Question about Hamilton Beach Kitchen Appliances - Others
Toaster pop up will not stay down - Hamilton Beach Kitchen Appliances - Others
  • 3 Answers
SOURCE: My Krups model 288 toaster won't always latch down.
You can fix this yourself by following these instructions. Unplug your toaster before proceeding!... Clean the toaster first. Turn the toaster upside-down and shake out the crumbs. Remove and clean the bottom crumb tray. 1. Unscrew the four Phillips head screws located in the corners of the bottom base. Remove the screws completely if possible. Do this over a cloth or newspaper - that way a stuck screw won't get lost if it falls out later. 2. With the toaster right-side up, pull off the wide toast lever knob. Do not remove the round adjustment knob (it will not come off from the outside) but make a mental note of what number (1-7) is showing at the knob's adjustment mark. 3. Carefully pry up the end of the case cover with the knob on it (don't pull on the "stop" button). When the knob's plastic shaft is clear of the circuit board, gently pull off the cover. 4. On the inner part of the circuit board you will see a black plastic "cam" surrounded by two sets of electrical contacts. Rotate the cam to open the contact points if necessary. Insert a thin nail file between the points and rotate the cam to trap the file between them, then scrub back and forth several times to clean the contact points. Do this for each contact on both sides of the cam. When finished, rotate the cam clockwise so it is all the way back down to it's original position. 5. To make re-assembly easier, remove the round adjustment knob from the cover by depressing the half-round shaft flanges inside the cover with your fingernails. 6. Re-assemble the toaster by reversing steps 1 & 2. Replace the knobs, making sure that the round one is in the same position you noted earlier before you push it all the way down.
Posted on Mar 27, 2007
  • 145 Answers
SOURCE: KitchenAide Toaster
Kitchenaid does not recommend repair on the toasters, as it is not cost effective for the consumer or company to engage in repair.
I would recommend calling Kitchenaid Customer Service. If the unit is within the 1 Year Warranty, they may replace it at no cost. If the unit is outside of warranty, they may provide discounts on the purchase of a new toaster.
Their toll-free telephone number is 1-800-541-6390.
Posted on Jul 10, 2009
SOURCE: toaster arms will not stay down
Arms stay down by the mean of an electromagnet, controlled by a chip. If the wall outlet is functional, you should be able to turn on light by pressing the "defrost" or "bagel" button while the arm is held down. No light? the toaster is good for garbage!!
  • 383 Answers
SOURCE: just got this toaster, and
Is there any 'temperature' setting that needs to be adjusted higher, to make it stay?
What did the manual say about how to toast your first slice of bread?
It sounds like you might need to take it back, and get it replaced.
Tell us more--
Mack B
Posted on Dec 27, 2010
mc1bean
  • 3053 Answers
SOURCE: The toaster won't stay
Hello, rex
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about toasters andpossibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances1.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
Fix sunbeam 3806 toaster that won't stay down and therefore heat bread.
Just a guess since I have had the same happen to my Proctor Sillex - When you push down the lever, you are actually completing the transformer frame that then magnetically keeps the toast down until it's setting lets the toaster pop up.
In my case, a piece of toast was wedged and I could not get the handle down so that the hardware was in place to magnetically hold. Have you tried to give your toaster a good thorough shaking upside down, unplugged over the garbage can or the sink?
Good luck Eric
Oct 04, 2017 | Sunbeam Kitchen Appliances - Others
The thing you push down to activate toasting will not stay down
Check to insure the surge protector has not popped out. Reset and try again. Make sure its plugged in or it will not stay down.
Feb 01, 2016 | Cuisinart CPT-160 Metal Classic 2-Slice...
Russell Hobbs 18140 Toaster The bread carrier will not stay down during toasting. Insert two slices of bread into bread carrier and push down to lock. The right hand side carrier does not stay down. The...
Constant use can lead to crumbs clogging the path of the lever. Try opening up the bottom panel, by pulling on the metal tab to release the plate (and crumbs!) over a trash can. Also try flipping the toaster upside down and, very gently, shaking the crumbs out. if that doesn't work, you can try checking the toaster's browning dial. This might be too low to activate the heating coil. Try dialing it up, and pushing the lever down again. I hope this helps. You can check our post on Best ways to use a Toaster oven. Best ways to use toaster oven 2017 ultimate guide Kitchenutilitypro
Sep 28, 2017 | Kitchen Appliances - Others
The toaster does not lock in the down position
I am having the same problem with mine. I have found that if I hold the lever down, it will stay down after the elements start to heat, and then pop up according to your dial number. This isn't a solution to the problem, but you can still use your toaster.
Jun 11, 2011 | Cuisinart CMT-400 Cast Metal 4-Slice...
Just got this toaster, and when i tried it out for the first time the lever would not stay down it kept popping up.
Tell us more--
Mack B
Dec 27, 2010 | Black & Decker Black Decker T2560B 2Slice...
The lever won't stay depressed
mcdevito75 here, The lever mechanism could be worn OR the setting for darker / Lighter toast is set to Light, swtch to darker see if that helps.
Jun 22, 2010 | Breville CT40 Retro Classic 4-Slice...
KitchenAide Toaster
Apr 10, 2009 | KitchenAid KTT261 Ultra Power Plus 2-Slice...
Sunbeam 3831 Toaster (2-slice) -- toast/carriage won't stay down
great ! its a great fealing when you save a appliance from the junkyard .
Mar 30, 2009 | Sunbeam 3831 2-Slice Toaster
Toaster arms will not stay down
Mar 15, 2009 | Cuisinart CPT-180 Metal Classic 4-Slice...
Kitchen Appliances - Others Logo
51 people viewed this question
Top Hamilton Beach Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
deton8 von Splosion
Are you a Hamilton Beach Kitchen Appliances - Other Expert? Answer questions, earn points and help others
