Question about iRobot Roomba 530 Robotic Vacuum
Fast blinking orange light - iRobot Roomba 530 Robotic Vacuum
Green light but won't start
Here is a video showing a quick temporary fix and the full fix showing the change of all the electrolytic capacitors.
Jun 14, 2014 | Neato 945-0041 XV-21 Robotic Vacuum...
Battery for Hoover Linx will not charge. Charger blinks very fast.
Jan,
your battery is Shorted. it is time to buy a new vac or a replacement battery.
sorry that is such a short hand answer but that is what the charger is telling you.
Apr 22, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
Garage door will not stay closed - one sensor is showing a green light and the other one is showing an orange light - i have tried to adjust position with no luck
When the two sensors are completely aligned, both sensor will show green lights. Usually the green light is your sending side and the orange/red side is the receiving side. You can measure the distance from the ground on the sending side and then adjust the receiver end to the same to get you in the general ball park and then fine tune it from there.
Jul 10, 2011 | Vacuums
When plugged in the hose light blinks
My spotbot lights would blink and it, for a time, only worked on deep clean even after unplugging and plugging back in. Finally it wouldn't work at all, only the hose light would blink. I unplugged the hose and plugged it back in and the machine started working as it should.
Apr 10, 2011 | Bissell SpotBot Robotic Wet/Dry Vacuum
The Orange "ON" indicator light
We need lots more info...oil won't heat ?...is this a vacuum cleaner ? Pop corn popper ? Oil filled radiator heater ? Company name...model number...anything ?? Help us help you. Thanks.
Nov 06, 2010 | Vacuums
Clean light blinks then solid orange button i bought a new battery dec
Remove the battery and hold the power button for 15 seconds. This will restart the charging cycle as if the battery were new. If after 72 hours, it stays orange your battery is either sub-standard voltage or not sold as advertised.
Feb 19, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
Battery not charging
Did you ever get an answer to your question on no power to your roomba? I purchased one for my parents off of craigslistthat was brand new; and has the same problem... charged for 16 hours - lite turned green - and no power! acmeremodel@cox.net Thanks
Dec 19, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Orange light is on
You may have a clog, which over heated the motor and it shut down. Clog could be in the hose, the dirt inlet by the brush roll and bag/filters. Some have a reset on the back, near the bottom. If not, then the over loard protector may have gone bad, could also have a motor problem.
Mar 22, 2008 | Royal Procision 7050 Bagged Upright Vacuum
Westinghouse Unplugged Vacuum Turns off after 5 Seconds.
If both batteries are behaving the same way then this is probably a charger problem. When you insert the battery pack into the charger does the 'charging' light blink for 30 minutes (fast charge) then go steady? I noticed that one of my batteries was causing the light to come on steady immediately I inserted it into the charger. When I tried to use the battery pack I got the same problem everyone else is seeing, i.e. vacuum cleaner shuts off in less than a minute, so I conclude that when the charging light is on steady then the battery is not being charged.
If the charging light does not blink when you insert the battery (i.e. comes on steady or not at all), try removing the battery and re-inserting it into the charger.
Try a conditioning cycle on your battery packs. To do this:
* Insert the battery pack into the charger
* Before the charging light lights press the 'condition' button located just above the charging light.
* The 'conditioning' light should blink. This is a light which does not normally illuminate, and it is located below the condition button and above the charging light. The charger fan will run quieter in this mode.
* Leave the battery pack in the charger for 24 hours while this cycle is taking place.
I'm not a service technician so perhaps someone else might like to post other solutions or corrections to this one.
Mar 07, 2008 | Vacuums
iRobot Roomba 530 Robotic Vacuum Logo
22 people viewed this question
Top iRobot Vacuums Experts
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
