Question about Frigidaire Dishwashers
Dishwasher door drops down too far
Frigidaire Gallery dishwasher FGDW
SOURCE: dishwasher door
new rope on one spring fixed it
Posted on May 21, 2007
SOURCE: frigidaire gallery series FDB125ORES1 wash
The lights flashed on mine for about three months before smoke started to pour out of it during the drying cycle. It nearly burned my house down.
Posted on Sep 03, 2008
Krazytech
  • 725 Answers
SOURCE: error code HO on frigidaire gallery series dishwasher
If your hot water isn’t hot enough it will display “HO” while heating the water to operating temperature
Posted on Sep 07, 2008
SOURCE: Frigidaire Dishw. Error code CL
this just happened to ours and it turned out to be the gasket that seals the door.
when you see the CL error and the door is indeed shut, pull gently back on the door. if you hear a click and the unit starts running again, it may be the gasket.
ours lost it's ability to keep the seal, allowing enough 'play' in the locking mechanism for it to think the door was not closed.
Posted on Sep 09, 2008
jonniewalker
  • 1029 Answers
SOURCE: The door on my dishwasher will not close
There are a few problems that can occur with the diswasher door assembly. These usually involve the latching mechanism, the door seal, the counterbalance spring assembly or the hinges. 1) The door latch plate can occasionally become out of alignment. Some door latch plates are adjustable, some aren't. If yours is adjustable, try loosening the retaining screws and repositioning the plate. It's trial-and-error, so have a lot of patience. If this doesn't work, then the latch needs replacing.
2) A new dishwasher or a newly installed door seal can be difficult to close for a while until the seal softens and compresses over time. You can try adjusting the latch, if possible.
3) If the door feels unusually heavy, there could be a problem with the counterbalance spring assembly. These counterbalance assemblies allow the door to open and close easier and are held by two springs. On some dishwasher models, holes are positioned in line so you can re-tension the springs by moving the spring hooks to other tensioning holes. If any of these springs break, they will need to be replaced as a pair.
4) The door hinges might be bent. They can seldom be adequately fixed and should be replaced.
hope this helps
Posted on Nov 24, 2008
What do I adjust to prevent the door from opening too fast? When I open the dishwasher door I must hold it so it does not come down too fast
Herbert,
You probably have a broken door spring or a hing cable. I looked your model up on Sears parts direct and have included a link. You are looking for item #1 or #1A. Good luck! http www searspartsdirect com frigidaire dishwasher parts model...
Apr 07, 2015 | Frigidaire Gallery FGHD2465NF Fully...
How can I get my Frigidaire Dishwasher 900 series to start?
Sounds like you have a bad door switch. You might also have a motor that tends to freeze or lock up. It could possibly be a bad motor capacitor too. Does this help?
Mar 18, 2015 | Frigidaire Gallery Dishwashers
How to fix a squeaky door on a frigidaire gallery dishwasher
Thank you for your post, friend!
I see that you need assistance in repairing a squeaky door on your Frigidaire dishwasher. The best way to quiet down a squeaky door is to pinpoint the cause of the squeak. This could be an issue with your hinges, springs, or the cables. You can use a lubricant such as WD-40 on your those parts to see if that will help alleviate the squeaking. Hope this is helpful. -Matt
Feb 27, 2015 | Dishwashers
Frigidaire gallery fghd2455lf leaks from bottom of door
Thank you for your post, Jacques Lanthier!
From what you have described it sounds like you could have a loose or bad gasket on your Frigidaire dishwasher. Typically, to clean any seals you would remove them and wipe them off with a rag and warm water. If you continue to experience an issue with water leaking I would recommend replacing the gaskets. I hope this information has been helpful. -Matt
Jan 10, 2015 | Frigidaire Gallery FGHD2455LF Full Console...
Why are the lights on the far right of the panel of the Frigidaire gallery dishwasher model #GLD8958A52 ?
Hi friend, thank you for your inquiry!
I understand that the panel on your Frigidaire dishwasher has lights on the far right side of the panel. I would recommend a reset on your dishwasher and you can do that by flipping the household circuit breaker in the off position for ten minutes. The lights on the right side of the panel could be providing a warning to inform the panel that something is wrong. A reset could provide an error code for further diagnosis. I hope this information has been helpful. -Matt
Oct 16, 2014 | Frigidaire Gallery 24" Built-In Dishwasher...
Power failure
  • Find the "Start/Cancel" button on the dishwasher's control pad. This button is located on the far-right side of the pad on most Frigidaire Gallery dishwasher models.
  • 3 Press the "Start/Cancel" button to clear the "PF" error code. Resume using the dishwasher as normal. You may have to reselect and start your cycle from the beginning.
Dec 02, 2013 | Frigidaire FDB520RH Builtin Dishwasher
Frigidaire Gallery dishwasher smoke coming out of door. smells like wires burning.
You need to replace the blower assembly, common prob after a few years of use.
Part number: 154226802 "Blower-Crossflow", suggested list at this time is around 30.00 us dollars.
To replace: TURN OFF BRAKER TO DISHWASHER
Open door, remove inside screws form panel and carefully remove panel up from door, blower is next to timer on control panel.
Nov 12, 2009 | Frigidaire 24 in. FDB636GF Built-in...
My dishwasher door goes down to far because my dog stepped on it
There are two problems that can cause this.
a.) The hinges of the door are broken and need to be replaced.
b.) The dishwasher (if it is an under counter model) is not firmly secured in the cabinet and when the basket rolls out, the whole dishwasher tips out.
Please post back what you find, OK? When you do, plese post the model number of the Frigidaire dishwasher.
Apr 10, 2009 | Frigidaire Dishwashers
Fridgidaire Gallery Series Dishwasher Leaks from bottom
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
wre
Mar 01, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Loose handle on frididaire gallery series dishwasher
Handle needs to be replaced part# 154537303 (blk). Un plug unit, take 4 screws from behind blk control panel out. Panel will fold down, remove two torx head screws from door latch, replace with new one and put it back together and your done.
Dec 12, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwashers Logo
16 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
