Question about Miele Incognito G658 SCVi Built-in Dishwasher
Intake/drain light on on larger light is flashing
I have intake/drain light on. This happened shortly after starting a wash cycle; so there is some water in bottom of wash cabinet. Manual says to clean out filter in wash cabinet. Do do this it instructs me to turn counter clockwise. This does not seem to be turning. I'm fairly strong and the lever is plastic. I'm worried that the plastic handle will break if I tug on it too hard. Checked filters on ends of hoses and they seem to be fine. No evident kinks in hose either. Is there something I'm missing on removing filter?
  • 7 Answers
SOURCE: another inlet / drain light cycle interruption problem!
When the water stops too soon, it could be the "over flow" is stuck in the downward position, therefore the dishwasher thinks it's going to over flow. Check that out. Otherwise I'm afraid this sounds like the circuit board is shot.
Miss Midget
Posted on Nov 02, 2007
gwshaw71
  • 83 Answers
SOURCE: Drain pump runs continuously
Which model do you have and is there any fault codes showing on unit? I have all of the service manuels for miele products.I am factory auth. for service on miele.
Posted on Feb 24, 2008
SOURCE: inlet/drain light remains on
I have the same problem on a Miele G647 SC Plus. It starts and completes the wash cycle, might skip a final rinse - not sure, but it drains the water. Pump then continues to run for extended period then inlet/outlet light comes on. The dishwasher never moves to the drying cycle.
I cleaned all filters, checked supply/drain hoses + the non return valve. All seemed servicable. But no real improvement in fault.
Any way I can fix this?
Posted on Aug 13, 2008
vector006
SOURCE: Cycle starts then stops and Intake/Drain light comes on
Hey All.
I had the same problem with my Miele g843, and i finally got to the root problem.
My machine would drain ok, and fill ok, but when it tried to start a cycle, it would do nothing. I could hear a relay occassionally clicking until it finally gave up and signalled the blinking red light of death.
I first checked the inlet filter, drain pump and drain pipe but I discovered no obstructions. So I started taking the dishwasher apart, and discovered that the main pump was seized! This may not be the source of YOUR problem, since it could be many things, but this worked for me. Here are the instructions to remove the pump and get it moving again:
Pull out the dishwasher and disconnect the power, water and drain lines.
Empty all water from the unit (disconnect drain line and let the water drain into a low profile container) you may have to elevate the unit and tilt it rearwards to get the remaining water out.
Remove the side panels of the machine.
Lay the unit on its side elevated about 2-4 inches above the ground (be careful you don't put direct pressure on any of the internal components when you support it)
Remove the 4 screws that hold the base panel to the frame of the machine.
You can now see the motor.
Disconnect the electrical connections to the motor and the pressure sensor.
Disengage the clamps that hold the rubber hoses to the motor and slide the hoses off the motor.
Unscrew the single bolt that holds the motor inplace on the back panel of the machine. Pry the rear panel out slightly to release the dowel pins and gently pull the motor towards you (pivoting on the inlet grommet). Once you have the motor out, you can try to manually turn it by rotating the impeller. If it is stiff, you could have the same problem mine had. Using silicon spray with a nozzle extension, spray the seal between the impeller housing and the motor and continue to spin the motor manually until it becomes free spinning. If this doesnt work for you, you may need a new motor ( i never priced one out but it cant be cheap ).
If you get stuck somewhere email me and i can send you pictures: vector006 at hotmail dot com
Cheers!
Posted on Mar 01, 2009
SOURCE: Intake/Drain lit flashing
I have exact same symptons, please someone help. I have had issue before where the plumbing backed up so it overflowed into the catch tray. Then that has to be vacummed out and then just start a new cycle. This time there is no water in the overflow tray....
Posted on Jun 08, 2010
Why won't my washer start a cycle? Start button LED just flashes. All other lights are steady. Door lock sounds like it engaged, but nothing happens.
There should be a way to enter the washing machine into service mode to view an error code. Check your user manual and then you should have your answer!
Jul 23, 2014 | Washing Machines
Indesit washing machine IWC6165 will not start a wash cycle.
my Indesit washing machine start washing normally taking water and spinning and draining but for each cycle i have to do manual its automatic cycle is not working by it self the way it meant and suppose to be . for example if i start on number 3 to wash it just stay on number 3 not moving to next cycle . plz can anyone knows why this happen .?
Dec 23, 2012 | Indesit Washing Machines
Indesit WIA121 Flashing Door Lock, Prewash and Spin Lights - Machine not draining
hi something similar has started happening to our washer, after the initial wash starts the machine doesn't do anything for a while then the red door light flashes on and off very quickly as does the 1st and 3rd green wash cycle light?
Jul 04, 2012 | Washing Machines
Trying to start the unit but the washing light indicator only flashes.
this means the machine has started the cycle...that is the washing light is flashing. However if nothing happens then the drain pump is not working firstly. Machines usually drain first any bit of left over water then go yo fill up. As you havent ststed the make and model i assume the drain pump is faulty. or the water inlet is not working. More precise info is needed to advise you further
Aug 01, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Intake/drain light flashes, and the diswasher won't start.
wash dishes by hand and use dishwasher for storage. lol
Oct 04, 2009 | Dishwashers
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Asko 1585 Dishwasher
do they flash lik all on one side then the other? Start a cycle, then open the door. Do the lights flash the same way when you open the door as when it stops? if soyou may have a door that needs to be adjusted so it closes better. when the cycle ends, is there any standing water in the bottom? if so you may have a poorly routed drain hose or a partial clog in it. Last, pull the bottom panels off and look inside the bottom of the dishwasher and see if there is standing water down there . If ther is you have aleak somewhere or a bad drain pump. You r only other choice is a bad pressure switch. If youve already adjusted the water fil to the proper level ( just up to the grey plastic housing that the lower wash arm sits on) tehre really aernt any more options. Hope this helps!
Aug 29, 2007 | Asko 24 in. 1585 Built-in Dishwasher
Miele Incognito G658 SCVi Built-in Dishwasher Logo
57 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
