Question about Panasonic Kx-e7000 Electric Typewriter
I have a panasonic kx-E7000 and some buttons on the keyboard work and some dont, is there a way i can fix the problem?
  • Panasonic Master
  • 3,594 Answers
You can remove, disassemble clean with alcohol, put a little powdered graphite on the rubber contacts.
DickyO
Posted on Feb 13, 2014
Where can I get an instruction manual?
Panasonic kx-tga600b handset manual - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesPanasonic kx tga600b cordless extension handset manual. Panasonic kx ...Panasonic kx tga520 5.8 ghz fhss cordless expansion handset manual. Panasonic kx ... Panasonic kx tg6071 operating instructions manual pdf download. Panasonic... Need manual for kx tga600b so i can turn off voice mail dont need. Panasonic ...
Kx-tg6500 manual - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesPanasonic kx tg6500 operating instructions manual pdf download. Panasonic ...Panasonic kx tga650b cordless extension handset installation. Troubleshooting ...Panasonic kxtga651b dect 6.0 plus expansion handset black kx. Panasonic kx ...Can i register a kxtg6500 handset with a kxtg4500 base. Panasonic kx tg6502 ...
Panasonic KX-TGA650B ' Installation Manual - Page 3
Feb 09, 2016 | Panasonic KX-TGA650B (037988474806)...
How can I change the number of rings on a Panasonic phone
On the Handset;
1. Press [MENU] [#] [2] [1] [1]
2. Press the [up] or the [down] button to select the desired ring count*.
3. Press [SAVE]
4. Press [OFF]
Jul 23, 2014 | Panasonic Kx-tg1032b Kx-tg1033b Kx-tg1034b...
Panasonic KX-TG5652 How do I make it so I dont hear people leaving messages?
While the base unit is idle, press GREETING CHECK button then press VOL.(arrow down) button until "0" is displayed. I have included a link where you can download the manual if you need it.
http://service.us.panasonic.com/OPERMANPDF/KXTG5631.PDF
Mar 30, 2011 | Panasonic KX-TG5652 Twin Cordless Phone
Panasonic KX-FL511 The 7, 8, & 9 buttons on the phone dial pad and the 'copy start' button have stopped working. All other functions and buttons work fine, what do you think it is? and how can it be...
The signal from each of these buttons, as well as the Prev and CID Print buttons, goes to the same place: pin #1 on the little square chip that controls the keyboard and the display. Suspect either the chip or that section of wiring. This is all on the operation board (the one on which the switches are mounted). The machine can be repaired by repairing or replacing the operation board. If you are an electronics tech or do-it-yourselfer, see the instructions and parts list in the service manual. Otherwise, you can search for a tech in your zipcode at the bottom of this Panasonic support page. Insert mode
Mar 29, 2011 | Panasonic KX-FL511 Plain Paper Laser Fax
MY PANASONIC TYPEWRIITER KX-E7000 WONT TYPE M'S OR 9'S SOMETIMES .DO YOU THINK I NEED A NEW DAISY WHEEL
If it types something in place of the letter you need a printwheel, if it dosent do anything (print or space) the key board is the problem.
DickyO
Sep 22, 2010 | Office Equipment & Supplies
Panasonic kx-tg5839al cordless phone on base set #1 button only works intermittently. Is there an easy fix for this (out of warranty)
No, the keypad is worn out. The electronic need to be replaced. Could be more costly to have repaired.
Apr 29, 2009 | Lands Phones
Handle Speaker phone stopped working
I'll assume this is on the base station portion. You can try unplugging the power while the phone is in the base, wait a minute, then plug back in. If that has no effect, I'm afraid you either have a failure in the keypad or in the electronics. To diagnose a keypad failure in the base, you'll need to disassemble the base. You'll find each of the rubbery keys momentarily connects two traces on the keypad circuit board when you press a button. You may also find the keypad fouled with dirt, liquid, etc, which could be a likely cause of failure. You can try manually shorting the two traces where the SP/Phone button would press and see if you are able to activate the speakerphone/dialtone. If that works, then carefully clean the keyboard circuit board and the rubbery keys. If that does not work, I conclude you have a bad keyboard circuit board or other electronics in the phone are bad.
Dec 16, 2007 | Panasonic KX TC1713 Cordless Phone
Panasonic Kx-e7000 Electric Typewriter Logo
140 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
