Question about Garden
Toro snowblower 726 TE problems
I have tried to start it with the 110 volt starter and the pull rope too. I just will not fire with or without choke and priming, has new gas with proper oil mix 50:1 it started good in November what could be the cause
SOURCE: i have a toro ccr 3650 snowblower the electric start just grinds
This problem has been solved! I took the covers off the machine, removed the starter and eventually replaced the drive. Apparently the drive parts were put on back ordered and took about 4 weeks to get the drive set. One thing I suggest if anyone does this is to look at the fly wheel to insure it's in good working order. The dealer I worked with said often that is chewed up (the teeth on the fly wheel) and leads to a bigger headache. Fortunately mine was just fine. The machine now works likes like new as I put in a new spark plug as well!
Posted on Mar 24, 2009
  • 35 Answers
SOURCE: Featherlite will not start
first never let any one browe your tools or your wife thay could break eather of them noe get a small screwdriver find the air adjutment screw on carb turn it in count the turns till it stops then pull it out by turning it counter clock wise dont louse any spring that might be there its out get carburator chock cleaner use the little tube put it in hole were the screw lived at and let it have a good blast or 2take out spark plug and pullthr start rope 10 or 15 times put plug back put air screw back 1 3/4 out from bouttom i think if you had dif number try it first if that dont fix it you may need to take carburator off take it apart and clean there is two gas lines that go to tank if one of the lines has a filter on it inside the tank if thay get water in there threeeere pluged up might get new one there fun to get out of tank or take to shop if you dont have all the tools or homedepo and buy good luck
Posted on Apr 09, 2009
  • 81 Answers
SOURCE: Oil causing a problem?
Sound as if you have too much oil in the machine. Anytime you see white or lite gray smoke it is a sign of too much oil. Before you go through the routine of cleaning the oil out of every nook and cranny, try unscrewing the spark plug and clean it with a soft rag. It would have oil on it preventing the machine from starting. If this does work and there isn't a lot of oil in the gas tank now, just continue running the engine until the smoke clears. It won't hurt anything. But if cleaning the plug doesn't help you will have to empty all gas and oil from the gas tank, refill with new gas, squirt a little gum out carb cleaner in your carb to remove any oil there (this can be done when you try to restart the engine). Remember, when you are mowing grass if you are mowing on a hill) of any knd, make sure to turn the mower so the gas tank is on a higher level than the oil.
Posted on Jun 19, 2009
#1 Taper
  • 1041 Answers
SOURCE: Mighty Lite Blower won't start
Check the fuel lines for cracks/breaks. If they are o.k., then:
You willneed to disassemble the carburetor and spray with carb.cleaner.Makesure the small screen is free of debris. (Should be able to see daylightthrough it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Nov 27, 2009
  • 122 Answers
SOURCE: Toro CCR 2450, Common starting problems? Fresh
Next step would be to check the ignition module(coil),I have a lawnmower that uses the same 2 cycle engine. Check coil for spark by removing the spark plug from the block then connect the insulator side of the sparkplug back to the coil then ground the plug by touching the threaded side to the block away from the sparkplug hole while turning the engine over. Should see a spark, if not you'll need a new coil,not hard to replace. calls for Briggs & Stratton #80-1268 you can also use a Toro/Lawnboy coil #99-2911 or #99-2916 or #684049.
Posted on Feb 02, 2011
Toro Powerlite Snowblower Starter rope kick back
Yes, it could be, but at least check one other thing.
Pull the spark plug and leave it out of the machine.
Then, pull the start rope and see how it goes.
Does it seem ok then?.
Now, reinstall the plug and try it.
Some people were never told to be sure the spark plug is elevated whenever the machine is stored, for any length of time.
If not, and the spark plug is lower than the crankshaft oil level, the oil can by-pass the rings on the piston whilst it is sitting and give you kick back when you pull the rope, because that oil in the combustion chamber is not compressible.
God bless your efforts.
Feb 22, 2018 | Garden
How do I adjust the belt ona Toro 726 snowblower
There should be a tension pulley between the main pulleys. Usually it is mounted on the side wall and can be adjusted with a nut and bolt.
Mar 16, 2016 | Toro Power Max 726 OE Snowblower - 37771
Pull starter won't pull
ALL-- Power Equipment-- needs to be inside & warm,
NOT in an outside shed
Have to warm it up inside-neighbors garage!
Feb 28, 2014 | Toro Power Max 726 OE Snowblower - 37771
Problems shifting toro power max 726 oe snowblower
adjust the cable easy to do , get the manual or just look good at it ,
Feb 04, 2014 | Toro Power Max 726 OE Snowblower - 37771
Toro Electric Start Problem
Remove spark plug and observe condition. Fouled with oil, bad motor. With plug removed pull rope several times to blow out cylinder. Spray WD40 in spark plug hole, pull rope several times see if oil blows out. Spray a lot of starter fluid in spark plug hole, replace plug. Spray starter fluid in air cleaner area of carb, try to start. Replace spark plug, try to start. Ensure oil is full, all mowers have a low oil sensor now. 30w oil. Always use Stabile in gas.
Jul 04, 2012 | Toro Garden
Can't get fire on old snowblower TORO 8HP / 32"
te fly wheel is rusted over the magnets remove cover and sand the wheel at the magnets space should be about busnes card thick between the coil and magnets
Nov 03, 2009 | Garden
Pulled choke and power swith is on, keep trying to pull the cord and stll won't start,yes it has gas
hi , try this, take the spark plug out. and leave it out for awhile ,to dry out.1 hour,clean plug ,put it back in the machine.then take the air cleaner off, make sure it is clean for later,get acan of aerostart or starter fluid NOW SWITCH ON, CHOKE OFF THROTTLE IN START POSITION''''' FULL THROTTLE ,AQUICK SQUIRT OF AEROSTART INTO THE TOP F THE CARBY AND PULLTHE START ROPE 3 OR4 TIMES NO MORE ,THE ENGINE SHOULD FIRE OR START;;;; if it does not at least fire you may have to try anew spark plug,if it fires but does not start, pu ll the choke out 1/2 way and pull 1 or 2 times only or you may flood it again,giv it another squirt in the carby and try again but dont keep pulling the starter as you will get crankey when ite rope breaks .if it starts let it run for afew minutes stop it replace the air cleaner 1/2 choke pull the starter should go push choke rightin after a couple of pulls start it and go to work.Please if this doesn`t work come back and tell me what happened for we may have to make a couple of adjustments
Aug 12, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
