Question about Tefal ActiFry Deep Fryer
The paddle is not turning
The first time I used it, the paddle turned automatically and continually moved the fries around. When I put fries in again a and turned the machine on, the paddle did not turn.
The device on the bottom of the bread pan appears to be locked and will not turn to knead the dough. Is there anything I can do? It worked fine the last time I used it.
The synthetic seal around the shaft which DRIVES the paddle is fried.
I need a replacement to fit on the shaft OR if necessary 2 new shafts with NEW seals
Feb 28, 2011 | Breadman TR2200C Ultimate Bread Maker
My Toro 221E, model 38582 is 3 years old. It ran great this morning (blizzard, 14" snow). When I got home from work in the afternoon to continue, it started fine but when I engaged the paddle to...
Hi, will try to help. This sounds like there is ice or debris that is in around the paddle or the auger preventing to turn at full speed. Without the blower running, look all over around the paddle and auger and get out anything that might be in there. I think that is the problem. This has happened to me many times, and have repaired many like that. I hope this helps you out. All the best and good luck.
Feb 02, 2011 | Toro Garden
My timer manual switch works,it turns the outside lights on and off. However the automatic dial,even when plled out and set to time to operate does not work.What 's going on? Isit me?
The two tabs are for On ad OFF.
One is slightly longer than the other. If the OFF tab is in the ON location, it won't work, it'll just click past the time and not flip the paddle to ON.
Try this, turn the dial (NOT pulled out) around slowly and see if it flips the paddle to ON. Keep turning it, slowly, and see if it flips to OFF.
If it works while you're "helping it" then it should work automatically. If it doesn't, maybe the gear is damaged and it can't move past a certain point.
Does the time move? Do you hear the motor running? I've seen the motors go bad. The manual flipping will work then, but the motor isn't running the clock around.
Jan 30, 2011 | Intermatic T101 - 24 Hr. Dial Time Switch...
Hi there! I've been using my toastmaster model 1142 bread maker a lot lately like almost every day and it has stopped mixing the dough. Once the dough is dense the motor sounds like its running but the...
Pull the pan out and turn the little paddle with your finger. Is the paddle slipping on the spindle? If yes, then your paddle is worn out. If you move the paddle around and it doesn't slip on the spindle then look to see if the ears on the bottom of the pan are turning too when you move the paddle. If yes, then your problem is further down in the machine. You may have a slipping belt. Those are some of the things you can check.
Nov 07, 2010 | Toastmaster 1142 Bread Maker
The machine gets warm but the paddle doesn't turn.
Hi, The paddle should turn freely by hand with the bread pan out of the machine. Make sure the pan is inserted in the machine correctly. If the motor shaft turns but the paddle doesn't then the sealed bearing that the paddle rotates on has failed and is frozen so the paddle does not turn.. You may need a new bread pan. Hank
Jul 01, 2010 | Kenmore KTR2205SPR Bread Maker
Why did the kneading paddle on my 1148X bread machine quit working. This happened the third time it was used. It did the initial mixing and resting. When it started the kneading process again, the blade...
Hi, If this is the third time using it, it could be defective. Return it for service. If not under warranty, try a few things. 1) Make sure the pan is inserted in the machine correctly. 2) Make sure that the paddle is not sticking, or the sealed bearing on the bottom of the bread pan is not broken or frozen. (Take pan out and see if you can turn the paddle freely by hand). Or finally, the belt may be loose and slipping, especially when it takes more power to knead the dough the second time. Good luck...Hank
Jun 12, 2010 | Toastmaster 1148X FastBake Bread Maker
I have the Black and Decker All-In-One Deluxe Automatic Breadmaker B1600 Series and it's worked well for years. Today I put the ingredients for a loaf in the bread pan and when it started to mix the paddle...
There is a sealed bearing in the bottom of the bread pan. The paddle sits on the sealed bearing shaft. Over time the bearing begins to fail and the paddle does not turn freely or it may even freeze up. If you are sure everything is installed correctly this may be the problem. See if the paddle moves freely by hand and is not really loose. Sealed bearings can not be replaced. Eventually you will need a new bread pan. Sorry Hank
Apr 21, 2010 | Black & Decker Bread Machine
Is the paddle supposed to turn all the time?
This just popped up on my screen. Are we talking about a ide cream maker? IF yes ... generally, the can revolves around the paddle. The paddle doesn't move.
Hope this helps.
Sep 06, 2009 | Magimix 2200 Gelato Chef 1.03 Quart Ice...
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
Tefal ActiFry Deep Fryer Logo
22 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Oscar Netto
Oscar Netto
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
