7. At the second BB unit, tie the black wire coming from the 1st unit to one of the black wires in one of those 2 sets of black wires. Again, only undo 1 set of wires at the 2nd unit, leave the other one alone. Tie the white wire coming from the 1st unit to the other black wire.
8. Make sure ground wire in grounded at the tstat and at both BB units.
Hope this helps...... If I was less clear than I hoped, call tech support and they will walk you thru it....
Kevin.
Dec 08, 2007 | Fahrenheat Electric Convector Baseboard...
Connecting 240 volt singer baseboard heater
Need front grill for singer model WJA-12 wall heater Cat # 9756-A
single phase 60 HZ
240 volts 5.2 Amps
1250 Watts
Where can I find it?
Nov 28, 2007 | Heating & Cooling
Cadet wall mount and thermostat
your wiring is all wrong. for a 240 heater a 20/20 tandem breaker will not work with a 240 heater. you need a 20 amp two pole breaker. the two wires at the heater need to be connected to the line. you probably have two black wires at the heater. one connects to the white romex which should be taped black, and the other romex black connects to the other black wire. at the panel one white goes to one side of the breaker and the black to the other. the bare ground goes to the neutral bar.
Oct 27, 2007 | Cadet Manufacturing 67507 Heater
Install and hot wire heater
You can be assured that the element is 240 volt. The fan motor is also rated at 240 volt. the wires you have black - black are the connections you make to the line. Use a 12/2 with ground. Use a double pole 20 breaker in your panelbox. The green wire is the equipment ground - connect this to the bare wire from the 12/2. On the 12/2 cable - there will be two colors, one black and one white. Wrap a couple of turns of black tape on the white wire both at the heater location and on the white in the panelbox. connect the 12/2 to your 2 pole breaker, the black wire and the taped white to the breaker.
Sep 05, 2007 | Fahrenheat FFH1615 Heater
Fahrenheat (FFH1614) Wall Mounted Panel Heater Logo
1,966 people viewed this question
Top Fahrenheat Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
