Question about Whirlpool WFW8300SW
How old is my WFW8300SW - Whirlpool WFW8300SW
I have a whirlpool duet sport that is displaying F28 code. I have replaced the ccu unit now what do I do. It fills but will not wash, drains but will not spin HELP PLEASE!
For the F28 error code:
First, check the wiring harness connections to the MCU, the Motor, and the CCU. Make sure all the connections are tight and there are no ground wires off. Then check the connections of the CCU board within the housing.
If the wiring connections are fine then It would be a good idea to order both, as both components have been problematic for the error code F28.
Here is the CCU to order.
Here is the MCU to order.
Nov 03, 2012 | Whirlpool WFW8300SW
Loud noise during spin cycle
this could be a fuw things it may be the drum bearings wearing out they will screem on spin speed
or some thing inside the drum jamed in it so it hits the inner drum
Dec 02, 2010 | Whirlpool WFW8300SW
On my washer machine appear code F-01, what that mean?
Under the front panel on the bottom of the machine is the error code manual. Mine says a CCU replacement for the F-01 error code.
Nov 22, 2010 | Whirlpool WFW8300SW
Where do i find the lint filter
theres a lint trap on the units pump located behind the access panel next to the floor just below the door,it just unscrews off the pump for clean out
Jul 14, 2010 | Whirlpool WFW8300SW
F 28 message
your motor control board has probably failed in the bootom of the machine.
Apr 26, 2010 | Whirlpool WFW8300SW
The door locks when the start button is pressed, but the cycle will not start. Diagnostics shows F26 door lock assembly. Whirlpool WFW8300SW. I have replaced the CCU and it still locks but nothing happens...
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Feb 18, 2010 | Whirlpool WFW8300SW
Does not start
check the motor bushes.
Jul 15, 2009 | Whirlpool WFW8300SW
My sears top loading washing machine has a HORRIBLE odor inside.
if it smells like something dead you may have a dead mouse somewhere inside cabinet
May 30, 2009 | Whirlpool WFW8300SW
Whirlpool wfw8300sw
if prvious owner has had no problems sounds like a good deal that is less that half new price no major issues most problems are customer instructs ..front loads are just catching on.. a lot of people don't fully understand them and with electronic controls they can be fickle..
Jun 18, 2008 | Whirlpool WFW8300SW
Whirlpool WFW8300SW Logo
22 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
