Question about Walthers Ho-athearn-5506-freightliner Tractor-hertz
No start ECU 140 - Walthers Ho-athearn-5506-freightliner Tractor-hertz
ECU Fried? 2004 toyota highlander.
Hello! The circuit is protected...First by a 12 GA Fusible link (White)...It feeds two other fuses a 30 Amp and a 140 Amp...I doubt the link is burnt open but those other two fuses are more than likely blown...Follow the positive cable to the box...Guru...saailer
May 07, 2012 | 2004 Toyota Highlander
Bernina 140 which has a sqeak in its Handwheel How do I fix it
it's sounds like the machine needs to be serviced when they start sqeaking or making odd noises
Mar 06, 2012 | Bernina Activa 140
Battery went dead changed it now no power inside the dash is dead only air bag light no radio no a/c no windows no alternator truck starts i touch a hot wire to the ecu fuse inside of truck and everthing...
Hook the battery up or try to jump-start backwards did we?
The ECU fuse gets it's power from the 140 Amp (or 180 Amp, depending on which engine your vehicle is equipped with) ALTERNATOR fuse in the engine compartment fuse block.
Sep 03, 2011 | 2007 Toyota Tundra
I've changed the injector on my friends 55 plate passat 2.0 140 and it fired up then cut out. Do i need to bleed the system / pair the injector to ecu or something else? tried several times but...
did you disconnect the battery?(you should have)if so unlock car with key/hold over windows go down,then unlock/hold key over,windows go up,then press/hold the unlock button on the remote,then jump in and start the car.(that is, assuming you connected up the injectors correctly)
Jan 24, 2011 | 2006 Volkswagen Passat
Battery changed on 2002 toyota camry, speedometer pegged at 140
Try disconnecting the battery again, only the + side. Wait for 3-5 min before hooking back up. Turn the switch on but not over, then start the car after a few seconds.
Jul 16, 2010 | 2002 Toyota Camry
I have a Passat TDI 140 SE saloon '06 plate, the MPG readout on the dash is playing up, it's showing random numbers constantly anywhere between 30 MPG to 170 MPG ( I wish haha) then seem's to reset (3...
The info that is gatthered on your display is taken from the engine ecu which is calculating average mpg, average distance, how many miles left in your tank etc. The only faulty part is your dash insert (speedo clocks). As you probably gather all the info is gathered electronically,from your throttle movement to the altitude of the vehicle which along with many other statistics is calculating your mpg, it wont be your ecu or would experience more seroius problems, so I am betting on your dash clocks,but get it diagnosed before spending money, hope this helps.
Mar 22, 2010 | 2007 Volkswagen Passat Sedan
Golf gt tdi 2.0 140 bhp mk 5 - esp light
When there's something wrong with the brake pressure that handbrake warning light comes on.
The ESP warning light could be caused by a lot of things, but most likely it's a dirty fuel filter. Don't take my word for it though, just go to the VW dealer and have it read the faultcodes from the ECU, which should point you/them in the right direction.
Alternatively, when you have the right equipment (= VAGCOM + cable) and knowledge, you or a friend yould diagnose the ECU yourself.
From the sounds of it, you'll need a small service (air filter and oil filter change, etc.) anyways. Don't forget to reset the ECU (or dis- and reconnect the battery) afterwards to erase the faultcode from memory (when there's still something wrong, it'll return soon enough).
You might get lucky with a small service :)
Aug 07, 2009 | 2001 Volkswagen Golf
Peugeot 307 model 2005 its speed does not exeed 140 km / hour why ?
depends on your model and engine. mine does on empty motorway max. 150 km/h and on hill/slop upwards 120km/h. If you let reprogram your ecu for performance may be you'll gain more speed (google it for ecu reprogramming and you'll find more infos).
Nov 20, 2008 | 2005 Peugeot 405
Walthers Ho-athearn-5506-freightliner Tractor-hertz Logo
69 people viewed this question
Top Walthers Toys Experts
ray gallant
Are you a Walthers Toy Expert? Answer questions, earn points and help others
