Question about Alpine HDD Navigation VIE-X08
Navigation displays loading - Alpine HDD Navigation VIE-X08
My LG RH397D will not play a disk. It gives a navigation error.
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
    See the diagram attached.and if the problem persist. Lube the plastic parts with small grease or vaseline very carefully
Feb 09, 2013 | Televison & Video
Navsure n420i won't load
This is washers & dryers. Try posting in Nav.
Oct 23, 2017 | Washing Machines
What's your problem?
It's a bit complicated. Either the internal memory got corrupted or there is another issue. Can't really tell you which is which until i have it in my hand. But i assume is the first.
Nov 27, 2011 | Nextar Q4-06 Car GPS Receiver
I have bought a Transcend MP850 8 GB mp3-player. I have loaded it with about 1000 songs in different albums, but when I enter the Music-menu, I do not see a list of artists or albums, it just displays the...
On the right side of the player you will find a menu button just below the record button...
press and hold this button down for a few seconds inside the songs menu and you will be given a choice of song navigation or playlists...
choose song navigation and you will be able to navigate through the songs you have added..
Feb 03, 2011 | Transcend T-Sonic 850 Digital Media...
Hp leserjet 4250n network ip change solushion
Print out the current configuration of the printer, Press the Tick button, navigate to Information, press the tick button, navigate to Print Configuration, press tick button.
On the printout find the current IP address. Open a web browser and type the IP address into the address bar, press enter.
The printer setup will be loaded into the web brower. Navigate to the network configuration so you can see the IP, gateway and subnet IP addresses.
You can now change these but once you have your browser dispay of the printer will disappear.
Type the new IP address into the web browsers address bar and you should get the new configuration displayed.
Sep 03, 2010 | HP LaserJet 4250n Printer
My 2004 RX330 Navigation GPS DVD does not load
another thought is try disconnecting the battery for and hour or 2 and see if that resets it,your last resort may be (hate to say it ) dealer to look at it
Oct 24, 2009 | 2004 Lexus RX 330
2003 Accord. Navigation/radio/display system does not load.
I've reads post here suggesting disconnecting the battery for one hour. Couldn't hurt to try it.
Also try ejecting the Navi Disk, inspecting it for any damage, wait a few minutes and reinserting. The disk contains not only the navigation Database, but also part of the operating system.
DO NOT TRY INSERTING A OLDER NAVI DISK OR ONE FROM ANOTHER VEHICLE, THAT COULD DESTROY THE NAVI UNIT!!
If you need a new Honda Navi Disk, order it direct at https://www.hondanavi.com/Hondadvdsales/naviorder.php
Good Luck
May 05, 2009 | 2003 Honda Accord
07 h3 navigation
It is actually located behind the navigation screen.
Turn off the radio.
Press and hold the CD eject button until the display unlocks (about 10 to 15 seconds).
Let screen move outward and rotate downward.
Press the DVD eject button just exposed behind the display.
Remove DVD, insert new one.
Rotate display upwards and press gently on all four corners to slide and lock display back into original position.
Turn on radio, navigation DVD should start update process, let it finish.
Jan 29, 2009 | 2007 Hummer H3X
Alpine HDD Navigation VIE-X08 Logo
22 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
