Question about Fuji FinePix Cameras
Date & time on 2012 and not seting as per manual if I'm doing it right
Bateries were low haven't been concerned with date and time till now and I have tried to set it as the way I understand it in book but it wants to flip other displays with I push left or right or up or down, Tried taking batteries out and card and waiting for long time and starting over but had no luck It shows the old time and date in the right corner real small in red and white highlighted in white but flips off when I press selector right or left that's about all I know now thanks for any help you can offer
SOURCE: Won't take pictures
The flashing F-- is addressed on page 123 of your users manual. My camera was also doing that and it was very frustrating. The lens is not being read by the camera. Try cleaning the contacts in the lens and camera body. In my case I had dropped my camera from a very short distance, but it was enough to make the lens not seat right in the body. Have to buy a new lens. Go to a camera shop and switch out the lens and see if it works...mine did. Problem solved.
Posted on Jun 04, 2007
SOURCE: Unable to open the flip to insert batteries as well memory card
Push release button then move the battery cover to the right to release the cover. Don't pry straight up.
Posted on Dec 23, 2007
SOURCE: date/time imprint. Coolpix 2100
To remove date imprint. This is the solution provided by Nikon more than a year ago. Switch on> set to green>menu>scroll down to Date Imprint.press centre/right on multi selector>select 'off.' Job done
Posted on May 01, 2008
SOURCE: when I press the shutter button I can hear the
Does your blue print light come on? The blue light is just right of the menu button.
Posted on Feb 07, 2010
t00nz
  • 4738 Answers
SOURCE: I have a Canon Powershot A560. The date and time
Think your problem is that you are looking in the wrong spot. Don't know why your manual is telling you to look there (are you sure your manual is for the A560)?
Your CR1220 date/time battery is located in the regular battery compartment. Look right beside your AA batteries. You'll see a little flap labeled "CR1220". Slide this open with your fingernail, and take the little coin battery down to your local drugstore to buy a replacement.
Posted on Oct 07, 2010
Seting time and date on answering machine of cordless phone
Now that you've finally gotten around to specifying the model of your phone, follow the instruction on page 14 of the CS6429-3 manual.
Sep 14, 2012 | Vtech Lands Phones
How do you set time and date on schiller at2 ekg machine
HI,
To set time on the schiller AT2 do the following.
1. Power ON the machine.
2. Press the following key sequence ALT,9,1,1.
3 Now enter the time using the digit key (HHMMSS)
You will hear the conformation beep indicating that the time is seted.
To set the date on schiller AT2 Do the following.
1. Press the following key sequence ALT ,9,2,2.
2. Enter the date using the digit key (DDMMYY)
You will hear a conformation beep indicating that the date is seted.
ok
Sep 08, 2011 | Schiller Welch Allyn Cardiovit At 2...
My hp compaq nx6120 has password in bios so i cannot upgrade it in windows 7 os someone can help me
Disconnect the cmos battery (remove clock batery out) wait and insert back the batery... p.s. Bios setings setting becomes the default date and time so the same ... Then you come into the system bios and adjust its settings and the date and EnJoy 16x16_smiley-happy.gif
Aug 17, 2011 | Computers & Internet
Do you have directions for armitron mens pro sport watch 49/1000
Hi robinmsavage,
I will be glad to help you with your concern regarding your Armitron Wristwatch, what exactly would you be experiencing? cause I only put info on how to set time and date on the Watch.
Please see below steps:
  • Your Armitron Watch will have Four Button on the side of the watches rim.
  • Button on the upper Left is MODE.
  • Button on the lower Left is LIGHT.
  • Button on the upper right is DATE.
  • Button on the lower right is Alarm.
See Steps below:
*Setting the time*
  • Press and Hold down the Mode Button til the Hours flash
  • Then push Alarm Button to set the Hours
  • Press and Hold down the Date Button till the Minutes flash, then push Alarm Button to set the minutes
  • After setting the minutes on your watch, Press Date till you get the month flashing push Alarm to set the month
  • Press the Date again till the Date flashes, then push Alarm to set date
  • Press the Date again till the Date on your watch flashes, then push Alarm to set the date
  • After setting everything push the Mode Button again just once to set everything or finalize your settings on the watch.
