Question about Jenn-Air WW30430P Stainless Steel Electric Double Oven
Problems with Jenn-Air Electric Double-Wall Oven
Hi I have a Jenn-Air electric double wall oven.   Model WW30430P.
The lights on the display panel have not worked for some time now.
Went to self-clean the oven recently on the top oven, and then the fan stayed on, and would never turn off.
Because the lights are out there is no error code to display.
We had someone attempt to diagnose the problem, and now it beeps constantly, and does not heat at all.
He said we needed the computer board behind the touch display.   Does that sound right?   How hard is it to install this for a do it yourselfer??     Where's the best place to get low priced parts for Jenn-Air?
Thank you for your help.
  • 9 more comments
  • frankgreta Jan 29, 2008
    Which board of the many is erquired to have the display work again. It has been out for some time because I'm not sure which board to replace.
  • texa Feb 15, 2008
    I have Jenn-Air electric wall oven, model JJW8130AA black color, it was working fine but suddenly stop and error show on control panel F1. and some time error: FO- 0 with 054, please advise what may be worong.
  • nick fg May 21, 2008
    disply screen has lost iluminance
  • smithrozzy Jun 23, 2008
    Jenn-Air WW30430 double wall oven. Can't see temp. or time displayed. When I press bake and temp. it just beeps. Any solutions!
  • Anonymous Jun 28, 2008
    My Jenn Air LCD Display is very dim. The oven still works, but I can't read the clock or any of the displays, especially when the oven goes on. Can I fix this myself???
  • Iyengar Jul 20, 2008
    I have the same problem. However, the Oven qorks fine!! No display. We have lived with it for teh last 5 years. The Oven is 10 years old. We just dial the temperature and hit bake or broil etc. We have learnt to use it without the display! Jenn-air will do nothing, except charge a lot for the display.
  • Anonymous Aug 06, 2008
    1. bollickybill@gmail.com same problem,control panel LED dim,if a solution is offered ,please let me know!.
  • Anonymous Aug 24, 2008
    lights on the display panel does not light up
  • elspring Sep 07, 2008
    I have the same problem - my jenn air wall oven is just five years old and the display lights are not working - The oven works fine. I was hoping for a quick easy fix?
  • jeffgirod Dec 06, 2008
    My Jenn-Air wall oven has the same problem. The display is extemely dim, but the unit still works. The only time you can read the display is when the unit is extemely hot, like during the cleaning cycle.
    Also, the door will not close all the way and so the light says on all the time. A repair tech. was not able to fix the door. We have lived with this for 5 years. If I could fix the display inexpensively, I would. The door does not bother me as much. We did un-screw the bulb inside so the light will stay off.
  • Anonymous Mar 31, 2014
    Electric oven heats slowly or not to temp. Broiler works find
The dim display is because a capacitor on the board is bad. when they manufactured it they used a defective batch of capacitors. just google how to replace. I ordered a capacitor and replaced, now display is bright again! too bad they did not recall. Now I need to find out why the self clean function no longer works on my top oven
Posted on Mar 10, 2012
Try changing the clock assembly --
http://www.partselect.com/ModelFrames.aspx?ModelID=221346&ModelNum=WW30430P&mfgModelNum=&ManufactureID=1&Selected=51238&Position=1&mfg=Maytag&Type=&Mark=1
here is a link to the diagram.
PS120923
Electronic Clock Assembly (Series 10)
Help with series numbers
here is the part number.
Posted on Feb 17, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 10 Answers
That board supplies power to the light unit and it is very easy to replace if that is what is wrong. it can also be the led display unit also. cost about $150 each i think.
Posted on Dec 01, 2007
I need the Start Amprege for a Jenn Aire #WW30430P
phone jen air tech support daytime Eastern Standard time:
1-800-JENN-AIR (536-6247)
Dec 20, 2013 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn Air wall oven won't cancel / shut off . Recently replaced membrane.
Hey - the ribbon link from membrane to control is a tricky plug to get in right- double check this connection and let me know if it helps- Thanks- Ed
May 13, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
The control panel display light is completely dark but the oven still seems to function ok. Jenn Air Model WW30430P double wall oven.
A lot of ovens use a gas-filled vacuum flourescent display module that takes a higher voltage to drive it. The modules can get damaged or the power supply for the higher voltage (usually around 50 volts) may have failed.
Chances are the thing is only sold as an assembly...While the displays are common in auto speedometers that have digital display, those for these ovens are special with wpecial characters and background.
Jan 31, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
Am negotiating a home inspection on a house with WW30430P Jenn Air Wall Ovens; neither of the doors close. Is there a solution?
There are several models of Jenn-Air ovens that had issues with the door closing. The only solution is to replace the door hinges (unless the doors themselves are bad, you can see this if you open the door, the porcelain on the door will be bulged and cracked right where the hinge joins the door). If the doors are bad, the hinges and the interior door panels need to be replaced. Hope this helps!
Dec 16, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
Lower electric wall oven won't heat up
It is highly likely that your heating element is open so I would ( with power removed) verify the integrity of the element by detaching it and making sure it is not elecltrically OPEN, It is nothing more than a big power resistor that when current is flowing,..gets hot but if it becomes open.. you will not have any curent flow thru it ( or heat generated from it). That would be the first place I would look.. It could also be the control that feeds it..
A few ideas to check..
Regards,
Rick
Feb 15, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-Air WW30430P Stainless Steel Electric Double Oven Logo
1,366 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
