Question about Bose Pm-1 Portable CD Player
Broken hinge how to fix broken hinge
How do I fix or replace a broken Hinge on Dell 500 Laptop
The hinge rarely breaks, the fixings come loose and split the plastic case.
Disassemble the laptop to find out where your problem is,
DELL Vostro 500 PP29L SSD
If the plastic has broken off, I use epoxy resin to repair around the hinge or look on fleabay for a replacement hinge.
Dell Latitude D500 Laptop 14 1 034 Screen Hinges eBay
Feb 06, 2017 | Dell Computers & Internet
Acer Aspire E1-571-6650 would not charge. Problem thought to be DC Jack (AC Adapter would not fix and DC Jack seemed loose). Had the same problem a year ago in July and it was fixed. Original charger...
Difficult to comment but if a laptop comes in for me to repair and the hinge is broken and maybe cabinet damage, I would offer to replace the broken parts and replace the DC jack, if it was faulty. It is part of the service but may not be cheap to repair!
Hinges usually become loose and very rarely break.
Did the laptop work on the power supply but not on battery?
Feb 24, 2014 | Acer Aspire Computers & Internet
The left hinge is broken on my pro905 how do you fix it
My 905 left hinge is broken too. Scanner lid/paper feed is now out of alignment and consistently jams paper being fed through it.
Oct 02, 2012 | Lexmark Platinum Pro905 multifunction...
The right hinge on my screen is broken. Can it be
Here's a link to hinge repair procedures...
http://www.laptopka.com/2007/08/01/replacing-satellite-a45-broken-hinges/
It also has a link to search for the replacement part you may need.
Jan 01, 2010 | Toshiba Satellite A45-S250 Notebook
Broken Inspiron 1525 Lid
hello
To fix your laptop follow the steps given below.
  • First of all as your hinges are broken you have to buy a pair of hinges for your laptop model.
  • This hinge includes the whole assembly made up of metal with a part which attaches your screen to the laptop.
  • Now you have to open up your laptop from the backside and disassemble the upper side.
  • This will make you see the part which detaches tour screen from the laptop.Just remove the screws and your screen will be completely detached.
  • now you can replace the damaged hinges with the new one.
  • you have to remove four screws for one hinge.Two screws supporting the screen and two attaches the screen with the laptop.
  • so remove these screws and replace the hinges and pack the laptop again.
And the lines are basically due to the movement of loose connector. So while fixing please fix the connector also.
Thank you
Aug 21, 2009 | Dell Inspiron 1525 Notebook
Broken hinge
I'd be frustrated as well. Fortunately, your Inspiron is still under warranty - contact Dell. They may send a tech to fix, or you may need to send back the laptop to them to be fixed.
Jul 30, 2009 | Dell Inspiron 1525 Notebook
Screen hinges are weak or broken. HP ZD7010US
The only way to fix it properly is to buy a new chssis or a broken one to use for a donor.
Jun 29, 2009 | HP Pavilion zd8000 Notebook
Broken Lcd hinges
No,you can't fix the hinges if they become slack, you wll have to replace the hinges,it's not too difficult on the E500.
Jan 21, 2009 | Compaq Armada E500 Notebook
Broken nintendo ds lite hinge. Do I send it away for repairs or get a new console?
Nintendo will fix the hinges depending on a few things, first thing would be to determine how the hinges were broken. The hinges are tested before they leave the factory, the only way that they actually break would be because of physical damage/impact. Physical damage is not covered under the manufact warranty so you would get a discounted price depending on if your under warranty or not. Regardless giving them a call and having their techs fix them will be the best bet, not only because you know it will be fixed right and your warranty will start over the day it gets repaired.
Dec 15, 2008 | Nintendo DS Lite Console
Nintendo ds broken hinge.
donde puedo localizarlos para llevarles el nintendo ds
Nov 22, 2008 | Nintendo DS Console
Bose Pm-1 Portable CD Player Logo
35 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
