Question about Royal Alpha 9500ml Cash Register
Function values not set
After typing in the price, press a department key and function value not set error appeared
How to solution services call m1 for Konica Minolta 164
11.5.4 MAINTENANCE COUNT.
A. Use
• To display the count of the maintenance counter.
• When the counter reaches "0", maintenance call M1 or the service call will appear, according to the setting on MAINTENANCE COUNT. of SERVICE'S CHOISE.
See P.85 below
e
• To enter an appropriate counter value (0 to 999999) as the tentative maintenance time.
• Specify the setting on maintenance counter to "1" or "2": If the maintenance life is
reached, the maintenance call (M1) or service call [Call Service (M1)] will appear.
"0" : Not counted
1 : Counted (The maintenance call display is given when the counter reaches 0.)
2 : Counted (The service call display is given and the initiation of any new copy cycle
is inhibited when the counter reaches 0.)
NOTE
• The counter value is decremented until it reaches -999999 even after it has
counted 0.
B. Procedure
• The default setting is 0.
• When "1" or "2" is selected, a screen will then appear to allow the counter value to be
entered.
• To clear the count, use [CLEAR DATA] of the SERVICE MODE.
Procedure below to enter::
11.2.1 Starting procedure
1. Press the Menu/Select key.
2. Press the following keys in this order.
Quick Settings Quick Settings left arrow twice the right arrow then left arrow
11.2.2 Exiting procedure
• Press the Back/Stop/Reset key as many times as it is required to display the initial
screen.
11.2.3 Changing the setting value in SERVICE MODE functions
1. Select the desired item using [??/??/??/??] key.
2. Select the setting value using [??/??/??/??] key.
3. Validate the selection by pressing the Menu/Select key.
4. To go back to previous screen, press the Back/Stop/Reset key.
Sep 29, 2016 | Konica Minolta Office Equipment & Supplies
My MS Excel vlookup function ASCII type table contains both upper case and lower case letters, characters like ( and % or *, and numbers. It seems to return the numerical equivalent of upper case letters...
Correct a #N/A error blueup_clv.gifShow All bluedrop_clv.gifHide All This error occurs when a value is not available to a function or formula.
  1. Optionally, click the cell that displays the error, click the button that appears ooui1_za06043871.gif, and then click Show Calculation Steps if it appears.
  2. Review the following possible causes and solutions. blueup_clv.gifMissing data, and #N/A or NA() has been entered in its place
    Replace #N/A with new data.
    Note You can enter #N/A in those cells where data is not yet available. Formulas that refer to those cells will then return #N/A instead of attempting to calculate a value.
    blueup_clv.gifGiving an inappropriate value for the lookup_value argument in the HLOOKUP, LOOKUP, MATCH, or VLOOKUP worksheet function
    Make sure that the lookup_value argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) is the correct type of value — for example, a value or a cell reference, but not a range reference. blueup_clv.gifUsing the VLOOKUP, HLOOKUP, or MATCH worksheet function to locate a value in an unsorted table
    By default, functions that look up information in tables must be sorted in ascending order. However, the VLOOKUP and HLOOKUP worksheet functions contain a range_lookup argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) that instructs the function to find an exact match even if the table is not sorted. To find an exact match, set the range_lookup argument to FALSE. The MATCH worksheet function contains a match_type argument that specifies the order the list must be sorted in to find a match. If the function cannot find a match, try changing the match_type argument. To find an exact match, set the match_type argument to 0.
    blueup_clv.gifUsing an argument in an array formula that is not the same number of rows or columns as the range that contains the array formula
    If the array formula (array formula: A formula that performs multiple calculations on one or more sets of values, and then returns either a single result or multiple results. Array formulas are enclosed between braces { } and are entered by pressing CTRL+SHIFT+ENTER.) has been entered into multiple cells, make sure that the ranges referenced by the formula have the same number of rows and columns, or enter the array formula into fewer cells. For example, if the array formula has been entered into a range 15 rows high (C1:C15) and the formula refers to a range 10 rows high (A1:A10), the range C11:C15 will display #N/A. To correct this error, enter the formula into a smaller range (for example, C1:C10), or change the range to which the formula refers to the same number of rows (for example, A1:A15).
    blueup_clv.gifOmitting one or more required arguments from a built-in or custom worksheet function
    Enter all arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function.
    blueup_clv.gifUsing a custom worksheet function that is not available
    Make sure that the workbook that contains the worksheet function is open and the function is working properly.
    blueup_clv.gifRunning a macro that enters a function that returns #N/A
    Make sure that the arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function are correct and in the correct position.
Oct 31, 2008 | Computers & Internet
Error code cof32 & c0070 at bizhub 210 how con i fix it?
Solution for Error code C0F32
1-Turn the machine ON. 2-Press "Utility" button on front panel.
3-Now press these buttons "stop+0+0+stop+0+1" it means press stop button, then press 0,again 0, then again press stop button, then press 0, and 1.
