Ecoquest Living Air Classic Air Purifier
Problem for Ecoquest Living Air Classic Air Purifier
Fan is not turning on
By donlisa on Oct 26, 2007
We have a Living Air Classic XL-15 and cannot get the fan to turn on. The green light is on inside, the fuse seems fine, the filter is pretty clean, the plate is clean.
I replaced the connector on broken red wire that was connected to the post labeled "caution high voltage." Yet the fan still won't turn on.
Can you offer any assistance? Thank you!!!
Best Solution
posted on Nov 10, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
The fan motor is probably locked up. You can either put a little oil to free it up (usually a temporary fix) or better yet replace the fan motor.
Popular Solutions for Ecoquest Living Air Classic
Questions and Unsolved Problems for Ecoquest Living Air Classic
Do you recommend Ecoquest Living Air Classic Air Purifier?
Answer
Answer
I have a Classic Living Air model XL-15C. I keep hearing a loud rattling noise from inside. I... (More)
Answer
no high voltage to grid after 5 minutes operation
Answer
Appears that the high volatge supply has failed. Neither lamp (inside) is illuminated consiquentlky... (More)
Answer
the ozone only comes on at the highest setting. It is to strong to have it on that level. What is... (More)
Answer
Not producing ozone, wire on little round sensor is broken on the small silicned in circuit board... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ecoquest Living Air Classic...:
Top Air Purifier Experts
Rank: Guru Guru
Solutions: 2511
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Air Purifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
