Marco fireplace model 792778e
When the blower is on the air is pulled in at the bottom but nothing comes out at the top why
SOURCE: I need help relighting the
First, turn the wall switch to the off position. Second, turn the key all the way tcountercockwise to the open position. At the front of the unit, below the hearth opening there is a black front access panel. Should have a little recessed part. pull it out and expose the gas valve. Turn the plunger/knob that says off, on, pilot to the pilot position. You'll knw your in the pilot position when it lines up with the indicator (usually a red or black mark on the gas valve body). If you are in the pilot position, you will be able to push in the pilot (it will feel springy). Push the plunger in and then push the red button (piezo ignition button) in until it makes a snapping sound. You may have to do this several times because the air has to bleed out from the pilot tubing. This should light the pilot BUT wait. DO NOT LET GO OF THE PLUNGER ONCE THE PILOT IS LIT. You need to keep the plunger depressed for about 30 seconds and then let it go. After 30 seconds let the plunger go and verify the pilot is lit. If not try the last step over. After the pilot is lit, you may turn the plunger/knob to the on position. Now go back to the wall switch and flip it on. If it doesn't come on tap it hard. Sometimes dust can actually prevent it from making good connection. I work on fireplaces for a living and coincidentally worked on this model today. Simple as pie.
Posted on Sep 15, 2010
  • 2418 Answers
SOURCE: I have a marco fireplace
It is to allow more or less ambient air into the combustion area.
Posted on Feb 09, 2011
  • 4736 Answers
SOURCE: Where does the FBK200 blower
As you are aware the Marco Fireplace Co is no longer in business. However, the blower model # you listed is a DESA/Vanguard part number. In any event, it may work.
The blower goes in the lower compartment (probably louvered) under the firebox. It is then attached to the rear wall of the compartment, with the blower output facing up the back wall of the firebox. There should be an arrow on the blower housing indicating which way it should point.
If your firebox is already wired for a blower and has a duplex receptacle in place (for the blower to plug into), you're in business. If it doesn't I highly recommend that you install one and not try to hard wire the blower.
The blower, if purchased new, should come will all the hardware to mount it. If it didn't you can use sheet metal screws to attach it to the rear wall of the firebox. However, make sure that you put a rubber flat washer behind the mounting frame and then screw thru it into the firebox wall. This will help eliminate vibration and noise.
Hope this helps to get you started.
Posted on Feb 25, 2011
  • 1082 Answers
SOURCE: I have cold air coming
So long as the fireplace is NOT IN USE, you are safe to block the draft, most any way you want.
Posted on Mar 07, 2011
  • 4736 Answers
SOURCE: lack of air to fireplace,need diagram to check air
To help you, I will need the correct Model Number of your DESA gas fireplace.
Please advise, thanks.
Posted on Jun 02, 2011
Need manual for marco fireplace model MH 9245
This company is out of business due to massive government recall. I could not find a manual online for you.
CPSC Marco Alert Consumers to Gas Fireplace Recall Due to Fire Hazard
Nov 17, 2016 | Heating & Cooling
Where is the thermocuple on my marco gas fireplace
Fireplace Pilot Light Tutorial - YouTube
? 5:06
https://www.youtube.com/watch?v=Moa7eGlKCr4
Nov 12, 2012 - Uploaded by FogoFox
This video walks you through the process of turning on the gas to your fireplace, lighting ... Lighting a Gas ...
The thermocouple compared to the thermopile. - YouTube
? 6:01
https://www.youtube.com/watch?v=dRjX5m0zHUU
Oct 16, 2013 - Uploaded by grayfurnaceman
I got an 1980 gas fireplace, I just see the pilot and something that look more ... My land lord purchased a ...
Marco Natural Gas Fireplace (Model B36CFI) won't turn on ...
Download MARCO GAS FIREPLACE MANUAL PDF ...
? 0:16
https://www.youtube.com/watch?v=lJyHdPywr0M
Jul 31, 2015 - Uploaded by Roscoe Sikes
Download MARCO GAS FIREPLACE MANUAL PDF ... How to Safely Light Your Pilot on Your Gas Fireplace ...
Dec 07, 2015 | Heating & Cooling
Is the Marco Fireplace 7792778E a fireplace or a fireplace insert?
Apparently the Manufacturer is out of business but there is a MARCO Distribution company. Call them for info since internet searches are failing.
call Marco Fireplace Distribution at 818 764 3366
Jan 02, 2015 | Heating & Cooling
I have a Marco wood burning fireplace built in 1980, can't close off vent on bottom of firebox...lets in ALOT of cold air. Help
TRY TAPPING ON IT WITH A SMALL HAMMER LIGHTLY, & QUICKLY 15-30 TIMES & SEE IF IT COMES LOOSE AND SHUTS FOR YOU.
Dec 27, 2012 | Leisure HOMEPRIDE Electric Fireplace...
In cleaning my gas-fired Marco fireplace, unsure original base configuration, mine has only burned out mineral wool pieces. The metal flat base has a row of small ports along the front. A single row of...
Unfortunately, you didn't list the model number of your fireplace and whether it's vented or vent-free. However, I suspect it's vented, as MARCO (now out of business) manufactured very few vent-free models. Restoration is going to depend on the condition of the burners, as well as the gas control valve and the condition of the firebox. The small ports you mentioned, are for the Rock Wool (Glowing Embers), which are divided into small pieces (dime size) and fluffed, then placed over the small ports. MARCO did not make a vented fireplace where silica sand was used on top of the burners. Normally, you only see that on vented gas log set, that is installed in a solid fuel burning (masonry) fireplace and operated with the damper fully open.
As far as restoration parts are concerned, I seriously doubt there are any available. MARCO, as such, has been out of business for almost 10 years. Today's burners are not designed for the same configuration that you have. It wouldn't be wise to try to change the configuration, as the firebox was tested and approved for only what's in there now.
Wish I had better news for you. But, my 15 years in the hearth and home business, tells me it would difficult and costly to do.
Apr 23, 2011 | Heating & Cooling
Where does the FBK200 blower go in the Marco fireplace
Feb 25, 2011 | Heating & Cooling
Need a manual for a marco fireplace 792778e
Models that starts with model numbers which are 6 numbers starting with 792 and followed by a letter are wood burning and models that starts with model numbers which are 6 numbers starting with 794 are gas models
Dec 27, 2010 | Maytag M6D24E7A Air Conditioner
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