4-service mode will appear on LCD screen.
5-Now with the help of arrow keys go to the 2nd option which is "ADJUST"
6-Now press "YES" button.
7-Again by pressing the down side arrow key go the option which is "ATDC ADJUST".
8-Press YES button.
9-Now increase the value, for example if the value is 145, you have to enter 155 or 160.enter the value with numerical key pad buttons.
10-After entering the new value press "YES" button.
Error Code C0070
Solution:
1- Open the front door and bring the bottle out.Now restart the machine.if the code appears then open the toner hopper section.Toner hopper drive motor is not working, Dis mental the hopper section.
Jan 27, 2014 | Toshiba E-Studio167 Copier
Tengo una konica minolta di183f que me pide
Enter in the service mode:
Press the following keys in this order to enter the service mode:
UTILITY,STOP(red button),0,0,STOP,0,1.Enter in COUNTER menu,select maintenance counter,select the setting value using the Left or Right key.Press the Yes key.When 1 or 2 is selected for the setting value,the count value entry screen automatically appears.Type the count value from the 10-key pad.Press the Yes key.
Setting value = 0 - meaning NO COUNT it is default value.
Setting value = 1 Meaning - PERMITS COPYING - Display "M1".
Setting value = 2 Meaning - INHIBITS COPYING - display "CALL SERVICE(M1)
Aug 18, 2012 | Office Equipment & Supplies
How do i programme prices on the casio SE-S300 till?
Turn key to Program 1 SUBTOTAL price (no decimal point) Item button SUBTOTAL
The Se-S300 manual can be found here: http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Jan 08, 2011 | Casio Parts Cash Register PC Desktop
Whenever i type in 2nd cos(1301.16) and press enter, it tells me that i have a domain error? how can i fix this?
The key sequence [2nd] [Cos] calls the function arcosine or cos^-1. However that function takes its values in the range of the cosine function which is the interval [-1,1].
As you can see, your value of 1301.16 is clearly outside the interval [-1,1].
Dec 15, 2010 | Texas Instruments TI-84 Plus Calculator
Error code C2557
Error code c2557 means "ATDC Sensor abnormality".
It appears due to following reasons,
1-Imaging unit (Drum unit) parts life is expired,
2-Developer's life is expired,.
3-Developer tank is hard, gears of the unit are not moving
For best results and smooth functioning of machine, simply call your technical services representative and he will help you in this matter.
OR
if you want to do it yourself, you have to do this.
1-Press "UTILITY/COUNTER' button on the machine's panel.
2-Now press "check details" button. (appeared on the lcd screen)
3-Now press these buttons,
STOP+0+0+STOP+0+1
4-now press "Tech representative choice" button on LCD screen.
5-now press "PRINTER" button.
6-press "ATDC GAIN"
7-Now press the "c" button to clear the value, after clearing the value enter new value by using numeric pad.
Enter new value by adding 10 to the previous value. For example if the previous value was 150 you have to enter 160 now or 165.
8-Enter the new value and press the End button on the LCD screen and exit.
9-Now restart the machine..
Nov 04, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Is there a way to search a table for a specific value of x or y on the TI-84 Plus. For example, if I graph a function and want to know the y value for this function is when x=1000, is there an easier way...
There are two ways you can do that.
Graphically:
Once the graph is drawn you can use the trace function b y pressing TRACE. With the right and left arrows you can move along the curve. The cursor will move by increments of Delta X, so some points you may be interested in may not appear.
To remedy the situation you can just type in a value of X that is inside the range Xmin , Xmax and press ENTER and the calculator will display the corresponding Y value. This will work only for points inside the interval Xmin, Xmax.
NUMERICALLY
To obtain Y-values outside the Xmin, Xmax interval you can use the fact that Y1, for example, is already defined, and ask the calculator to find a Y-value for you.
Say you want Y1 for X=1000.
  1. In main computer screen you type in 1000 [STO
Oct 05, 2010 | Texas Instruments TI-84 Plus Calculator
Percenteg Function problem in my Casio MJ - 120 Model Calculator
I found it by myself, I can help you.
1. Press (AC)
2. Hold (Rate) for about 2-3 second
3. Press (Set / TAX+)
4. Input the tax rate
5. Press (Set / TAX+)
6. Hold (Rate) for about 2-3 second again
7. Press (Set / TAX+) again
And Then you can test the rate .
From Thailand
Mar 12, 2009 | Casio Office Equipment & Supplies
How to programme tax rate on casio MS-8T
hold down rate set/% key until the current value appears then type in the new value and press rate set/% key again
Apr 14, 2008 | Office Equipment & Supplies
Royal Alpha 9500ml Cash Register Logo
Top Royal Retail Supplies Experts
Patrick Tinashe...
Electroboy
Electroboy
_-__-___-_
_-__-___-_
Are you a Royal Retail Supply Expert? Answer questions, earn points and help others
