Maytag mav39 How do I get the top off of My May tag mav-39?
5 Suggested Answers
ngafm
  • 166 Answers
SOURCE: MAYTAG TOP LOADER BARREL NOT SPINNING
Peace,
ngafm at your service,
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
* The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
* The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
* A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
* The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
* The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
* The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
* The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up."
Please give me a rating before you sign off!
Posted on Sep 05, 2008
  • 942 Answers
SOURCE: how do i remove the drum on a maytag top-loading
If you want to remove the drum of your maytag wahser follow this procedure:
  1. Disconnect the power supply to the Maytag dryer by unplugging it from the wall outlet.
  2. Use a screwdriver to remove the three screws located at the top of the control console.
  3. Pull the control console forward to release the tabs that hold it to the Maytag dryer top. Maneuver the control panel out of your way without disconnecting any wires.
  4. Use a putty knife inserted between the top and front panel to disengage the retaining clips that secure the top panel of the Maytag dryer. Lift the top panel up, and remove it from the dryer.
  5. Use needle nose pliers to remove the wires from the door switch terminals. The door switch is located just inside the front right corner. Grasp the wire leads with the pliers and pull them off the terminals.
  6. Use a screwdriver to remove the retaining screws that hold the front and side panels together on the Maytag dryer. Lift the front panel up and out of the work area.
  7. Use a screwdriver to remove the Maytag dryer drum light lens screw. Press the locking tabs on the light socket, and remove it from the cavity of the drum.
  8. Use a socket wrench to remove the four retaining bolts that secure the drum bulkhead to the sides of the Maytag dryer.
  9. Reach your hand beside the drum and the motor, and push the idler pulley forward to release tension on the belt. Make notes of how the belt is routed on the pulleys, and then remove the belt from the motor pulley and idler pulley.
  10. Grab the belt with one hand, and the Maytag dryer drum with the other. Pull the drum out of the front of the dryer.
Posted on Jan 30, 2010
SOURCE: Maytag MAV 9600 grinding noise/no agitation. Tub
I had a problem similar to this. There was a bobbie (?) pin stuck in the pump. Google how to take the front off and then disassemble the pump. (It will be on the bottom right side in the front of the machine). Pretty simple. Took about an hour and a half.
Posted on Feb 03, 2010
ginko
  • 19396 Answers
SOURCE: I have removed the 4
Hi.
The 5/16-18 x 1/2 inch screws indicated with nrs. 19 and 15 in diagram below are bolted on the part nr 14. Click on the diagram below to enlarge.
Posted on Jul 18, 2011
How to control water levels in Maytag TOP LOAD WASHER, model #MAV 6000 AWW
What is the problem?
Water level is automatically controlled based on what you set it to low, med, or high.
Jul 14, 2017 | Maytag Washing Machines
Maytag mav-1 doent spin
What does it do when it gets to the spin cycle?
Nov 29, 2012 | Maytag Atlantis MAV6451 Top Load Washer
Hi, I have a Maytag Alantis Washer (model: MAV
Does it not spin just in the final cycle or not at all during the wash cycle? Also, does the wash cycle agitate normal?
Regards,Richard
Nov 07, 2011 | Maytag Washing Machines
I want to delete my messages in tagged
When you load your inbox screen in Tagged, there are check boxes to the left of each message.
Tick any indivial boxes you wish to delete, the scroll the the very bottom of the page and click "Delete Checke" link.
Note: If you wish to delete all the visible message on that page, just tick the single check box at the very top of that column - this will 'auto check' the entire list.
Cheers
Oct 01, 2011 | tagged.com
How to replace a drive coupling on a maytag atlantis series mav 6300. I heard a loud cracking noise, then the washer stopped.
you will need a sevice manual go to appliancerepairplanet.vstore.ca it will show you how to do it
Dec 08, 2010 | Maytag MAV6300 Top Load Washer
sounds like a transmisson problem expensive to fix
May 17, 2009 | Maytag MAV9600 Top Load Washer
Maytag Mav-1 Slow Spin
hi thanks for the question with any washer if you use a hi sud zing detergent it really slows down the spin cycle check this just fill & drain 2or 3 times use some veniger try this thanks the appliance doc
Jul 17, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
