Question about LTD Watch Bowflex Strapless Heart Rate Monitor watch
Don't know which buttons on my bow flex strapless heart monitor to push to set the time
MIO MOTIVA STRAPLESS - My problem is that the watch is brand new out of the box, but the actual top right button (Start/Stop/-) doesn't work. Also the actaual sensors don't seem to be picking up my pulse...
Unfortunately MIO do not have repair services in Australia, probably would have to send it back to the US. Hopefully you can work with the seller to fix the issue. I know when you buy through mioglobal.com their customer service is excellent.
Mar 30, 2011 | Mio Motiva Strapless Heart Rate Monitor...
Under the settings, limits, the limits on the max HR stop @ 100. I want to increase the setting on max hr but it stops @ 100 and then returns to 18. help [polar F4]
Go into settings.
Press the center button on the right hand side of the watch 1 time you will see settings watch time & date appear in the display.
Press the bottom button on the right side of the watch1 time to get into the TRAINING SETTINGS FUNCTION.
When you see TRAINING SETTINGS in the display press the center button on the right side of the watch once.
You are in TRAINING SETTING mode.
Press the bottm button on the right hand side of the watch 3 times until you see
ZONE LIMITS displayed.
When you see ZONE LIMITS displayed press the center button on the right side of the watch 1 time to enter into the ZONE LIMITS FUNCTION.
Now, you should see the lower end heart rate limit number blinking.
To adjust this number use the top button on the right hand side of the watch to increase this limit or lower button on the right hand side to decrese it.
When you have it set where you want it press the center button 1 time to save that setting.
Now you should see the upper limit number blinking.
Follow the same steps to set the upper heart rate limit.
When you have pressed the ceter button to set the upper limit you have completed setting the heart rates limits and the display should read: LIMITS SET!
Feb 13, 2011 | Polar F4 Heart Rate Monitor Watch
I am trying to set the time on my FS1. When I go to the time mode it goes right back to the time display.
On my tips and tricks page is a link to the user manual.
The trick with the FS1 is that you have to wait between button pushes. Don't try to skip ahead of the pace of the watch, it is slow to set anything. That is the rub with 1 button operations.
Push the button, wait for the prompt, enter the info, push the button, wait for the prompt, etc.
if after trying this it still doesn't work you will either need to take it back and exchange or send into polar. There is a warranty service available. Again that link is under my tips and tricks.
Dec 14, 2010 | Polar FS1 Unisex Heart Rate Monitor Watch
I have a mio watch,installed new battery.hear rate monitor does not work,much too high
Have you contacted their customer service team? They are great at resolving issues and really stand behind their product. Their Facebook page MIOWatch also has lots of troubleshooting and FAQs too.
Nov 13, 2010 | Mio Motiva Strapless Heart Rate Monitor...
I lost the directions to my Motiva heart monitor watch. How can I find it on-line?
Thank you for contacting FixYa.<br /> Motiva is owned by Philips. You can download at the following link:<br /> <a href="http://www.healthcare.philips.com/us_en/products/telehealth/Products/motiva.wpd">http://www.healthcare.philips.com/us_en/products/telehealth/Products/motiva.wpd</a><br /> Best regards.
Aug 25, 2010 | Mio Motiva Strapless Heart Rate Monitor...
Reebok Strapless Quick Touch Heart Rate Monitor Watch (Reg. Size)
Have tried going to a watch shop ? It may sound a bit obvious, but looking at your watch and comparing it with mine, I think that a standard strap might fit.
You have nothing to loose by asking and it tends to be expensive to send them back to the makers.
Feb 16, 2010 | Watches
Sportline S7 HRM watch users guide?
To get a manual for your monitor, go to "sportline.com",
Select "products" and then "see products" in heart rate monitors.
Go through the list of models to find yours and then click on "learn more".
Details of the monitor will be shown and you then click on the tab marked "manual".
Download your manual.
Jan 27, 2010 | Watches
New battery needed and fitted to a Polar heart rate monitor
This is really easy to do yourself. Get a CR1632 battery, unscrew the four screws on the back (dont tip the watch as there is a small spring in the watch), unclip the metal band holding in the old battery noting the way 'round the battery is in (minus side up), pop in new battery and push clip back down, when re-fitting the back make sure the spring mentioned earlier lines up with the white sticker with a hole in it on the inside of the watch back, screw down the back. After you have re done all your settings you may need to re-aquaint the watch with the strap, to do this put on the watch and strap, set the heart monitoring going, bring the watch up close to the 'Polar' logo on the chest strap until the time is displayed, should now be all set up.
Andy
Oct 28, 2009 | Polar F4 Heart Rate Monitor Watch
LTD Watch Bowflex Strapless Heart Rate Monitor watch Logo
18 people viewed this question
Top LTD Watch Watches Experts
Ansel Alberto
Ansel Alberto
Are you a LTD Watch Watch Expert? Answer questions, earn points and help others
