Question about Jumbo RC JUMBO HELICOPTER
Protocol turbo hawk
My helicopter won't lift off the ground. It just spins in circles. What should I do?
Spins to left, will not take off/lift?
GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC ...
www.amazon.com/Hercules-Unbreakable.../B00AAOJ...
Amazon.com, Inc.GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC Helicopter (Color ... you can remove the 8 or so screws that allow you to pull the fairing off, remove .... Also we purchased our helicopter from HobbyTron.com through Amazon and .... won't spin, so the entire helicopter spins, and doesn't generate enough lift to fly.
GYRO Nano Hercules Unbreakable 3.5 CH Electric RTF RC
Amazon.com, Inc.Nano Hercules Unbreakable Glow in the Dark 3.5CH RC Helicopter ... It can go forward, backward, up, down, left, right and hover. .... It worked for a few flights and now the copter will not fly off the ground. ... and ive had it for a year now and everytime I start it up and it takes lift off it starts to fly backwards but otherwise ok toy.
Hercules Unbreakable 3.5CH RC Helicopter - HobbyTron.com
Dec 26, 2015 | HobbyTron Nano Hercules Unbreakable 3.5CH...
Its spins around in circles
THE TAIL MOTOR IS NOT WORKING PROPERLY OR NOT AT ALL. YOU MAY NEED TO REPLACE IT
Dec 25, 2013 | Protocol Predator SB 3.5-Channel...
My green air hog helicopter is spinning on the ground, it won't lift and fly, how do I fix it?
There is a problem on the motor gear, check the underside where you could see a big gear that should spin when you try to lift the helicopter. Check both big gears if they rotate/spins.
Usually the problem is the small gear on the motor shaft that is not aligned to that big gear. Check on it and adjust the small gear of the motor.
Hope that copter flies high.
Thanks for asking FixYa!
Aug 09, 2011 | Air Hogs Havoc Heli Helicopters
My hawk talon v3 is doing everything fine except it wont come off of the ground the blades are spinning they are taking some wait off the ground but in all the helicopter stays down what can i do?
try taking the body off of the skeleton and cleaning the rotor cylinder, might be dirty or have some carpet/hair fibers keeping the blades from running at full speed even if the battery is fully charged
Jan 08, 2011 | Team International Hawk Talon V3 RC Indoor...
My airhogs hawk eye video camera helicopter want fly it just spins in circles
Right here is the support site. http://www.airhogs.com/#/need_help
This is the place to get help for Air Hogs.
They also have a "community" link which may do you some good too.
Dec 29, 2010 | Air Hogs Reflex Micro Helicopter
Hawk talon v3 wont get enough power to lift off the ground after being fully charged. another hawk talon v3 rear tail rutter wont spin to go forward. how do I fix these problems in these two...
I too had the lift-off prolem and I fixed it by gently pushed the upper gear all the way up, using a nail through the bottom of the copter and a hole in the lower gear, while pushing the lower rotor down.
Dec 29, 2010 | Team International Hawk Talon V3 RC Indoor...
My 9053 volitation wont lift ground, i checked top blade it's not loose from metal shaft, it also wants to spin heavy to the right in circles. I just it so I'm learning
Had a similar model lasted 10 mins i broke this little plactic holder that seperates the blades i bent it the slightist bit and boom never flew again
Oct 16, 2010 | xheli 9053 Outdoor Volitation Metal...
Helicopter keeps spinning in circles and won't lift.
There is a "trim button" on the controller. Ex: if the helicopter is spinning left, press the "R" trim button repeatedly. Takes a little practice to get it down to flying with out hitting anything. Good luck.
May 17, 2009 | Spinmaster Air Hogs RC Reflex Micro...
Jumbo RC JUMBO HELICOPTER Logo
Top Jumbo Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Jumbo Toy Expert? Answer questions, earn points and help others
