Question about Vehicle Parts & Accessories
Engine codep 0455 says throttle body is bad - Vehicle Parts & Accessories
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
Then it probably is replace.
Posted on Oct 09, 2014
Volvo c70 2001. blown engine. Have now replaced engine/used old throttle body but car difficult to run and hard to start. surging badly will not idle/stalls
on google:
2001 Volvo C70 Problems - RepairPal
repairpal.com > Problems > Volvo > C70 Problem with your 2001 Volvo C70? Search our list of user submitted and RepairPal verified problems and issues
Jul 20, 2015 | 2001 Volvo C70
WHAT WOULD MAKE MY CAR ENGINE WANT TO RACE FORWARD
A few possibilities:
  1. Defective throttle position sensor (TPS);
  2. Bad idle bypass circuit or idle circuit solenoid;
  3. Cracked intake manifold, throttle body assembly, or bad throttle body gasket (most likely);
  4. Serious vacuum leak somewhere.
Aug 02, 2014 | 2002 Buick LeSabre
Hi I have a code p17705
You will need to get a VW type scanner and perform throttle adaptation . You may have one of two issues, one being a faulty throttle body, the other being a bad harness. We have seen some issues with the 01 model vehicle engine harness. There is a problem at the connector for the throttle body. Normally we will unplug and reconnect the harness to the throttle and perform a throttle adaptation. If it fails, the first thing is to replace the throttle body, if you are still having problems, then you will need to replace the engine harness.
May 09, 2011 | Volkswagen New Passat Cars & Trucks
Dear Sir, I have a 1997 Jeep Cherokee Sport, 6 cylinder 4.0 liter. I recently tried cleaning my throttle body with carb cleaner while the vehicle was running. After spraying a half can of cleaner in the...
do a compression check on the engine, and replace the bad sensor, i take the throttle body off to clean it and some sensors are touchy about cleaner, i fear maybe something got on the egr valve pintle
May 26, 2010 | 1997 Jeep Cherokee
Idle fluctuates up and down engine warm. stalls at stops
The most common cause of this is a dirty throttle body. If you follow your air cleaner hose to the engine thats your throttle body.When you take the air hose off you will see black stuff around your butterfly thats the bad stuff you can remove that by giving it gas or moving the throttle cables.and cleaning with throttle body cleaner! This will only take about 10 minutes
Feb 17, 2010 | 1995 Buick Regal
Engine doen't stay idle at steady rpms rev up and down by itself
Either you have a vacuum leak, a bad throttle body position sensor, or a bad throttle body.
If the throttle body is drive by wire (electronic) then it would be a bad throttle body.
If the throttle body is drive by cable (manually driven by a cable connected to the gas peddle) then it would be a bad throttle position sensor.
If the throttle body is bad the check engine light wil lbe on. If it is on have your codes read at your local parts dealer for free, and this will give you a clue as to which pices/parts you need to replace.
Have the car leak tested and the vacuum linse inspected for leaks as well.
Jun 01, 2009 | 1989 Toyota Camry
2002 Chevy Trailblazer
hi, those sound like throttle actuator codes. the throttle body on your vehicle should be an electronically controlled unit without wires to control actual acceration an deceleration. now, there is also an electronic switch called a potentiometer on the gas pedal that transmits signal to the throttle body to tell it what to do. most of the time, the throttle body is what goes bad here. you should also check the wiring to the unit for bad connection by wiggling the wire connector and seeing if the reduced engine power light comes on. if this happens, you will likely have to replace the wiring pigtail and the throttle body. but, in some cases, the gas pedal switch goes bad, and likely what is not allowing the transmission to shift out of park, the pcm may lock out the solenoid controlling the shifter. but, don't just run with that answer, it maybe completely wrong. i have seen more throttle bodies and wiring harnesses go bad than gas pedal switches in those vehicles. but you might want to have a shop diagnose further, it may even be two unrelated problems, or in the powertrain computer itself.
Mar 26, 2009 | 2002 Chevrolet TrailBlazer
HIGH IDEL
sometimes the gasket under the trottle body goes bad. spray carb cleaner at the base of the trottle (not down into it) body while the engine is running. if the idle changes your on the right track. its an easy gasket to change.
Jan 08, 2009 | 1998 Chevrolet S-10 Pickup
Vehicle Parts & Accessories Logo
24 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
