Simpson encore 605
Hot water does not flow into machine
active209
  • 14 Answers
SOURCE: my simpson encore 605 beeps when you press the
problem was caused by lever mechinism under lid ,which pushes down safety lever inside top box behind electronic control pad. when lid is closed. Adjusted to suit , now machine is working fine.
Posted on Nov 06, 2009
Testimonial: "very helpful, spot on !"
  • 69 Answers
SOURCE: machine will not stop filling with water
Does machine stop filling if you discnnect from power? If it does, the problem lies with timer/control unit, or fault in pressure switch/ tube. Check pressure tube (thin rubber pipe that goes from water level selctor switch to side of outer bowl) for holes- replace if faulty. You can test pressure switch by remove pressure tube from outer bowl and blowing thru tube- you should hear the water level switch click when you blow, and then click again when you release pressure.   If it keeps filling even with power off, you have a faulty inlet valve. If you remove top panel (3 screws along top rear-power off first!!), you will see the inlet valves- one for hot, one for cold. The valve is the thing the inlet hoses screw onto. New valves availble from any good spare parts supplier, relatively inexpensive part. Good luck!!
Posted on Mar 13, 2010
Testimonial: "Exactly pipointed the problem which is now fixed Thank you"
  • 713 Answers
SOURCE: simpson encore 605 wash machine 6kg. Washer pump
Hi mark just read your posting.Now what country do you live in.If you live in Australia then I can give you some phone numbers.Regarding your machine it does sound like the control board.Probably the power supply section of the board is faulting.Please reply with additional information and I can help you further.
Posted on Jun 19, 2010
Testimonial: "Nice reply with information to put me in contact with someone who may have parts. Thanks. I await some more contact phone numbers."
blueextc3221
  • 15935 Answers
SOURCE: simpson encore 605 won't start
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question !!!!
Posted on Sep 18, 2010
mpcheeseman1
  • 1400 Answers
SOURCE: SIMPSON 816 ENCORE WASHING MACHINE ERROR MESSAGE
Hello
Try running the washer through rinse/spin cycle,then normal cycle without any detergent.
SF is suds failure,or too much detergent or wrong type of detergent.You need to use H E type detergent.
This should clear the machine out.
Posted on Apr 01, 2011
My washing machine goes fine until half way through wash then comes up with error code PU and beeps until I turn it off...will not drain out the water? Simpson encore 556
simpson encore pu Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/simpson_encore_pu
Unsolved problems for simpson encore pu question. Get free help ... My simpson encore 757 shows PU error code. What is this? ... Simpson encore 556. Aug 22 ...
Sep 10, 2015 | Simpson Washing Machines
Simpson encore 503 washing machine
Hello:
The first thing to check is at the water inlets, normally these have screen in them. If the screens are clogged no water will flow.
Jan 07, 2014 | Washing Machines
Simpson eziset 605 wont take in hot water
Hot valve in washing machine required. Part is between $25 & $60 STEP 1: unplug machine STEP 2: undo the 3 Phillips screws on top of machine the fold top console forward STEP 3: Undo hot tap,disconnect 2 wires running to hot valve,remove valve,fit new valve. STEP 4: Refit top console. DONE
Jun 17, 2012 | Washing Machines
Simpson Encore 605 agitator bolt comes loose - does it need loctite?
The wear is preventing it from tightening correctly, loctite won't be a long term fix, it will still come loose again due to the forces put on the bolt by the vibrations of the agitator. The only way to fix it is to replace the agitator.
Mar 06, 2012 | Washing Machines
Simpson encore 605 fault code are as follows during wash process stop suddenly, strat to beep and all lights are gone except the Maxi light . It flashs while beeps
Hi, my Simpson encore 605 wash machine wash on the half way keeps beeping, and the maxi is keep flashing. What kind problem it is?
Cheers!
Feb 12, 2012 | Washing Machines
Simpson encore 605
Sounds like a motor transmission problem.190.00 parts and labor is not a bad price.
Check if there is a warranty with the new parts the service person is installing.
Oct 27, 2011 | Washing Machines
Simpson encore 605 wash machine 6kg. Washer pump
Jun 19, 2010 | Washing Machines
My simpson encore 605 beeps when you press the start button buy no water comes threw. Water is on at the tap. Same if water is on hot or cold. worked last night then stopped today. can you help
Nov 05, 2009 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
