Question about Royal Rice Cooker Persian 10 Cups
10 Cups solved problems - Royal Rice Cooker Persian 10 Cups
Is 4 pints of water more than 10 cups
There are 2 cups in a pint, so 4 pints is only 8 cups thus less than 10 cups.
May 04, 2014 | GPS
Hinari homebaker model hb152 bread capacity what is bread capacity for model
Bread pan Capacities
Here is how you determine the size of loaf you can bake in your machine. You need to determine the capacity of your pan. Fill your pan with water and measure the cups added so you know how many cups of water are in the pan when it is full to the very top. Here are the conversions:
1)If your pan holds less than 10 cups of water you can make: a 1 pound loaf
2)If your pan holds 10 cups of water you can make: a 1 pound loaf and a 1.5 pound loaf
3)If your pan holds 12 cups you can make: a 1 pound, 1.5 pound, and a 2.0 pound loaf
____________________________________________________________________
This is rare, but if you pan holds 14 cups or more you can make all the above plus a 2.5 pound loaf
FROM ANOTHER SITE:
To find your bread machine pan size:
Fill the bread pan with water and measure it out in cups
Less than 10 cups of water = 1 pound
11-13 cups of water = 1 1/2 pounds
More than 13 cups of water = 2 pounds
Dec 26, 2010 | Kitchen Appliances - Others
What size bread will 41066 make
FROM ANOTHER SITE:
Dec 14, 2010 | West Bend 41077 Just For Dinner¿...
Lost the measuring cup for 10-cup rice cooker and lost the booklet. How do I measure to end up with 8 cups of rice?
1 cup rice and 2 3/4 cups water
makes about 4 cups rice.
SO:
2 cups rice and 5 1/2 cups water should do it.
Feb 02, 2010 | Wolfgang Puck BDRC0010 10-Cup Rice Cooker
Do i need the steamer insert in the unit if only cooking rice? and I want to make the max amount the 10 cup unit will hold is that 10 cups raw rice to 11 cups h20 and how much cooked rice does that make??
went online and looked at blogs by other people.... dont need the steamer insert if you are not steaming anything. The 10 cup maker uses 10 cups (included in box) and makes almost 20 cups rice!!
Dec 26, 2009 | Tayama TC-03 Rice Cooker
Funny tasting coffee
Vinegar/water cleaning is a good idea, but it won't necessarilly solve funny-tasting coffee. First, replace your charcoal water filter - you can get the Cuisinart brand-name replacements at Lowe's, Bed/Bath/Beyond, or Williams-Sonoma in most areas.
To do the vinegar/water cleaning, just pour 1/3 caraffe distilled white vinegar and 2/3 caraffe water into the water reservoir and brew it like it was regular coffee - I would simply bypass the self-clean function if your Cuisinart has one. Repeat up to 3 times, using a fresh batch of vinegar each time.
(if you have the caraffe-less DCC-2000, then just pour in 4 cups vinegar and 6 cups water).
Then run a full cycle of water. Then run a combo of 12 tsp lemon juice and 12 cups water (or 10 tsp and 10 cups water) to improve the taste.
On your next batch of coffee, use bottled water just to rule out any possibility that your local water supply may be contributing to funny-tasting coffee.
Now your coffee should be tasting fine again.
-Tha Mp3 Doctor
Apr 03, 2009 | Cuisinart Coffee Makers & Espresso...
10-22 urn
If you have the L1350/155C, the manual states 1-1/4 cups coffee for 12 (5 oz) cups, for 30 cups use 3 cups coffee using standard measuring cups. Take the stem & filter out when the coffee has finished brewing so the bitter oils do not get into the coffee.
Dec 17, 2008 | Faberware 10-22 Cup Coffee Urn
My cuisinart coffee maker just recently started not using all the water I've poured into the reserve. Up 'til today it was leaving the last two cups in the reserve, but today, out of the six cups I poured...
This is a real problem with these coffee makers, and there's not much that can be done. However, there is a work around: before brewing, just hit the button to brew 1-4 cups. It'll still brew a whole pot, it'll use all the water, the coffee will taste no different, and you can still program it however you'd like. Cheers!
Sep 21, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Lost rice cooking instructions
From the users guide for the 550 FOR BROWN RICE RICE: 2 half cups WATER: To 2 mark, plus 3/4 cup TIME: 32 minutes MAKES: 2 cups RICE:4 cups WATER: To 4 mark, plus 3/4 cup TIME: 39 minutes MAKES: 8 cups Here are the rest: 6 cups To 6 mark, plus 3/4 cup 44 minutes 13-1/2 cups 8 cups To 8 mark, plus 3/4 cup 48 - 49 minutes 15 cups 10 cups To 10 mark, plus 3/4 cup 51 - 52 minutes 21 cups Here is a link to the user guide for all the instructions. http://www.blackanddeckerappliances.com/dyn/prod/user-guide/139/RC410%20RC550.pdf
Jun 22, 2007 | Black & Decker RC550 10-Cup Rice Cooker
Royal Rice Cooker Persian 10 Cups Logo
23 people viewed this question
Top Royal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Royal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
