Question about Kenmore Elite Oasis ST 6806 Electric Dryer
Squeking bearing on Oasis dryer - Kenmore Elite Oasis ST 6806 Electric Dryer
Need to replace bearing in dryer
Pretty easy fix. Check out my home video:
More:
Manual link and more HERE
Nov 06, 2012 | Dryers
My dryer has a bearing squeking somewhere on the back. i have tried to locate but was unable to find bearing. can you please help me with this problem. thanks
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 24, 2011 | Maytag Dryers
The dryer has a very loud shrieking squeking
Hi dear.It's bearing problem & needs to be replaced.I hope that helps.Thanks.
Feb 13, 2011 | Dryers
The dryer is squeking very loud when turned on
Hi
Check white pulley on idler arm. Also check condition of the four glides around door bearing. A dry rear bearing ground strap will cause an annoying squeal also. Lubricate with a high temp grease to stop noise. Have to pull the drum to get at it. Check the rollers if its worn or not.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Feb 01, 2011 | Dryers
Dryer is making loud squeking noise. changed rollers did not fix problem
Sorry to read about your problem, I hope this helps you out.
you must have a drum bearing issue
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Dryer making a squeking noise
That squeaking noise means trouble is ahead. I suspect your main drum bearing has worked its way through to the metal bracket.themobilian_485.jpg I have a repair pictoral HERE
Dec 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
My dryer has a squeking noise when drying clothes. I do not have a manual to look at. Thank you.
chances are the rear bearing sleeve needs replaced or lubricated...parrt is very cheap,but kind of difficult to install w/out prev. experience....should be repaired for less than 120.00 if service company is honest
Mar 10, 2010 | Hotpoint NVL333EY Electric Dryer
Very loud squeking from dryer
Most of the time that dryer drum bearing WE3X75 is the problem. You need to remove the drum to replace it.
Feb 08, 2010 | Dryers
I own a FP dryer model DE08-US1, and it is making a high-pitched squeking noise and smells like burning rubber--please help.
I suspect your drive belt is slipping or a worn bearing, you need to have this checked by a Qualified serviceman. Get a firm "Quote" before proceeding.
Jan 31, 2010 | Dryers
Kenmore Elite Oasis ST 6806 Electric Dryer Logo
18 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
