Question about Sony MDR-RF960RK Consumer Headset
Tube me how to change my batteries on my Sony TMR-RF970R head phones for tv
Show me where to change batteries
Sony TmR-RF985-R what type of battery for head set wireless
Look in the user manual or go on ebay to find a replacement battery.
May 16, 2017 | Sony Computers & Internet
Cannot get my sony KDL 46HX803, TMR-BR100 transmitter and PS3 to play/sync 3d!! The TV does not seem to recognise the transmitter when plugged in.
I have same problem now. Always worked before. Your post is old. Did you ever get it fixed? I don't know if its ok to put my email address here, buy hoping to solve this. rsmor48@hotmail.com
Any help appreciated.
Roger M
Jan 09, 2011 | Sony TMRBR100 3D Sync Transmitter for 3D...
The screen will show a white line every few seconds, then will black out, this will go on as long as the TV is plugged in.
The Picture Tube of the TV must have got damaged. Give the TV to TV brand's technical support and change the picture tube, Thank You.
Oct 23, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have Model MDR-RF970R and the battery is not holding a charge. Where can I get another battery? The # on the battery is BP-HP550-11/2.4v 550mAh. Thanks. Joe
Sony has some special case they put around the original 2 batteries to hold them together.
You don't need to buy special batteries. You can put regular AAA NiMH in.
To remove the compartment cover on the headsets make sure you hold down the pressure button on the left headphone to release the cover. Mine has the words "PUSH" on them.
With the cover removed you can then see the original BP-HP550 sony battery. Which you can remove and put 2 regular AAA batteries in.
Oct 07, 2010 | Sony MDR-RF960RK Consumer Headset
I'm looking where to buy sony mdr-rf970r ear pads
https://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?searchOperation=modelSearch&searchText=MDRRF970RK&sessionId=FLk3TTjKj9RC2AYaSnUQb_k
This is the link from sony style for accessories and online ordering for your headset. Hope this helps.
Oct 03, 2010 | Sony MDR-RF970RK Headphones
Need replacement batteries for Headphones(Sony) MDR-RF970
You can use 2 AAA batteries. I just tried it on some similar headphones (MDR-RF970R).
Aug 26, 2010 | Sony MDR-RF960RK Consumer Headset
Hello! I have Sony MDR-RF800R wireless stereo hea...
Hi there. I had the same problem after a while of having them packed and unused! Try this: Hard clean the batteries connectors with alcohol or some other cleaning fluid (I don't remember which one I've used). It solved my problem and now they charge fine and even with the expiration date of the batteries expired they are still working but I mean working very very well. Hope this helped though somewhat late reply... Might help other users too!
May 20, 2010 | Computers & Internet
Ps3
Depending on your television, if it's a tube then your display settings should be at 480i and no higher. Sounds like you set it at 720 or 1080 and your TV can't handle the resolution. You need to go to the PS3 main screen (turn on without game in it) and select the "settings" ( might be called "system settings", 2nd or 3rd icon from the left), a sub menu will show up and look for the 'display settings' heading and change it back to 480i. That should do it. Reset the PS3 just to make sure the new settings take effect.
Jan 08, 2008 | Sony Playstation 3 (PS3) Console
Sony MDR-RF960RK Consumer Headset Logo
Top Sony Radio Communications Experts
 Grubhead
Grubhead
Michial Gueffroy
basssplayer
Level 1 Expert
Are you a Sony Radio Communication Expert? Answer questions, earn points and help others
