Question about Harley Davidson 2007 HarleyDavidson FLHTCU Ultra Classic Electra Glide in Olive Pearl and Vivid Black
PN 68924-07 Help with reading code
Please help me
Write the codes down. Then erase them. read the codes that come right back, before you start the car. If the U codes come back, these have to be addressed before anything else. Communication codes. If not, Drive the car for about fifteen minutes and read the codes again. These codes have to addressed first. One code left on over time can cause other codes.
Sep 01, 2016 | Nissan Cars & Trucks
Engine fault light
read the code and we will help you. there's a mothod of reading toyota codes by use of a bulb tester by connecting it to the obd terminals. when you hit the correct one the engine light will start blinking. read the code: Good luck
Aug 21, 2014 | 2007 Toyota Quantum 2.7
How do i reset or find code for check engine light where is the the computer connection inside car
ODBC-2 code reader is used to read the codes and reset the codes once read. This web site will help you troubleshoot the codes http://www.obd-codes.com/trouble_codes . The reader can be purchased for usually less than paying a auto mechanic to read the codes and perform the reset. The plug to read the codes is usually under the driver side dash. If you lay down on the ground you will see it. ODBC-2 reader are sold at every auto parts store and are easy to use.
May 01, 2014 | 2006 Buick LaCrosse
I have a message (air condition no connected)in my car LEXUS VG 470 v8 model 2006 and i can't read the trouble code with scan tool please help
You need a professional scan tool to read
body codes & the correct software
for asian vehicles, as well as enhanced data
Mar 08, 2013 | Cars & Trucks
The service air bag light just came on how can I fix
hi, it means your car has the obd2 code problem, you need a scan tool to read out and clear the code. when my car has this problem, I use this tool to check the code, and it is helpful, hope help.
but it need to do with the gm tech2. or you can take your car to the repair shop, they will help you read out the code. hope help.
Jul 01, 2011 | 2004 Cadillac Escalade
FMS AUDIO, SY712, MODEL 14787220, READS CODE ERROR. I DO NOT HAVE THE CODE. CAN YOU HELP?
FMS AUDIO, SY712, MODEL code 14787220,SERIAL NO :0094264 READS CODE ERROR. I DO NOT HAVE THE CODE. CAN YOU HELP?
Oct 23, 2010 | 1990 Nissan Hardbody King Cab
I have problem with code 1126 (toyota 4 runner 2001
Manufacturer Specific Codes
P1100
BARO Sensor Circuit - Read Our Article on Automotive Circuit Testing For Help With This Toyota Check Engine Light Code
P1120 Accelerator Pedal Position Sensor Circuit - Read Our Article on Automotive Circuit Testing For Help With This Toyota Check Engine Light Code
P1121 Accelerator Pedal Position Sensor Range/Performance Problem
P1125 Throttle Control Motor Circuit - Read Our Article on Automotive Circuit Testing For Help With This Toyota Check Engine Light Code
P1126 Magnetic Clutch Circuit
P1127 ETCS Actuator Power Source Circuit
P1128 Throttle Control Motor Lock
P1129 Electric Throttle Control System
P1130 Air/Fuel Sensor Circuit Range/Performance (Bank 1 Sensor 1) - Read Our Article On Oxygen Sensor Codes For Help With This Toyota Check Engine Light Code - More Related Information
P1133 Air/Fuel Sensor Circuit Response (Bank 1 Sensor 1) - Read Our Article On Oxygen Sensor Codes For Help With This Toyota Check Engine Light Code
P1135 Air/Fuel Sensor Heater Circuit Response (Bank 1 Sensor 1) - Read Our Article On Oxygen Sensor Codes For Help With This Toyota Check Engine Light Code - More Related Information
P1150 Air/Fuel Sensor Circuit Range/Performance (Bank 1 Sensor 2)
P1153 Air/Fuel Sensor Circuit Response (Bank 1 Sensor 2) - Read Our Article On Oxygen Sensor Codes For Help With This Toyota Check Engine Light Code
P1155 Air/Fuel Sensor Heater Circuit. (Bank 1 Sensor 2)
P1200 Fuel Pump Relay Circuit
P1300 Igniter Circuit Malfunction - No. 1
P1305 Igniter Circuit Malfunction - No. 2
P1335 No Crankshaft Position Sensor Signal - Engine Running
P1349 VVT System
P1400 Sub-Throttle Position Sensor
P1401 Sub-Throttle Position Sensor Range/Performance Problem
P1405 Turbo Pressure Sensor Circuit
P1406 Turbo Pressure Sensor Range/Performance Problem
P1410 EGR Valve Position Sensor Circuit Malfunction - Read Our Article on EGR Valve Codes For Help With This Toyota Check Engine Light Code
