Question about Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D
FORD ikon engine
Have a ford ikon 1.6 Exi model there is a unique problem the car has just been repaired new spark plugs , coolant topped up cooling exhaust fan working perfectly. The car has poor acceleration and after heating up(15 minutes of running) there is absolute loss of power. During idle RPM is steady but as you press accelerator the response of RPM is consistent but after running for some time it seems the engine is starving and RPM beyond 3000RPM starts drooping to low levels if you remove feet from accelerator it comes back to idle problem but it can not move in gear
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 116 Answers
Maybe your converter is stopped up this is just one thing could be a fuel filter
Posted on Feb 09, 2014
2 Suggested Answers
tbirdfan1
  • 3051 Answers
SOURCE: Briggs and Stratton engine stumble
Hello there:
first i would shorten the gap on the plug and if needed readjust the air/fuel mixture as per specifications
Posted on Sep 15, 2009
Cooling problem,code#P1299,on a 06 Ford Escape 2.3l
P1299 - Cylinder Head Over Temperature Protection Active Description: Indicates an engine overheat condition was detected by the cylinder head temperature (CHT) sensor. An FMEM strategy called fail-safe cooling was activated to cool the engine. Possible Causes:
  • Engine cooling system concerns
  • Low engine coolant level
  • Base engine concerns
Diagnostic Aids: Refer to Section 1, Powertrain Control Software , for more information on the fail-safe cooling strategy and cylinder head temperature sensor. Application Key On Engine Off Key On Engine Running Continuous Memory All GO to Pinpoint Test DL .
Feb 19, 2015 | 2006 Ford Escape
Engine cranks but no spark
check coil, igniton module, map sensor hose and connector, new plugs and wires/ distrubter cap if so equipped, cam or crankshaft sensor.
Dec 14, 2013 | 2005 Ford Ikon 1.6i
2001 ford taurus that wont start. I am getting fuel pressure. I installed new plugs, wires, and coil pack. There is pressure in the radiator fill tank just from trying to start the car. Is that norma
Take off the radiator fill cap.
Top off the radiator.
Crank the engine.
Are there bubbles or is there water spouting out of the radiator fill hole?
Yes: likely cylinder head gasket failure or cracked header.
No: Pressure test cooling system after topping off with a pressure tester. Locate source of leak.
Assuming the water leak isn't anything to do with the non-starting situation, which it probably is though form the sound of it, also check the following:
1) Air filter
2) Fuel filter
3) Manifold Air Pressure sensor.
4) Mass Air Flow sensor.
Nov 12, 2012 | 2001 Ford Taurus
FORD IKON 1.3 FLAIR RADITOR FAN NOT WORKING/EARTH SUPPLY NOT THEIR
that sounds like a faulty coolant temp sensor, if it fails you will have to hold the gas to get it to start and the computer will not know when to turn the fan on.
Nov 08, 2012 | Ford Cars & Trucks
Ive ford ikon 1.8d car. The engine fan starts as soon as i switch on the battery and runs till i switch off the battery. also there are sparks near the switch in the hood when i start the engine.
you need a new fan switch for the engine fan.
with the engine off and the battery cables disconnected from the battery - replace the switch.
if the ( "sparks near the switch") is the fan switch check the wires when you replace the switch.
if these ("sparks near the switch ") are another switch check those wires for frays and tighten or repair.
Apr 02, 2011 | Ford Fiesta Cars & Trucks
I have a 90 chev camaro rs since new, but since then this vehicules has the same problems, "getting hot" and hotter when getting older. I have change every detail at it and even a additional...
Inside your car's engine, thousands of controlled explosions called combustion events occur. These explosions are created by igniting a fuel / air mixture inside the engine. Spark plugs are used to ignite the fuel / air mixture contained in the cylinders. These explosions are converted into power through the engine while producing a large amount of heat. These high temperatures are controlled with the help of the cooling system. A cooling system consists of a water pump, cooling fan, thermostat, radiator hose, hose clamps, radiator, radiator cap and coolant. Engine coolant is used to transfer heat from the engine to the radiator by the cooling system. The radiator removes heat from the coolant by forcing air through the radiator cooling fins. Without coolant your engine will overheat and if left unattended severe engine damage will occur. Engine coolant colors can vary from green, orange, blue, clear and yellow each having their own unique protective and environmental properties. Coolant leaks are a common car problem that can lead to overheating; we have listed some of the most common causes below.(Always inspect engine cold to avoid personal injury) (note: coolant and antifreeze refer to the same product, in below freezing, coolant lowers the freeze point hence the name anti-freeze and in warm weather coolant help raise the boiling point, "coolant").
Troubleshooting Procedure
Step 1: Check Engine Coolant Level, Test For Leaks - Engine coolant is used to transfer heat from the engine to the radiator; if a coolant leak is present the engine will eventually overheat. Inspect the engine coolant level in the coolant reservoir tank; coolant level should be between the hot and cold marks. Always check the coolant level when the engine is cold, preferably over night. If the coolant level is not between the reservoir marks the cooling system may have a leak.
If engine overheating has occurred the coolant level will naturally be low due to expansion of the coolant from the extreme heat of the engine. This heat expansion forces coolant out of the radiator and coolant reservoir. To test for an engine coolant leak move the car to a dry smooth surface and allow the engine to cool. Remove the radiator cap and carefully (do not spill) add water until full, then re-install cap. Start engine and allow to run for about three to five minutes (do not allow to overheat) while the engine is running inspect the ground below the engine, if an engine coolant leak is present observe the location of the coolant drops, this will help determine where to start looking for the coolant leak (shut the engine off before inspecting).
If no coolant is observed two additional checks are needed for a complete test. With the engine off remove the engine oil fill cap and turn it over, if a milky oil condensation is present the engine may have a failed cylinder head or intake manifold gasket allowing coolant to leak internally. To inspect engine gaskets disassembly is required. Next, the car heater core must be inspected; the quickest way to check the heater core condition without removal the heater core is to inspect the passenger's side foot well compartment carpet for the presences of coolant. If coolant is present the heater core has failed and must be replaced or repaired. After necessary repairs have been made refill the cooling system with manufacturers recommended engine coolant and recheck operation.
Nov 24, 2010 | 1990 Chevrolet Camaro
How do I drain coolant from a 2001 ford mustang GT?
unscrew the freezeplug located on the bottom corner of the radiator
Aug 17, 2010 | 2001 Ford Mustang
1999 Land Rover Discovery II engine miss
Observe the engine running in the dark to see if there are any spark jumps from the wires or coil, you may have a carbon track.....
Feb 16, 2010 | 2001 Land Rover Discovery Series II
I have intermittant overheating problems with my 1.6 Ford Ikon which has a Rocam engine. I need the diagram of the cooling unit attached to the side of the engine as I think this is where the problem lies....
Ronnie this soun ds like the thermostat is not opening all the time. this is an easy fix. the part probably cost about 8-15 dollars at autozone, dont forget to get the gasket also.
1-2 dollars. The guy at the counter can show you where it goes
Jul 05, 2009 | Ford Focus Cars & Trucks
Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D Logo
425 people viewed this question
Top Briggs & Stratton Hammering Experts
Dan Webster
Dan Webster
John Trevino
JOHN LAPIER
Are you a Briggs & Stratton Hammering Expert? Answer questions, earn points and help others
