Question about RCA RP5440 Clock Radio
Set the alarm on RCA rc-40-b - RCA RP5440 Clock Radio
Rca 21k8. Insufficoent height
Warning!!!!!!!!!!
Do not adjust anything else only Vertical amplitude .1.1. The way to enter P-Mode a) Method one A) Switch on the TV set. B) Press the "MENU" key on RC to show the "PICTURE" OSD menu. C) Move the cursor to "Contrast" item then press the "9", "7", "3", "5" key continuously on RC within 3 seconds then enter P-Mode. The "P" letter will appear on the left low corner of the screen when enter P-Mode. China TV 21F1 NX56E LA Service Manual
Nov 25, 2016 | RCA Televison & Video
Panasonic clock radio RC-6099 How to set the time
1. Press and hold button on top front marked: "Time Set" (also has "OFF" above it) 2. Using LHS buttons to go forward or reverse as marked press and hold until correct time is displayed. Middle button here will move it fast then release and use single button when closer. To set alarms either the Alarm 1 or 2 (also marked "Display/Adjust" held down while using the side buttons as before.
Oct 24, 2012 | Panasonic RC-6099 Clock Radio
I need owners manual to program RCA RC140-A alarm clock
Hello
Send your Emai Address to me. I've the user manual for your RCA RC 140. I actually do not remember, from which site did I downloaded it. I can't send it to you by this window, as it does not allow me to upload PDF fiels by it. If you send your Email ID, I'll send a copy of it to you by return mail. OK.
Nov 27, 2011 | RCA Radio Alarm Clock
How do youn set the alarm clock
http://www2.panasonic.com/consumer-electronics/support/Audio/Portable-Audio/Boomboxes-Radios-Clocks/model.RC-CD500
click on this link for the manual
best of luck
Sep 21, 2010 | Panasonic RC-CD500 Clock Radio
I'm using my dad's old Panasonic RC-6064 alarm clock. How do I set the time and the alarm?
The Hour/Minute buttons are on the bottom of the radio. Just press the hour or minute buttons to adjust the regular time. Alarm is the same but you hold the alarm button on top.
May 18, 2010 | Vacuums
Setting the alarm on my clock radio
use the selector switch on the top, switch it to wake 1 or wake 2. set the time that you want that alarm to go off. then push the switch all the way back to the left to deactivate it. then to activate the alarm, use the buttons on top labeled wake 1 or wake 2 to turn the desired alarm on. pushing that button repeatedly will cycle the alarm to either beep, radio, or it will turn that alarm off.
Oct 21, 2008 | RCA RP5440 Clock Radio
CD500 Clock Radio Problem
there is a button that says alarm hold it down as well as the minute and hour buttons to set the alarm you must hold down the alarm button and only use min or hour not both at once
Feb 24, 2008 | Panasonic RC-CD500 Clock Radio
Clock settings
- Please let us know the make and model number so that we can try to find the user manual for you. -
Oct 02, 2007 | Panasonic RC-6299 Clock Radio
RCA RP3721 Alarm won't shut off
To turn alarm off completely, press WAKE1 and WAKE2 until the bell-shaped indicators go off.
As for resetting the alarm (buzzer), press SET WAKE/CLOCK untill SET and WAKE! light.  Press left- or right+ arrow to set time.  Press WAKE1 until bell-shaped indicator comes on.
Jun 14, 2007 | RCA RP3721 Clock Radio
RCA RP5440 Clock Radio Logo
21 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
