Question about LG 42LE5400 42 in. LCD TV
LG BP330 picture is not stable - LG 42LE5400 42 in. LCD TV
Program my Toshiba 36A60 36' TV to a universal remote
Programming procedure differ to different brand of remote controls; and it is no practical to type in all here by this window. If you wish to get more information, check these links. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
0028,0021,0020,0025 are the common codes that sets with most of Toshiba TVs.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Dec 15, 2013 | Toshiba 36A60 36" TV
Unable to reconnect to wi-fi
If you have not done so already, reset the player to factory settings and try again. If an ethernet cable connection is available, use it to get the best connection speed.
Dec 12, 2013 | LG DIGITAL/AUDIO/VIDEO Lg Bp330 Blu-Ray...
My lg 42pc3dv just turns off and on. I removed the power supply boad and checked the capacitors but I don't see any bad ones. They all look good. The only thing I noticed is three white coil resistors up...
You need to monitor your standby voltages first, to see how stable they are 5v-3.4v-12v. If they are stable then locate the ON command pin going to the inverter board and see if it is going High then Low. If it is then replace the main board.
Nov 27, 2010 | LG 42PC3DC 42 in. Plasma HDTV
I would like to get pictures from my LG and transfer them to my computer. Also, I would like to download a computer file/folder onto my phone.
all you need to do is to connect your phone via usb to your computer and open up the external device with which it appears. with this connection stable, you should be able to transfer files freely between your computer and phone
Nov 03, 2010 | LG Cell Phones
Transfer pictures from my LG GR500 to my computer
There is a super easy solution, if you are using windows  try using a live cd, which is a bootable cd. Here is the link to a good one: http://ftp.heanet.ie/pub/linuxmint.com/stable/8/LinuxMint-8.iso
just download and burn onto a disc using an iso burner (http://www.freeisoburner.com/)
then boot up the disk and plug in your phone, the os should recognize the phone as a mass storage device then you can retrieve your pictures as you would a usb
Mar 20, 2010 | LG Xenon GR500 Cell Phone
LG Neon ramdonly shuts off and loses pictures
Did you unlock lg neon network before? If this condition happened after you unlock your phone you will net to upgrade your phone software, since lg unlock code only reset your phone network but all remaining software still have old network configuration and it's will not stable for your current network.
Sep 05, 2009 | LG Neon GT365 Cell Phone
LG 22" HD ready LCD Picture mode problem
This problem is going to be a bad main board (sometimes called digital board). Hope this helps.
Dec 09, 2008 | LG 26LX1D 26 in. LCD HDTV
Picture squeezed horizontally
we have right click on desktop <properties<settings <apply ok
Sep 09, 2006 | LG Studioworks 563N 15" CRT Monitor
LG 42LE5400 42 in. LCD TV Logo
19 people viewed this question
Computer Repairing
Computer Repairing
