Question about Serta Furniture
Lift mechanism not working - Serta Furniture
Air bags for the suspension in my 2006 Envoy XL Denali has been replaced and it still doesn't lift up. What's wrong?
could be a faulty component in the kit supplied to the mechanic
is it a four bag kit ?
mechanic will have to miss his lunch till he sorts it out
Oct 27, 2016 | Cars & Trucks
2000 Mercury Villager, third row bench stuck
you will have to take the mechanism apart and reseat the spring or replace the broken part.
May 29, 2014 | 2000 Mercury Villager
GMC Acadia Power Lift Gate Not Working
Will require a scan tool to check for codes, make sure latch is working well, make sure release switch is getting signal. Most common concern is the latch itself though
Jan 19, 2014 | 2008 GMC Acadia
What is a jack lift?
"A jack lift is a mechanical device used as a lifting device to lift heavy loads or apply great forces. Jacks employ a screw thread or hydraulic cylinder to apply very high linear forces.
A mechanical jack is a device which lifts heavy equipment. The most common form is a car jack, floor jack or garage jack which lifts vehicles so that maintenance can be performed.
More powerful jacks use hydraulic power to provide more lift over greater distances. Mechanical jacks are usually rated for a maximum lifting capacity (for example, 1.5 tons or 3 tons)." (Wikipedia)
Oct 07, 2013 | Hoisting
Kitchenaid stand mixer bowl lift not working
Yikes!!! How old is your mixer? In most cases in a bowl lift model, the plastic lift mechanism breaks. It is not hard to fix or get fixed the parts are inexpensive and it is totally mechanical not electrical to fix. Go to kichenaid.com and then click on support the drop down menu will give you a selection to get manuals and user guides, click that selection, then you go to a page that will ask you for model number, look under your mixer and use the model number on the white sticker. you will be able to download the parts list for that model. The parts list will show how the lift mechanism operates and how the parts go together. the next page will give you a part number for the parts involved in the lift mechanism. Now go on ebay or amazon and type in the part numbers that you need, you will find almost every part involved in the lift mechanism, Now get a screwdriver a punch and a non metal hammer, once you have the part list and you see how it goes together you will be able to disassemble the lift and repair. you can fix it for about $15.00 and an hours time. That does not include the wait time for parts shipping to you, that will take about a week. You can also call kitchen Aid and see where your nearest approved repair center is and take or ship your system there, "for the price of your first born". But while you are there you can buy the parts that you need. There are not a lot of authorizes centers around every corner. if you have a warranty definitely call Kitchenaid, they have one of the best "No Hassle" exchange for another mixer programs in the biz. The negative is that it ABSOLUTELY ends on day 365 of your one year warranty.
Sep 13, 2012 | KitchenAid KSM150PS Artisan Series Stand...
Hp laserjet 4250dtn tray 2 & 3 will not lift
Any message appearing? like 60.X ? '*Open 'tray two' check 'open message (if No check switch 102) YES '*remove tray2 lift drive mechanism(RM1-1074-000CN) check is it working? YES '* check tray mechanism is it engaging to the lift mechanism? '* check connector/cable of lift drive motor* if not working replace lift drive mechanism '* mechanism is good replace DC controller.
RM-1074-000cn
Sep 06, 2011 | HP 4250dtn Monochrome LaserJet Printer
Chevy uplander rear liftgate will not unlock
The tailgate on my 2008 Chevy Uplander refused to open. The unlock fuse was fine. The handle pull worked fine. I could even hear the little motor that unlocks the tailgate whirr when I pushed the unlock button. But the gate would not release. Turns out the problem was the lock mechanism was jammed because it had dirt in it and not enough grease. From the inside, I pulled the lift gate panel out at the window so I could look down and see the lock mechanism at the bottom of the lift gate. I reached down and prodded it with my screwdriver until I noticed that parts of the mechanism weren't sliding back and forth like they should. I sprayed it with a silicone lubricant until the parts started working again. Finally, the lock unlatched and I could open the rear hatch. I could then remove the entire plastic panel and remove the lock mechanism. I found that the mechanism has lots of rubber and plastic parts which get chewed up and start to jam if not properly lubricated. I cleaned out the dirt with my silicone spray and thoroughly lubricated all the moving parts. The latch now lets go of the post very easily, and the lift gate no longer gets stuck.
Nov 19, 2010 | 2005 Chevrolet Uplander
Where are the chrysler pacifica 2006 lift points for lifting it up onto a hoist.
VECHICLE LIFT POINTS IS WHERE FACTORY TIRE JACK GOES. WHERE YOU SEE NOTCHES IN FRONT AND REAR ROCKER PANEL.THATS THE LIFTING POINTS TO KEEP CAR CENTER GRAVITY.IF NOT SURE GO TO A GARAGE THAT HAS LIFT.ASK A MECHANIC OR TIRE SHOP THAT HAS A LIFT. THERE A DRIVE ON LIFTS AND DOUBLE POST COLUMN LIFTS YOU HAVE TO USE FRONT SUSPENSION AND THE REAR AXLE HOUSING TO SUPPORT VECHICLE.FOR SAFETY SAKE CHECK AROUND FIRST DONT GUESS I HEARD OF A MECHANIC LIFT CADILLAC ON COLUMN LIFT. DID NOT HAVE VECHICLE TO CENTER OF GRAVITY.CADILLAC FELL OFF LIFT CRUSHED HIM. SO IF YOU DO HAVE A COLUMN LIFT FIRST TIME USING IT LET GARAGE DO IT.YOU EITHER DAMAGE VECHICLE OR GET FATALLY HURT.
Nov 14, 2010 | 2006 Chrysler Pacifica
Dual 1218
What happens if you lift the tonearm and slowly move it over its travel in toward the label area past the expected point at which it should cycle? There should be a mechanical click as it engages the lift / return cycle. If so, the mechanism works but might be out of adjustment due to wear and tear.
Perhaps cycling the Record Size switch a few times might have a positive effect on the function. There doesn't seem to be a user adjustment for the end of play cycle.
You can get the manual for free after you register at:
http://www.vinylengine.com/library/dual/1218.shtml
If you decide to venture into the mechanics be cautious, always protect the tonearm from damage and make sure you rotate the platter only clockwise as there are mechanical interlocks that could get damaged if you turn it the wrong way.
Mar 09, 2010 | Technics SL-1200 Turntable
The roller for pulling paper into the printer is not grabbing paper. Can that roller be replaced?
Yes, it can be replaced. However, you may be able to clean them really well with a little Isopropyl alcohol on a soft cloth to restore their "grab." Also, you may want to be sure that the paper lift mechanism is working correctly as well. The paper lift mechanism actually lifts the edge of the paper and presses it against the rollers to help feed the paper into the paper path.
Jan 07, 2010 | Epson Stylus Photo R1800 InkJet Printer
Furniture Logo
76 people viewed this question
Top Serta Furniture Experts
David Payne
David Payne
Tom Chichester
Bobby Lewis
Bobby Lewis
Are you a Serta Furniture Expert? Answer questions, earn points and help others
