Simpson ezi sensor
When I hit start,after a couple of seconds the machine goes straight to end cycle.I have cleaned and checked the water inlets.it will not release the door.we have hard water here
SOURCE: Electrolux/Simpson EZI sensor 5.5 kg machine cycles.
Well I'm an idiot. They did say there was a fast wash, but it specified that it was for extra rinses to help people with detergent allergy etc., but did not give a time for the cycle. They should have said it was the short wash for everyone. I tried it, and it was fine. Thanks anyway. If I ever have a real problem, I'll be back.
Posted on Aug 04, 2009
  • 41 Answers
SOURCE: Simpson Aquarius washing machine 7kg: water
SOUNDS LIKE A PLUMBING PROBLEM WITH DRAIN PIPE .YOU COULD FIT NONRETURN VALVE TO DRAIN FROM WASHER BUT THAT WOULD NOT STOP SINK FROM OVER FLOWING
Posted on Jan 09, 2010
SOURCE: We are using our Electrolux/Simpson Ezi Sensor washing
also have the same machine - if you wash with the eco rinse the clothes will ALWAYS have the soap residue on them and if you use the deep rinse then this machine will just sit there doing the very occasional agitate for up to 6 hours - can't win - have only just hung out a load and as usual there are many many dry spots on the sheets which is a daily occurence - really hate this machine and it's so called u-beaut functions -
Posted on Mar 11, 2010
SOURCE: simpson ezi loader washing machine clicks 3 times
It sounds like a door switch fault see if the end light and the start/pause light are flashing count the flashes if end flashes 4 times and the start/pause once or maybe more this could be error 41, door switch fault.A door switch would cost about $ 20 but there may still be a problem with the main Programmer.
Good luck.
Posted on May 03, 2010
  • 713 Answers
SOURCE: My simpson ezi sensor wont agitate
hi just read your posting.Does the machine spin and drain?Please reply with answer and I can help you further.
Posted on Jul 14, 2012
Have Simpson Ezi loader 5.5 Is there only one water inlet valve.
there should be two inlet connections -- one for hot water (red) and one for cold (blue)
there should be two hoses with the ends color coded
inside of the fitting the screws onto the back of the machine there should be a rubber washer
that is what seals the hose onto the machine fitting
-- same rubber washer that is in any 1/2 " hose to tap fitting
Nov 21, 2016 | Simpson Washing Machines
My simpson eziloader machine won't start - when I press the start button it clunks a couple of times then nothing - water won't enter have checked the inlet pipes
sounds like blocked pump or door latch sensor/switch more likely pump blocked.thats normally first to activate in wash cycle.if unsure seek help to locate and check.it ll be either accessable from bottom front of machine or you may need to tip it up as it ll be at bottom of machine.unplug first,and if you pull pipes off pump to access there will be some water.hold waste pipe as low as itll go to release any water left in machine
Feb 21, 2015 | Simpson Washing Machines
My simpson ezi sensor will not fill on wash cycle, the water enters very slowly
Check the pressure on the incoming water pipe (make sure stopcock/isolation valve) fully open then check that valve opening fully (this may be able to be removed) will be one or the other :)
Nov 05, 2014 | Washing Machines
Simpson ezi 950 9.5 will not empty, rinse, spin dry.
That sounds like the pump is jammed. Have you checked for hair slides or similar? Once the pump is free to operate, your Simpson should resume normal service.
Feb 20, 2014 | Washing Machines
Simpson Ezi Sensor Front Loader keeps pausing during washes, doesn't put through the detergent.
you might be putting the detergent in the wrong part of the dispenser,or you might have the hose on the wrong way,or the water valve has failed. Read up on your user manual to see what happens on this part of the cycle,does the w/m empty ,then try and bring in more water?? The main give away to this fault is,detergent still in the dispenser.Check all your filters on your inlet hose and water valves.
You have to ask yourself what has changed,cheers.
Aug 14, 2012 | Simpson Washing Machines
Jul 14, 2012 | Simpson Washing Machines
Simpson washing machine 8kg ezi sensor watter wont stop running
Hi just read read your posting.Is your machine the Simpson Ezi set? If it is and the water keeps running does it at any stage while it is filling start to agitate? Or does the machine keep filling and does not start agitating?Please reply with additional information and I can help you rectify this fault. Looking forward to your reply.
May 16, 2011 | Washing Machines
Simpson ezi loader washing machine clicks 3 times then the end button lights up without even starting the cycle. does anyone have a solution for this?Solve this problem 1 2 3 4 5 6 7 This is a... Solution...
Good luck.
Apr 27, 2010 | Zanussi FS1455W Front Load Washer
Aug 03, 2009 | Electrolux Washing Machines
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