I hope that this will be of help regarding your query on how to set the time on your Armitron watch, I also included the setting of the time and date just for further details.
Thank you for choosing Fixya,
mvincentc
Apr 21, 2011 | Armitron Chronograph Sport #204345BKBK...
Have 2005 lincoln aviator - has miss at 30-55 MPH - no codes replaced all coils ( ford) & spark plugs (twice) - repair vacuum leak at PCV Still misses -- no codes -- help
The COPS (coils) may have shorted the drivers in the PCM (computer). You should get a misfire code for each cylinder misfiring though.
Slim possibility, but very expensive unless you have a service contract.
LINCOLN: 1999-2004 Navigator
2002-2003 Blackwood
2003-2005 Aviator MERCURY: 2003-2004 Marauder
ISSUE: Some 1999-2004 Navigator, 2002-2003 Blackwood, 2003-2005 Aviator, 2003-2004 Marauder and 2003-2004 Mustang vehicles built before 12/19/2004 equipped with 4.6L 4V/5.4 4V engine may exhibit a runs rough, lacks power, and engine misfire, prompted by a MIL light and DTC codes P0301, P0302, P0303, P0304, P0305, P0306, P0307, P0308, and P0316.
ACTION: Diagnose engine for engine misfire concern. If diagnostics determine an engine misfire which is characterized by leakage through exhaust valve(s), only replace the affected cylinder head(s).
SERVICE PROCEDURE FOR VEHICLES WITH RUNS ROUGH/MISFIRE CONDITION:
  1. Perform relative compression check on all cylinders. If abnormal, check cylinder leakage and actual compression for "low" cylinders refer to Workshop Manual (WSM), Section 303-00.
  2. If leakage/compression check indicates a valve train concern, per valve train diagnostics in WSM, Section 303-00, replace cylinder head and cam assembly, pipe plugs and timing chain tensioner, per procedure outlined in WSM, Section 303-01.
  3. If cylinder leakage and compression tests are inconclusive, perform misfire diagnostic, per TSB 05-22-8. NOTE: DO NOT TRANSFER SPARK PLUGS. INSTALL NEW SPARK PLUGS IN REPLACEMENT CYLINDER HEAD AND CAM ASSEMBLY. NOTE: THE ENGINE MISFIRE CONCERN IS TYPICALLY EXHIBITED ON THE LEFT HAND CYLINDER HEAD AND RARELY ON THE RIGHT HAND CYLINDER HEAD. UNLESS CONFIRMED, THE RIGHT HAND CYLINDER HEAD SHOULD NOT BE REPLACED AS AN "EXTRA MEASURE" SERVICE PRECAUTION. NOTE: THE REPLACEMENT CYLINDER HEAD WILL NOT IMPROVE OR REDUCE ENGINE HORSEPOWER OR TORQUE ABOVE ADVERTISED LEVELS.
Sep 24, 2010 | 2003 Lincoln Aviator
I lost my book,,,,, how to set date/time on answering machine?
keep on pushing the setings botten till it says time and date
Feb 27, 2010 | GE 25942GE2 Cordless Phone System
My desktop compaq sent me a message stating that the time & date is not set and may b a result of a loss in batery power, ask m to correct date and time and if mesage persists I have to replace the...
you need to replace your cmos battery, you need to open up the casing of your computer. you need to look for the coin cell battery on the motherboard, there shoulb only 1 there, so you cant miss...
Feb 17, 2010 | HP Compaq Business d530 PC Desktop
How do you change the date and time
Please go inside the camera setting press my MENU botton. the scrool up/down, then select date & time , fix it up as per your date & time then save.
After that your carema show you the latest date & time as per your setting. Thanks & waiting for your feed back.
Feb 04, 2010 | Nikon D70s Digital Camera
Cameras Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
