Question about Samsung SL600 Digital Camera
Charger turns red green orange than shuts off
My charger flashes red/green and does not charge my scooter. Any suggestions?
hi the red led should not flash the green led should only come on when batteries r charged while charging the green led turns orange or yellow....can u borrow another charger just to check to c if its not the scooters charging circuit that is the problem..or the batteries ..good luck
Sep 19, 2015 | Health & Beauty
Flutterby fairy charge with charger blinking
STATUS LIGHT will FLASH RED when
charging. Allow at least 30 minutes
for a full charge.
STATUS LIGHT will turn ORANGE,
and then turn off when charging is
complete.
STATUS LIGHT will FLASH GREEN
when the batteries in the CHARGING
BASE are LOW. Replace the
batteries.
STATUS LIGHT will FLASH RED &
GREEN when there’s a CONNECTION
ERROR. Reconnect the FAIRY.
Jan 03, 2014 | Butterfly Toys
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
When charging my light stays red does that mean its charging
Some chargers have 2 LEDs (lights), some have one. Both chargers have an LED that is red (or orange) when the charger is charging a battery and turns green when the battery is charged and the charger has dropped back to trickle charge mode or off.
On the charger with two LEDs , the extra LED is normally red to indicate the mains power is connected.
Sep 10, 2013 | Razor MX500 Dirt Rocket
What to do when your vectron wave is blinking red and green at the same time while charging.
When you attach the charger the wrong way round it will flash red and green. Turn it around and it will just flash red. Then when charged it will go orange.
Dec 12, 2010 | Master Heaters Air Hogs Orange Vectron...
Just got this little dirt bike from a yard sale. Trying to figure out charging the battery. When I put the charger into the outlet, the little green light comes on. Then when I connect black charger end...
the charger led should turn orange or red when charing then turn green when finished charging, but without knowing the model of the charger its had to say
Dec 12, 2010 | Peg Perego 12v Battery
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
Charging doubts
Personally I would suggest leaving it in the charger maybe even overnight because if I'm not mistaken it should turn green when it is fully charged. good luck
Jun 25, 2009 | Samsung L100 Digital Camera
Turn on problem
your gameboy is completely screwed up so get a new one or buy a ds
Jan 27, 2008 | Nintendo Game Boy Advance SP Console
Samsung SL600 Digital Camera Logo
23 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
