Question about Bodum 11451-294US 17-Ounce Electric Water Kettle,
Bodum bistro kettle
Thumb button will not push in/stay pushed in. Light will not stay on. water will not boil. Replaced cut off resistor. I think the problem lies with the thermo switch. Do not know where to source a replacement.
2 Suggested Answers
brenda_scofi
SOURCE: Bodum kettle boils too long before automatic cut off.
Mine does the same and now the switch doesn't work at all. Bodum is replacing the whole kettle.
Posted on Nov 02, 2012
Water does not heat
PDF]Instructions for use (PDF) - Bodum
www.bodum.com/media/ifu/11001-01EURO.pdf
BodumCongratulations! You are the proud owner of a BISTRO pour over coffee machine fromBODUM®. Read through these instructions carefully before you use the
Aug 30, 2015 | Bodum Bistro Coffee Makers & Espresso...
Control lever does not remain depressed
Over manual use can damage the unit over time. There could be particles tucked under the latches, contacts, and other attachments. Clean the catch tray and turn the entire toaster over and shake it violently. If you have vacuum with air OUT and you can place the hose up to the slots, blow from both the top and bottom to push out debris.
Feb 27, 2014 | Bodum Bistro Toaster
Morphy richards 43960 kettle not boiling
I think it has died a natural death, kitty. Get a new one it will be cheaper than fixing this one.
Feb 11, 2014 | Morphy Richards Kitchen Appliances -...
No light, no water heating
The heating element may have failed.
Sep 11, 2012 | Braun WK200 Electronic Water Kettle...
Our kettle has started making a crackling noise when turned on now; thought it does boil the water, and there is no odd smell from it.
Our kettle start making the same noises and now no lights come on. i can spin it around the base and sometime it connects and work. i think it's an electrical issue of the base. i wonder if anybody knows if it's possible buy just that part, i would hate to buy new kettle just because of bad connection.
Jan 24, 2010 | Breville SK500XL Stainless Steel Cordless...
Brokem switch on bodum kettle,
The problem with your bodum kettle is not the switch but the fuse that is in the bottom of the kettle. Because you cannot stop the boiler even when it is empty, the boiler overheat and burn the fuse at the bottom. You must unscrew the 3 screws at the bottom part of the kettle (not the base), then unscrew a nut that retain the fuse in a gain to the base. cut the wires and replace the fuse by a new one (less than 2 dollars on ebay). You should not exceed the temperature of the fuse(172 C) as it will melt your boiler if there is no water. Thats why you have to put a fuse. This helps me resolve my button issue with my bodum kettle.
Jun 25, 2009 | Bodum Electric Kettle
On Off switch problem
Look under the kettle at the round circular connector in the bottom. Inside there is a small button that is depressed when the kettle is put on the base. If this is not pushed in far enough it will have problems.
The cause is that after some use the connector in the base plate collapses into the base by 1-2 mm This means the switch is not pushed in far enough.
My kettle had similar issues... I pulled the base plate apart (3 screws I think) and cut a round disk of plastic to lift the connector up by about 1-2mm and then reassembled the base.. No more issues
Jul 08, 2008 | Russell Hobbs RHOK3123 Cordless Electric...
Switches off before full boil
Nov 23, 2007 | Russell Hobbs RHOK3123 Cordless Electric...
Sediment in my electric tea kettle
it is very hard to get rid off ass the sediment comes from the tap water untill you boil the water you dont see this sediment and take it for granted that the water is clean but as soon as you put it in a electric kettle this sediment builds up on the element then it brakes off and floats around in the kettle most new kettles have a filter near the spout so when you pour the water out it traps it in the filter then this can be removed and cleaned but the sediment floating in the kettle is hard to get out you can clean the element and descale it and then just keep pouring water in and out of kettle till its all out but it will soon build up again there are two ways to stop sediment one is filter all the water before putting in kettle but this can be slow process so not worth doing or the best sollution is buy a kettle that has a filter by the spout of the kettle and clean this regularly hope this is some help to you............................................
Nov 17, 2007 | Bodum (5600-01USA) CURL Electric Kettle
Bodum 11451-294US 17-Ounce Electric Water Kettle, Logo
Top Bodum Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Bodum Kitchen Appliances - Other Expert? Answer questions, earn points and help others
