Question about Fitness Quest Edge 482U Upright Exercise Bike
E1 code beeping - Fitness Quest Edge 482U Upright Exercise Bike
My mass 6 Bosch washing machine is locked up and was blinking in red light letter F what do I do
"Sd" - (Excess suds)
F8 followed by E1 - (water supply error)
F9 followed by E1 - (drain pump system error)
F5 followed by E2 - (door will not lock)
F7 followed by E1 - (motor drive error)
"rL" - (remove load)
Washer making error beeps - Door has not been opened and closed for at least 3 cycles
Washer beeps when HOLD TO START is touched - Door not closed
F# E# code other than as described above appears in display - System Code Error
"nt" (interrupted) - Cycle was paused or cancelled
Clean Washer LED flashing at end of wash cycle - The washer has run 30 wash cycles and is indicating a reminder to run the Clean Washer cycle https://removeandreplace.com/2015/05/05/washing-machine-error-codes-front-and-top-load
Sep 21, 2017 | Bosch Washing Machines
I'm getting an E1 f5 error code and my oven won't light
The F5-E1 error code means that their is a problem with the switch on the self clean door latch...it (the switch) is telling the control board that the door is locked even though it may be open so it will not let the oven come on
GENE
Nov 14, 2011 | Whirlpool SF325 Gas Kitchen Range
My WhirlpoolModel SF379LEK display shows an FS, E1 code and beeps. Any Ideas? Thanks for any help
Hi
Error code F5-E1 indicates that there is an issue with the door latch switch assembly; if the switch tests open then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jul 29, 2011 | Whirlpool RF378 Electric Kitchen Range
My unit shut off now displays E1.
Sharp updated the procedure for resetting the E1 code.
1. unplug unit
2. hold the Power button while plugging the unit back in
3. keep holding the Power button until the unit beeps
4. unplug unit again
5. plug it back in and it should be good
Here is the updated user manual
http://www.sharpusa.com/downloads/archives/product_manuals/air_man_AFS100FX_S120FX_S125FX_R100FX_R120FX.pdf
Jun 05, 2010 | Sharp AF-S120FX Air Conditioner
Whirlpool Gold Electric Oven F5 E1 code on bar code
For some reason I get the same error code every time we have a power outage. If you push and hold the "lower off" button for about ten or 15 seconds it will unlock and reset. Hope this helps.
Jan 26, 2009 | Whirlpool GBD307PDS Electric Double Oven
Problem codes for self-cleaning ranges
My experience (Kenmore Ultra-bake Model 665-72002102) was that E1 F5 meant an error with the oven lock switch. In our case, the latch was partly stuck from food or other debris. Just moving the latch back and forth loosened the scale that was making it stick, and it worked again.
Dec 05, 2007 | Kitchen Ranges
Fitness Quest Edge 482U Upright Exercise Bike Logo
26 people viewed this question
Top Fitness Quest Cycling Experts
colinat108
Tom Chichester
Donald Ayers-Marsh
Are you a Fitness Quest Cycling Expert? Answer questions, earn points and help others
