Question about LG DLE2512W Electric Dryer
Lg dryer air flow sensor lite wont reset - LG DLE2512W Electric Dryer
How to reset the service engine lite for a mass air flow sensor
It can be reset by a code reader or autozone, dealership, any car repair garage.
Apr 01, 2014 | Metra 72-4568 2005 - 2008 BUICK LACROSSE...
LG DLG2251W won't heat up
Your post is from 2008 but I am having the same problems with this dryer, same model. This is an LG problem, for crying out loud LG ---- GET IT FIXED. No more LG dryers for me. My $300 Kenmore works like a charm.
The first LG dryer they sent me I thought was a lemon. They came out and replaced the motherboard on the brand new dryer. They came out again and couldn't figure out why it wouldn't dry my clothes, and the second time they gave me another brand new dryer. Same problem with this one and all brand new perfectly clear ducts. Really?????
Google "lg dryer spins but no heat" on youtube - he explains how to get to the sensor and reset it, but still trying to figure out where to find it on my model. I can't believe I have to go through all of this with a $1000 machine!! Never ever again. Avoid LG dryers at all costs. It takes me HOURS to dry a load of laundry. Wanna throw a dry piece of clothing in the dryer for a few minutes to get the wrinkles out? hahaha think again. The heat will never come on even with the manual (non sensor) setting.
Again = AVOID LG DRYERS AT ALL COSTS. It's not worth the headache.
Nov 25, 2012 | LG DLG2251W 27" Front Load 7.1 Cu. Ft. Gas...
Check engine lite came on had it coded said bad master air flow sensors replaced it had it recoded lcheck engine lite came right back on
Have a them reset the codes. You can fix an error code and go check it right after and it will still be throwing codes. So just have them reset it.
Aug 04, 2012 | 2002 Chevrolet Impala
Dryer flow sensor shows 4 bars
lint trap holder has got some lint overflow caught down inside it ,past lint screen , I use a piece of small pool pump hose taped to the end of a normal vacuum to suck it out
May 08, 2009 | LG DLE5955 Dryer
Gas LG dryer works fine, but heat wont stay on more than a minute. then if i try to start it again, the heat wont come on at all. if i wait a few hours, then the same things happens again. heat comes on,...
First, check to see if there is strong air flow out the house at the exterior dryer vent. It is very important to have good air flow for gas dryers. Second, if you do have good air flow and you do get ignition but the burner shuts down quickly and won't relight, the most likely cause is the coils on the gas valve. They heat up when current passes through them and can open up electrically. When they cool down, the process can repeat. The coils for LG gas valves are not available as separate parts. You have to order a complete gas valve, but you can then take the coils off the new valve and swap them out onto the original valve so you don't have to change out the entire valve. If you need instructions on how to get at the gas valve, let me know (with your model number).
Remember, check your air flow first !
Please rate this solution once you have completed your repair. Thanks.
Dec 12, 2008 | LG DLG5932W Gas Dryer
Burner wont stay lite for more than 60 sec.
There are two things which could cause this.
First, if there is insufficient air flow, and second would be if one of the coils on the gas valve open up as it warms (as current flows through it). If you have good air flow out the outside exhaust with this problem, replace the gas valve. (coils are not available individually, even though you can swap out the coils from the old and new valve without physically changing the entire valve)
Dec 11, 2008 | LG DLG5932W Gas Dryer
LG DLE2512W Electric Dryer Logo
24 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
