Question about Nextbook Tablets & eReaders
My tablet will not stop doing a factory reset. was told to install an older version to my tablet so that when the tablet updates to the current version, it will take care of the problem which is a bad
I got the tablet just before or rather, around Christmas. I had to do a factory reset when the nextbook tablet that I have wouldn't respond the way it was supposed to. Since then, my tablet had done a factory reset more times than I can count. Was told that to fix it, would have to uninstall something, and install an older version. When the tablet would update to the current version, that should fix the problem. Need help.
  • 6 Answers
SOURCE: Lost Tablet Funcionality on Gateway M275
You dont have the correct drivers installed for the pen and button functions.. I need a email address to send them to... Mine is: or call me...740-404-6370
I have the same tablet and it took me 3 months to round up all the CORRECT drivers and get everything working.... BTW I could use a copy of the restore disk for mine if you could...
Posted on Apr 12, 2010
  • 7 Answers
SOURCE: how do i unfreeze my android tablet after factory reset
let it sit at room temperature until it thaws out :-D
Posted on May 31, 2012
  • 167 Answers
SOURCE: nextbook will not com on
check the battery otherwise it is the hardware problem in your tablet pc
Posted on Jun 26, 2012
  • 2072 Answers
SOURCE: how do i update my adobe flash player to version 11 on my htc evo design from boost mobile
Through the Google Play Store is the only way I know of. If it isn't working go into settings > Apps > play store, clear out cache and force stop the play store. Then try updating flash again.
Posted on Dec 04, 2012
  • 54 Answers
SOURCE: my daughter forgot her unlock pattern for her craig 7' android tablet, how do we factory reset
press and hold the camera button and the on/off button at the same time.
Posted on Jan 04, 2013
Hi,i had to factory restore my kindle hdx 8.9 2th gen.i can not locate any bookmarks.tryed it twice no luck,any help
You may need to install updates since you factory reset and it is an older tablet. Check and see if there are updates available.
Nov 05, 2016 | Amazon Kindle Fire HDX 8.9
I'm trying to download the wwe app on my tablet. It keeps coming back saying that the app isn't compatible with this device. What do i need to do?
Only thing you can try to do is to find inline older version of that app and see if it would load on your tabled. Looks like currently offered in play store is not compatible with your unit and chances are that either there is hardware limitations or app requires higher android version in order to work. Check tabket manufacturer for updates
Oct 15, 2016 | Tablets & eReaders
My tablet continus to freeze now all because of a app they installed on a update they won't help me. I cannot uninstall or force stop!
You may need to consider resetting your tablet to its factory settings. If nothing else is working, it is what you can try. Any saved data you have on it will go, so you should try to back it up somehow, if you can, but if it is freezing so much, that may not be possible.
How to Factory Reset Your Android Phone or Tablet When It Wont Boot
I post on behalf of HP.
Jun 24, 2015 | Tablets & eReaders
When i turn it on i get a message that says unfortunately,launcher has stoped wont let me do anything else
You need to do a FULL reset.
1. Power off unit
2. Hold down POWER and Vol - (or Vol+ if Vol - doesn't work) until Android reset screen appears.
3. Scroll down to factory reset and select it.
4. Agree to reset
Unit will reset itself and start over like it was brand new and you will lose everything that was installed. Most likely you have a corrupt operating system and this may help. However, many android apps will not work on that tablet as its an older tablet that does not have an upgraded OS available.
Good luck
May 25, 2015 | Ematic 7" Touch Screen Tablet
How do I desert my password?
back up if you can reset the tablet factory reset process {look it up in google } and i would look for any 'firmware' updates install these and the reset of the default software then update the tablets software to the latest
this will wipe out the older password and allow you to then enter what you like
if you can get into it then backup now and follow above to restore its proper functions
Nov 28, 2014 | ASUS Tablets & eReaders
How to fix my proscan will not run google it keeps crasing
Go into settings.
