Question about GE Spacemaker JVM1640SJ Microwave Oven
GE model HVM1540LN1CS - touch does not work
Touch pad states to please press clock - touch pad does not respond
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
Bad touch pad
Posted on Sep 23, 2014
localwonder
  • 6784 Answers
SOURCE: touch pad does not work, clocke does, nothing else works
Hi this will happen when the touch pad circuits become unstable and damaged, due to abundant usage or , old age.
simply replacing the touch pad will fix this issue.
Posted on Jun 01, 2009
SOURCE: touch pad doesn't work
ut the tech sheet did mention that intermittent F7 problems are usually caused by poor connections. So I pulled the ribbon connector off the control board and cleaned the copper connectors using a pink pencil eraser. That whupped that puppy! But then I went out on another service call, same oven, different house. The pink pencil eraser trick didn't work on this one so I had to apply some of that famous Samurai gray matter. To identify the problem on this one, I cut power to the range and disconnected the ribbon connector that connected the touch pad to the electronic range control (ERC) board. Then I re-applied power and let it sit that way for 24 hours after which the customer was instructed to call me and report on the error code status of the oven. If no error code was reported, I knew the touch pad was the problem. If, on the other hand, the F7 error code came back, then I knew the (ERC) was the culprit. In this case, the error code did not come back during the test period and, using my keen, Vulcan-like powers of deduction, concluded that the touch pad was defective. I replaced the touch pad and problem solved!
Posted on Jun 11, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Touch sreen won't work
I would suspect it either needs a hard reset (unplugging it for a few minutes, then trying again) or the membrane keypad is failing.
Instead of JMV1540BMC01, it would probably be one of these models:
JVM1540DM1BB
JVM1540DM1CC
JVM1540DM1WW
JVM1540DM2BB
JVM1540DM2CC
JVM1540DM2WW
JVM1540DN1BB
JVM1540DN1CC
JVM1540DN1WW
JVM1540DN2BB
JVM1540DN2CC
JVM1540DN2WW
JVM1540LM1CS
JVM1540LM2CS
JVM1540LN1CS
JVM1540LN2CS
JVM1540SM1SS
JVM1540SM2SS
JVM1540SN1SS
JVM1540SN2SS
Since FixYa is not currently notifying us Experts when Clarification Requests are answered, feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Oct 11, 2009
  • 6771 Answers
SOURCE: I have a 2003 GE Spacemaker model 2.0 (JVM2070WH001): the touch pad has stopped responding to any input. Can it be fixed?
Yes! but the whole keypad control or smart board will need to be replaced. I highly recommend a professional for this job and do a spot check on the rest of the unit.
Posted on Apr 02, 2012
SOURCE: GE model JVM2070SK02 touch pad not working
Most people, and GE will tell you these are not repairable and you must replace the whole unit for $300 - 500. I can fix them. If you are interested, let me know. em.ka.ventures@gmail.com I can only fix the touchpad not working and it must not be physically damaged. You must be able to take out the control panel and send it to me. It is easy (3 screws and electrical connectors).
Posted on Jun 19, 2012
My GE Advantium microwave is beeping about 5 times every 2 minutes or so. The display says, "Keypanel Shorted. May need service. Press CLEAR to continue." Ironically, I need a working keypanel to press...
check the touch pad or control unit any short circuit in the control unit, other wise any moisture at control unit chec the circuit other wise replace the touch pad.
Jan 28, 2014 | GE Advantium SCA2000B Microwave Oven
Touchpad is not working
Hello :
If touch pad has gotten wet, then allow to dry for several days. Avoid spraying cleaning liquid near touch pad.
Check for insect infestation. Insects (cockroaches most frequently) will appear under clear surface of touch pad or under readout window; they like the warmth of the circuit boards.
Place window mesh over vent to keep insects out.
good luck .
please rate !
Mar 29, 2010 | GE Microwave Ovens
Power went out. Microwave just scrolls press clock!!!!!!!!!
Did you figure this out? I am having the same problem. I see PRESS CLOCK on the control display. But none of the keys on the touch pad work. GE sucks bigtime !!
Jan 17, 2010 | GE Spacemaker JVM1540 Microwave Oven
GE model JVM5503 (1980): light and exhaust fan work, but touch pad does not respond to pressing buttons and therefore no functions can be initiated.
That would be a problem with your "touch control" but it is no longer available.
The oven will have to be replaced.
Sounds like it had a good run.
Jan 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How do I get it out of lock mode
If the model number you have listed is correct, you turn the Child Lock feature on/off by pressing and holding the "Clear/Off" button for three seconds. The instructions are on page 28 of the Owner/Operator Manual.
If your model number is different from the one you have this question posted under, please post back with your correct information so that I may be able to provide you with better assistance.
I hope this helps you.
Nov 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
What does f3 mean in the window of a GE microwave
Code F3 is for 'shorted touch pad panel'.
However, this is not always the case.
Try the following;
Press (and hold) the Clear/Power button to reset the microwave and turned it off. Press it again to turn the microwave back on. set the clock. If the touch pach panel is okey, your microwave should work with no problem.
Oct 10, 2009 | GE Microwave Ovens
The clock works & counts down but the microwave won't heat
  • Disconnect the power for 30 seconds. After restoring power, do not set the clock.
  • If your model has an ON/OFF clock display, you can choose not to have the time displayed. To choose this option, press the 0 pad for about three seconds. To Turn the display back on, press the 0 again.
Touch the clock pad. Enter in the correct time of day by touching the numbers in sequence. Touch the clock pad again.
Aug 03, 2009 | Sharp R-1460 Microwave Oven
Touch pad does not work, clocke does, nothing else works
May 30, 2009 | GE JVM2070 Microwave Oven
No numbered touch pad for use setting clock
I think on this one you press the CLOCK/TIMER pad, then enter the desired time using the 10 MINUTES, 1 MINUTE, AND 15 SECONDS pads then press CLOCK/TIMER again.
If that doesn;t work, press STOP / CLEAR then try the above again.
Let us know if it does not work.
Mar 05, 2009 | Sharp Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
163 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
