Question about Video Cameras
Verif.patilha prot.contra esrita - Video Cameras
Yamaha RX-V463 turns on and off after 3 sec
try the reset again and watch the display. is should say something along the lines of: PS PROT, DC PROT, or I PROT.
Mar 06, 2016 | Yamaha Audio Players & Recorders
The screen takes forever to change & the resolution is very faint
check the phn setting menu where you will find contras option it will help you to bring it normal contras. thank U!
Sep 22, 2013 | Cell Phones
What is contra entry? how it is done?
Contra mean to contradict or place an opposite.
A contra entry is issued to the books by placing a negative amount in the dr column.
Mar 04, 2011 | Computers & Internet
When i turn on my Samsung HT-C550 IT showing PROT and DVD turn off. What this is mean PROT?
PROT means that the AMP is protecting itself from damage due to bad or incorrect wiring or damaged and or incorrect speakers. Check your wiring and speakers.
If you find no problem then, DISCONNECT YOUR SYSTEM FROM THE POWER, disconnect your speaker wires...all of them, then reconnect the power ONLY, turn on the system and see if it still says PROT. If it does then your amp is damaged.
Feb 20, 2011 | Samsung HTC550 Theater System
TENGO UN DISCO EXTRAIBLE ONE TOUCH 4 MINI DE 320 GB PERO EN NINGUNA PC LO PUEDO ABRIR EN ADMINISTRADOR DE DISCOS ME APARECE SIN ASIGNAR Y AL INTENTAR ASIGNARLO ME APARECE PROTEGIDO CONTRA ESCRITURA mi...
Hola. Hablo Ingl?s. Mi espa?ol no es muy bueno, pero har? mi mejor esfuerzo. El problema s que el disco est? protegido contra escritura. La ?nica manera de conseguir m?s all? de que es encontrar el equipo que se utiliz? por primera vez con el disco y tratar de desactivar la protecci?n contra escritura. Si eso no resuelve el problema, entonces yo siento, y por favor no me dan una baja calificaci?n, como algo que fue mal traducido probable.
Feb 11, 2011 | Maxtor OneTouch 4 Plus 500GB External USB...
Samsung ht c550, enciende, saluda, lee y aparece el mensaje PROT y se apaga.
when i turn on my Samsung HT-C550 IT showing PROT and DVD turn off. What this is mean PROT?
Oct 11, 2010 | Samsung HTC550 Theater System
How to unlock the code of contra
The Contra Code, also known as the Konami Code, is used in most konami games, and is Up,up,down,down,left,right,left,right,B,A, then start or select, depending on what game it is. for Contra, It would be start
Jul 06, 2010 | Nokia E51 Smartphone
HT-Z320 displays PROT code and then shuts down
i had the same problem a prot display then it would shut down. turns out i had the sub disconnected(noise complaint from the shaking at my apartment complex) but the speaker wires for the sub connected to the amp or central unit. when i disconnected the sub i left the wires on the floor behind the sub separating the pos. and neg. somehow the wires got moved around and the pos was touching the neg. as soon as i noticed and fixed this problem the system was working fine. my samsung hometheater model is HT-BD1250
Dec 29, 2009 | Samsung HT-DB120 System
HP PSC1510 PAPER JAMS
verifque o mecanismo de tracçao do papel esta limpo.se estiver verifique se a patilha que esta qao lado da servic station esta paretido
se estiver nao ha nada a fazer se nao a troca dess patilha
May 15, 2009 | HP PSC 1510 All-In-One InkJet Printer
Video Cameras Logo
13 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
