Question about Boxlight 2002 Digital Multimedia Lcd Projector
Need adaptor 590-0201-01
I have a model-JJB052000-2509 50/60 H2 Output5V-2000mA and I need power adaptor can you help me?
pls let me know where do u live,,you need 5volt 2 ampere adaptor,,u may use 2-5 ampere also,,volts should be =5 volts,,,u can charge ur note with laptop usb connector also,,,or u can find this adaptor on amazon.com,,,ali express,,,or any other as per ur area
Jan 27, 2015 | Archos 101 Internet Tablet 16GB 10.1"...
I have a Yamaha PSRE413. on/off does not work with adaptor, but works with batteries
If you are using the correct adaptor then the most likely reason is that the socket where the adaptor plugs in has broken away from the circuit board and will need to replaced/resoldered.
if you need a socket Google : Yamaha PSR power socket ( KPA3 / PA130UK / EPA3 ) (LB30226R)
OR if you have used the wrong mains adaptor and the polarity was reversed you may have damaged the diodes / voltage regulator on the power input.
Jan 24, 2013 | Yamaha Music
Does a nintendo ds lite need the battery in to power up on just the adaptor?
The adaptor is only to recharge the battery. If you only use the adaptor without battery, I'm sure nothing will happen. You need the battery in or you can't play. But you can play with both the battery and adaptor in at the same time. It makes your battery recharge + you can play meantime.
May 20, 2010 | Video Game Consoles & Games
Laptop does not work off mains and battery does not charge
Just check the power connection from the AC going to your laptop if the power adaptor of your laptop are working. Note; you only know that the power adaptor was working if the LED (Light Emiting Diode) was light because the power adaptor are have the LED to see it that they are working normally. If the power adaptor working normally their was a problem of the power supply inside your laptop and need to be repair by the electronic service center. But if the power adaptor are not working the problem are in the power adaptor. I recommend that you replace your power adaptor and bring it to the computer store to check its type and model it is because only same type or model of that power adaptor to be replace.
May 19, 2010 | Dell Inspiron 6000 Notebook
How to use the card reader of Acer aspare 4730z? Does it need any special adaptor?
no it does not need special adaptor for sd card but some specific cards requires adaptors that comes along with it as addon
May 07, 2009 | Computers & Internet
How to fix Power Adapter
Does your adaptor geting warmer when plugged to power outlet for some time (minutes)?
If not, than there are two possible solutions:
First (the easiest) thing is to check if both wires are not cut or short (one that you connect to power outlet, and the other one you connect to your laptop). You'll need some multimer to do this.
Most possible is that you'll need to open the power adaptor to do these checks.
Second thing is to locate and check the Fuse. Most of the adaptors have a Fuse inside.
If the fuse is OK, the wires are also OK, and the adaptor is getting warmer (or not), than you should buy a new power adaptor.
My experiance sais, not to belive much to repaired laptop adaptors (you don;t say what laptop you have).
Also, do not ask for substitute (cheap) adaptor!
Find an original one!
Most important is the following:
Please note that you should't try to do these checks, if you don't feel you are enough qualified. You should ask some friend of your's or some service. It should't cost you much !
Also, if you try to do this by yourself, be EXTREMELY carefull when adaptor is open. DO NOT PLUG it to power outled !!!
You might be killed !!!
Regards.
Mar 26, 2009 | Toshiba Satellite 2210CDT Notebook
Correct Cassette Adaptor
This is likely a firmware\software issue
you need to have a specific version of EPROM FLASH ROM programmed files..
Ed
Sep 19, 2008 | Panasonic AJ-D230H DV/Mini DV VCR
Linksys router and Belkin wireless adaptor
Anne ,
I need to ask is the driver for wireless adaptor installed ?
Thank you ,
Styme = )
Jul 28, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Power Adaptor for 500GB LaCie P3 HD USB 2.0 7200RPM 8MB USA?
Both power adaptors are 4 pin, ITHINK that the Porsche that you have is the same as mine which has the smaller (4 pin DIN) plug 34W power supply.
But check on LaCie's site: http://www.lacie.com/asia/products/product.htm?pid=10857
Hope this helps.
Chris
Jul 23, 2008 | LaCie Computers & Internet
Boxlight 2002 Digital Multimedia Lcd Projector Logo
16 people viewed this question
Top Boxlight Office Equipment & Supplies Experts
jasbo
jasbo
Computer Links
Mike Charette
Are you a Boxlight Office Equipment and Supply Expert? Answer questions, earn points and help others
