Question about Ascaso Dream Espresso Machine
Power stays on even though the switch is off
Can't figure out why the power switch is on even though it is in the off position
My tdxsp wheelchair will not power off
This should help you: Invacare,s TDX - SP power wheelchair - YouTube
Sep 26, 2015 | Health & Beauty
2007 dodge caliber has full power to all electronics. The engine light stays on and when you turn the car to start nothing. Turning the key does not even deam the lights like the starter is getting no
Sounds like the solenoid on the starter is not getting any power, check the small wire connection on the starter to see if there is power in the start position, if not you have an ignition switch problem or an open circuit between the ignition switch and starter solenoid... if you do have power in the crank position then you have a bad starter.
Jan 11, 2015 | 2007 Dodge Caliber 2.0
I HAVE REPLACED FUSE BUT STILL NO POWER
Stay connected to electric line, can cause a lightning stroke to effect, even though the set is switched off.
Mar 01, 2013 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Element on light on ... Nothing is on
This happens when one of the infinite switches short out. The indicator lamp will remain on even though none of the elements are heating up. To figure out which one is defective, gain access to the rear of the switches and remove the wire going to terminal P (Pilot) Restore power and see if the light is out now. Keep doing this to the remaining switches until you find the one where the light stays out with the wire removed after power is restored. Supply model number and we will supply the part number for the infinite switch. Be sure to let us know if it is the 6 or 8 inch burner switch. Good Luck and be careful. Eric
Mar 23, 2012 | Frigidaire Cooktops
The "Cook Top On" light
one of the stove top burner control switch has gone bad causing the light to be on when off,it could be anyone of the 4 since the light will come on no matter which one is turned on.
To test and see which one it is..remove back panel so ya can get to switches TURN OFF THE BREAKER OR DISCONNECT THE POWER TO RANGE
using a multmeter need to check all 4 switches to see which one it is
on the switches will be wire terminals on the switch maked as L1 and one marked P the switch that is the problem will have contunity on that L1/P curciut when the switch is set to off causing the light to stay on all the time.
Aug 26, 2011 | Whirlpool Accubake RF362LXTS Electric...
Brake lights are staying on even with the ignition is off
Hi, you probably have a bad brake light switch located, I believe, on the arm of brake petal, try disconnecting it to see if they go off, not too difficult to replace once you have new switch.
May 30, 2011 | 1995 Honda Accord
Ge tru temp range, oven will not shut off
You have a malfunctioning oven switch,get it replced or simply remove the fuse for your oven there maybe 2 fuses.
Jan 30, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
No power
You have probably missed re-connecting part of the electrical wiring- probably missed a ground connection..
Check you have re-connected:-
the main power supply via the fusible link (or in line maxifuse),
the battery negative terminal is correctly grounded to chassis/frame,
the motor ground connection to the chassis or battery negative.
Oct 09, 2009 | 1991 Ford F150
Ascaso Dream Espresso Machine Logo
20 people viewed this question
Top Ascaso Coffee Makers & Espresso Machines Experts
richie46
ray gallant
Are you an Ascaso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