P1411 EGR Valve Position Sensor Circuit Range/Performance - Read Our Article on EGR Valve Codes For Help With This Toyota Check Engine Light Code
P1500 Starter Signal Circuit
P1510 Boost Pressure Control Circuit
P1511 Boost Pressure Low
P1512 Boost Pressure High
P1520 Stop Lamp Switch Signal Malfunction
P1565 Cruise Control Main Switch Circuit
P1600 ECM BATT Malfunction
P1605 Knock Control CPU
P1630 Traction Control System
P1633 ECM
P1652 Idle Air Control Valve Control Circuit
P1656 OCV Circuit
P1658 Wastegate Valve Control Circuit
P1661 EGR Circuit
P1662 EGR Bypass Valve Control Circuit
P1700 Vehicle Speed Sensor '2' Circuit Fault
P1705 Direct Clutch Speed Circuit Fault
P1765 Linear Shift Solenoid Circuit Fault
P1780 Park/Neutral Position Switch Malfunction (Only For A/T)
Back To Top Of Toyota Check Engine Light Codes Page
Mar 21, 2009 | 2002 Toyota 4Runner
Codes for 1995 Mitsubishi eclipse
Engine-light-help.com
P1100 Induction Control Motor Position Sensor Fault
P1101 Traction Control Vacuum Solenoid Circuit Fault - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1102 Traction Control Ventilation Solenoid Circuit Fault - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1103 Turbocharger Wastegate Actuator
P1104 Turbocharger Wastegate Solenoid
P1105 Fuel Pressure Solenoid
P1294 Target Idle Speed Not Reached
P1295 No 5 Volt Supply To TP Sensor
P1296 No 5 Volt Supply To MAP Sensor
P1297 No Charge In MAP From Start To Run
P1300 Ignition Timing Adjustment Circuit - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1390 Timing Belt Skipped One Tooth Or More
P1391 Intermittent Loss Of CMP Or CKP Sensor Signals - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1400 Manifold Differential Pressure Sensor Circuit - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1443 EVAP Purge Control Solenoid '2' Circuit Fault
P1486 EVAP Leak Monitor Pinched Hose Detected
P1487 High Speed Radiator Fan Control Relay Circuit Fault - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1489 High Speed Condenser Fan Control Relay Fault - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1490 Low Speed Fan Control Relay Fault
P1492 Battery Temperature Sensor High Voltage
P1494 EVAP Ventilation Switch Or Mechanical Fault
P1495 EVAP Ventilation Solenoid Circuit Fault
P1496 5 Volt Supply Output Too Low
P1500 Alternator FR Terminal Circuit - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1600 Serial Communication Link
P1696 PCM Failure EEPROM Write Denied
P1698 No CCD Messages From TCM
P1715 Pulse Generator Assembly
P1750 Solenoid Assembly
P1791 PCM ECT Level Signal To TCM Circuit Fault
P1899 P/N Position/Transaxle Range Switch Circuit Fault - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1751 A/T Control Relay
P1791 Engine Coolant Temperature Level Input Circuit - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1795 Throttle Position Input Circuit To TCM - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
Mar 21, 2009 | 1995 Mitsubishi Eclipse
Hi, i want buy a ship (short money) code reader from ebay that reads Mitsubishi colt 1.6 glx 1997, and possivel more japonese cars, any idea? They all say that reads but i hve one (Vag405) and dont read...
Hi...
I'm a Mechanic.
And I Have Solus from Snapon. on My shop.
But I have Tried a lot Of OBDII code reader.
For me On my own OPINION. I say one of the better is AUTOXRAY.
With this Scanner you can Read Codes, Live Data. Freeze Frame, Pending codes,
And Clear the CODES.
This Kind of Scanners support, MB, BMW, AUDI VW, , All the Imports, from 1996 up to date.
Domestic From 1982 up to date. GM, FORD, Chrysler , Saturn.
Ok.. I hope this help on your question.
Thank you for use fixya.
Sep 18, 2008 | Mitsubishi Colt Cars & Trucks
Lost my security code
you need software to read your codes.. go to your nearest center to read your codes... here's what they gotta do.. put the cables on ur fone, run the soft and read informations in to your fone... and there they will see your codes...
Apr 14, 2008 | Nokia 6103 Cellular Phone
Harley Davidson 2007 HarleyDavidson FLHTCU Ultra Classic Electra Glide in Olive Pearl and Vivid Black Logo
599 people viewed this question
Top Harley Davidson Toys Experts
ray gallant
Mark McGinty
Mark McGinty
Charles Ma
Charles Ma
Are you a Harley Davidson Toy Expert? Answer questions, earn points and help others
