Question about HP 640 Inkjet Fax Machine
I have the same problem as blackwufgar. I did not use the fax machine for some time and now it won't print anything. I purchased a new cartridge and it still won't print!!
The ink cartridge moves over the paper as if it is printing but nothing comes out on the paper.
Tonerman
  • 62 Answers
SOURCE: Message Ink Cartridge stalled
the machine needs servicing, something is causing the carriage to stall
Posted on Jul 11, 2007
  • 1003 Answers
SOURCE: installed a brand new cartridge in hp 1040 fax but prints very poorly(light )
remove the new cartridge
TAKE A MICROFIBER CLOTH MOISTENED WITH RUBBING ALCOHOL AND WIPE THE PRINT HEAD ( THE PART OF THE CARTRIDGE THAT CONTACTS PAPER)
REINSTALL THE CARTRIDGE THEN TEST
ALSO YOU MAY WANT TO WIPE OFF THE CONTACTS ON THE BACK OF THE INK CARTRIDE WITH THE MICROFIBER CLOTH MAKING SURE THERE ARE NO FINGERPRINTS ON THE CONTACTS
Posted on Jan 18, 2008
  • 106 Answers
SOURCE: Machine not printing
try to go a setup and option clean the cartridge
Posted on Feb 05, 2008
wellirp
  • 23 Answers
SOURCE: Acts like it is printing but nothing comes on the paper
some cartridges comes with deffects, replace with new one or reclaim warranty to your dealer
Posted on Mar 22, 2008
rakeshpramod
  • 234 Answers
SOURCE: lexmark 5400 all in one
It is observed in branded printer not only lexmark also with HP printers yoou get this same problem.
It is always recomended to use genuine cartridges rather than refilled or any other brand ink cartridges.
As for HP cartridges they are all made under six sigma process where it is very rare you get a ink cartridge issue.
thats why HP Gives 18 months of replacement warranty on its cartridges
The same applies to Lexmark printers aswell
Make a habit of usig Genuine cartridges which will give value for your money.
Posted on Aug 28, 2008
I have an HP 2140 fax purchased one year ago. I have never replaced the catridge and have used the fax about once a month. Today I am trying to copy and it won't print. I cleaned the nozzle and still...
New cartridge wouldnt print but sounded like it was printing. You can check ink levels clean or align cartridge by pushing menu then tools. I cleaned contact points w qtip and alcohol. What seemed to work is putting alcohol on cartridge where ink is released and putting back into machine wet did this three times first time little dots of ink then a faint print and now it is printing must have been dried ink further then I could access.
Apr 12, 2011 | HEWLETT-PACKARD HP 2140 Fax
How do you load a new ink cartridge?
Replacing the Print Cartridge
1 Open the front cover, and then open the top cover by pressing the blue levers on both sides of the top cover.
2 Remove the old print cartridge containing the used ribbon and dispose of it.
3 Remove the plastic stopper from the new print cartridge.
Note You can reuse the print cartridge until it breaks. If you purchased refill ribbons, follow the instructions that came with them.
4 Turn the black spool on the right clockwise to tighten the ribbon as shown.
5 Install the new print cartridge by inserting the recessed first, and then placing
the cartridge into its four holders.
6 Press down on both sides of the top cover to close it securely.
7 Close the front cover.
Brother Customer Service at 1-800-284-4329 (in USA) or 1-877-BROTHER (in Canada).
Vertical Black Lines When Receiving
The sender's scanner may be dirty. Ask the sender to make a copy to see if the
problem is with the sending machine. Try receiving from another fax machine.
If the problem continues, call Brother Customer Service at 1-800-284-4329
You can save money by purchasing the 2-PK Refill Ribbon Rolls (PC302RF).
Installation instructions will be included. If you handle the print cartridge (frame)
carefully, you can reuse it until it breaks.
Jan 17, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
No print on copies or faxes
This is a clogged print head. This happens if the printer has been off for a long time or if the cartridge was removed and the unit left empty for any time.
Take out the cartridge and press the print part on a piece of paper. Any black lines? If not, you will need a new cartridge. Wiping the print head gently with a Q-tip moistened with PURE alcohol (99%) may restore printing.
Mar 31, 2010 | HP 1040 Plain Paper Inkjet Fax
No print on rec'd or sent faxes
Surely you don't have blank copies rec'd and sent as these are two different parts of the machine entirely. I'll assume you mean rec'd and copied. Sounds like you've left a packaging seal on the cartridge to me - or it's a faulty cartridge. Remove the cartridge and check that all packaging has been removed - especially plastic strip that prevents toner from dropping into the cartridge.
Jul 01, 2009 | Canon FaxPhone L75 Plain Paper Laser
I don't use the color printing yet the color cartridges are empty
It's all a scam. I have the same problem and I called Brother and they told me that the machine uses color ink to clean itself. It costs more to replace these color cartridges then to buy a new one, which is what I'm going to do. Buy a black and white from a different company. It's all a scam to get you to spend money on their color ink that you don't use.
Mar 25, 2009 | Brother IntelliFax 1860C Plain Paper...
Fax will not print after installation of new cartridge
Look at your NEW print cartridge again, very carefully. I'll bet there's another piece of tape on the bottom of it. That's what happened to me.
Dec 03, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
HP 920 Fax Half Lines
Try making a copy of something.
If the copy comes out the same way as your faxes, then the ink cartridge is either dirty or clogged.
You can try removing the cartridge and checking the bottom of it.
You can even wipe the bottom of the cartridge with some denatured alcohol.
If this doesnt work, then purchase a new cartridge and your problem should be solved.
Good luck.
Hope this helps.
Mac =)
Apr 02, 2008 | HP 920 Plain Paper Fax
Fax not printing or scanning
Sounds like the guy who refilled screwed-up the cart...Go back to the shop and have them check it on their test machine..Good luck.. Dave,, Ulster,, Northern Ireland,,
Nov 02, 2006 | Samsung SF-330 Plain Paper Inkjet Fax
Open Questions:
See all HP 640 Inkjet Fax Machine Questions
HP 640 Inkjet Fax Machine Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