Apps. Select Google.
Clear cache.
If that doesn't work select uninstall updates. You will be questioned if you want to reinstall factory version. Select yes.
If that doesn't work back up and reset tablet.
Apr 21, 2014 | Proscan Recertified - PLT7035 4GB NAND...
I dis a factory reset on my Proscan 8 PLT8235G tablet. Now, I can't install or update any apps. What do I do to fix this?
Not being able to update any apps simply means either you don't have access to the internet or that your apps update is programmed to function ONLY when you are connected to/through WiFi.
second, you can download standalone 'raw' apk files online and install on your tab.
Remember to go into your Settings---Security (and under Device administration, check 'Unknown sources' and activate 'allow installation of apps from unknown sources'.
This is safe.
Post update or feedback please
Mar 06, 2014 | Proscan 8 4GB Android 4.1 Tablet
My meep wont play youtube its showing a black screen
First suggestions would be to check that your firmware is current (latest version is 2.1.3) and to install an AppKiller program. If your Meep is full, you might want to consider a factory reset (done through the Settings menu) to clear out any file corruptions. Other than that, this is a matter for the OSI call center.
Jan 23, 2014 | Oregon Scientific MEEP Kids Tablet
Kocaso M1070 turns on goes to bold android screen and hangs please can anyone help my 6year old is heartbroken I bought the tablet from mighty deals in June when I had the money and gave it to my son...
Anyone from Kocaso, or anyone who owns one of these please jump in and correct me, please!
I suggest first trying the toll-free help for Kocaso: 1-866-777-0079. They are open M-F, 9:30am-6pm EST. Follow exactly the help instructions from that person first! Ignore the rest of this!
Do you know what your son did to induce the error--if anything? Do you still have the manual? Have you tried soft and then hard reset?
Use your PC/Laptop/Mac--not a tablet--to navigate to these links and downloads.
I've done some searching: Manual--Download from this link and open the PDF file with Adobe Reader on Windows. (If you don't have Reader installed, the most current version is a free download at
Firmware Upgrade: Their manual doesn't appear directly to indicate how to perform a hard reset without upgrading firmware. Telephone support should instruct well about that, though. See the manual on page 13--that's likely your tablet's problem! That refers the reader back to "Should I perform a firmware update?" on page 12.
I hope that firmware update isn't required: It may prove very risky--perhaps making your tablet useless.
Note the screen picture on page 9 of the manual: "Backup and reset"--if you can navigate to that, click navigate further in the menu to "Factory Data reset" (that's what my Android 4.0 tablet indicates, anyway--it's likely the same wording). Execute, (and, click "Yes, etc.") if possible: It likely isn't possible, is it?
Here's the firmware update site for the 1070 models: The procedure is somewhat involved, yet not impossible. Actually, two versions of the 1070 tablet exist--1070A and 1070B. You need to determine which one is your's. Definitely click and read "Serial Number Checklist.txt to help determine which firmware update to use. It appears somewhat ambiguous with one model. Again, telephone support ultimately should prove correct here, in your case.
Yet again, talk to a person at Kocaso first, always ignoring all of this, if possible!
I'm making a guess here: Note step 2 of the "Firmware Update Instructions.
"Turn off the tablet."
Then "Press the Volume + button of the tablet and keep it pressed. "
That point in the process likely should offer an option for factory reset, given that you can't navigate your tablet's "Settings" menus. Navigate on that screen and execute--clicking "Yes," or otherwise affirm.
Try to get in touch with the company! Online, they provide a form in 'Contact Us"--use that in place of calling, if necessary.
Dec 16, 2013 | Tablets & eReaders
Tablets & eReaders Logo
19 people viewed this question
Top Nextbook Tablets & eReaders Experts
Nhat Nguyen
Andrew Taylor
Andrew Taylor
Are you a Nextbook Tablet and eReader Expert? Answer questions, earn points and help others
