Question about Kohler K-10430-VS Fort½ Single Lever Handle Kitchen Faucet with Side S...
Remove diverter - Kohler K-10430-VS Fort½ Single Lever Handle Kitchen Faucet with Side S...
How do I replace/repair the sprayer diverter valve in a Tuscany kitchen faucet?
Do you have a model # ? Normally the diverter will be exposed by removing the spout.
Dec 23, 2014 | Plumbing
Old Moen shower diverter
You will have to replace the shower diverter button. Remove the handle, remove the faceplate, and the diverter will screw out. Any plumbing supply that carries Moen products will have a replacement button for your valve
Feb 23, 2014 | Moen Home
Need to get handle off of pantera sand filter
You need to remove the "key assembly" before removing the handle. The key assembly is the lid, handle and diverter which all come out in one piece after taking the bolts out around the lid.
Once the assembly has been removed, you need to compress the lid down toward the diverter to allow the handle to move freely. At that point the handle pin, which connects the handle to the diverter may be removed. Note the position of the handle's pointer and the open slot on the diverter. When reassembling it is important that they are in the same position. If not careful the handle will be 180 degrees off.
Its a good idea to go ahead and change out the diverter o-rings and bearing on top of the lid (that the handle slides upon while turning) while you have it open.
Mar 13, 2013 | Pool & Spa
Replace diverter in 2 handle aqua source kitchen faucet
For a dual-handle Aquasource kitchen faucet with spray hose, the following instructions will afford replacement of the diverter. These instructions specifically refer to the faucet illustrated at http://pdf.lowes.com/installationguides/6953123900358_install.pdf, and the diverter identified as part RP70007 (item 14). Note the position of notches at the top of the diverter and around the rim of the base of the diverter, either of which can be used to leverage a tool to rotate the diverter out of position. Caution: The diverters on older faucets may be exceptionally brittle and thus very difficult to remove.
1. Using a pipe wrench or similar large-mouth wrench, unscrew the base of the faucet. Wrap the base with a cloth or other protective material to prevent scratching during the process of unscrewing. The base unscrews in a counter-clockwise direction.
2. With the base removed, remove the faucet. Note that a small amount of water may drain from the faucet when removed.
3. Removal of the base reveals the top of the diverter, which is a white, plastic cylinder approximately two inches long with copper stopper in the bottom. Insert a wide, flat-blade screwdriver across the notches in the top of the diverter - but be *extremely* careful. A faucet that has been installed for some length of time may have an exceptionally brittle diverter. If the upper shaft of the diverter breaks, a pair of needle-nose pliers may be used in the notches around the *base* of the diverter. Carefully rotate the diverter counter-clockwise to remove it.
4. Insert the new diverter and screw it into place in a clockwise direction. Apply a wide, flat blade across the notches in the top of the diverter to apply slight additional pressure to tighten the diverter just beyond hand-tightness.
5. Re-insert the faucet.
6. Screw the base back into position, tightening as necessary.
7. Test the operation of the diverter by operating the cold and/or hot water faucets, then the spray handle.
Dec 24, 2012 | Plumbing
MY PHONE IS SWITCHED ON, BATTERY AND SIM CARD CORRECTLY INSERTED BUT WONT ACCEPT CALLS. IT AUTOMATICALLY DIVERTS TO VOICE MAIL. PLEASE HELP
Hello Damien barlo, I have a solution for you. Please remember to provide me POSITIVE FEEDBACK so that I can continue providing expert solutions for free.
Please remove both the battery and your phone from a charging jack. Remove the SIM card and replace the SIM card in firmly. If you have a storage flash card, then ensure to remove that as well as replace it back into the phone. Next, step outside the home and set the phone down on the ground all allow it to find a signal on its own without you having to move around to find the best signal. If you have a second phone, please try to call your cell phone to see if it rings correctly without going to your voice mail. If your problem continues, please come back for more free expert solutions.
Thank you,
Jan 11, 2011 | Nokia 6300 Cellular Phone
I have a delta tub shower faucet with a pull-out diverter. The model is "Delex" by Delta as stamped on the cover plates. I have not had any luck finding a replacement diverter. Neither Delta U.S...
take the details to a plumber supply shop ( where the tradies get their parts ) and discuss the problem with them
it is very possible that there are other makes that will fit in the holes to replace the delta unit
Mar 25, 2017 | Delta & Single Handle Shower Faucet
How to deactivate active call divert
put your sim card to another phone and change the divert settings.deactivate them.then you will not get a msg.
Aug 17, 2009 | Nokia 6233 Cellular Phone
Water sprays out the diverter
Remove hot/cold button in handle, remove screw/pull off handle. Remove the two screws in the wall plate/remove plate. Use a wrench to remove the diverter assembly. Get new diverter assy and reinstall eveything. You don't need to turn off the water.
Jun 09, 2009 | Delta Faucet #RP320 Divert Assembly
Call Divert wont go off!
Hi guys
That call divert comes automatically, did my nuts in today. Anyway just key this code
#002# , then press the green key, then bingo call divert off.
cheers
Irwin
Nov 12, 2007 | Motorola Mobility RAZR V3x Cellular Phone
Kohler K-10430-VS  Fort½ Single Lever Handle Kitchen Faucet with Side S... Logo
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
